    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Is it a navigation BUG .. Distance/ETE/ETA remained empty despite I was not far from the itinery
    57 Posts 8 Posters 8.4k Views 8 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • isaziI Offline
      isazi Moderator @DMytro
      @дима-мельниченко those are not POIs, but waypoints. If you have phone connectivity, you can create POIs, or even create a new route. If not, better you are prepared in advance.
      Blog: isazi's home
      DMytroD Mister PYCM 2 Replies Last reply Reply Quote 1
      • DMytroD Offline
        DMytro @isazi
        @isazi I’m aware. Just saying it would be nice to have as an option.
        • Mister PYCM Offline
          Mister PYC Silver Members @sartoric
          @sartoric
          it’s a super good question !!!
          Neither the blue nor the green.
          And this is exactly why I think this make interresting to have these informations => I will have first of all walked the way I was thinking to go BUT will have observed carefully how the 2 arrows and the distance indications will have spoken to me, permanently reevaluating my navigation options … for exemple … if I see the blue and the green arrow comes to the same angle even if I move, most surely I can go now straight and follow them … if you look to my exemple … this is exactly what will have happen at the end
          The fog problem is not a big deal if I’m in a desert, because here I may decide to go straight (assuming there is no quicksand 🙂 … anyway if there was the watch will not have told me in any case).
          The fog problem is interresting to study in mountain because there are constraints (cliff, glaciers, holes, …) but that could also be an advantage, you may arrive to a point which could give you some precious indication (a old farm) and which is on your paper map.
          Honestly speaking if I plan a route with such potential risks, I will for sure have also positionned multiple POI, so I will have some multpile backups plan …
          I’m more thinking here as a markjeting guy … how could I have promoted the watch instead just to say “Ooopss sorry you are lost” … imagine you can say your watch act as an angel for you 🙂 🙂 🙂 but not … this previous and expensive piece of modernity is now just a useless modern art which fall down in the first trap you put it in.
          Joking of course … humm … half of joke 🙂
          All is possible in IT
          Driven by you fear you stay on the ground, driven by your dreams you fly
            Mister PYC Silver Members @DMytro
            @дима-мельниченко
            You are totally correct, it will have been good.
            But here I think you can use the other option that the watch is proposing you already …
            If really you get lost and have a giant doubt that you could continue, the best is to do the road in the reverse side and come back in safety to your starting point, hence you can use the “petit poucet” feature and change th navigation to it.
            This is why I did not suggest to propose either the ENDING or the STARTING point. your watch has already recorded the real start of your journey.
            But… your question brings a very valuable point and this is exactly why I was suggesting an “advance angel mode” … if you have only the ENDING point navigation … you can never go back to the route you planned … because you have zero information to be back to it except at its end. in reverse if the watch has the capacity to determine the shortest point to be back to yoru planned road and display it … then you can recover at the beginning of your adventure and still join the start of your planned route … which was no more my case when I started from the wrong parking place even if located at a small reasonable distance
            Dimitrios KanellopoulosD 1 Reply Last reply Reply Quote 0
              Dimitrios Kanellopoulos Community Manager @Mister PYC
              @mister-pyc but it already does that with the find back.
              Creator of quantified-self.io - sync Garmin and COROS activities to Suunto, import Suunto routes, deliver Suunto routes to Garmin courses, and analyze training data in one private dashboard.
              Mister PYCM 1 Reply Last reply Reply Quote 1
                @дима-мельниченко
                hello
                I thaught more to your idea and I should confess that your proposal is even better that mine, much mor eeasy to put in place, not need to perform comple computations to search for any closest point between where I’m and the planned route.
                Simply : BEARING mode indicating 2 points : the real point from where I started my journey (back to safety) and the targeted point of my itinery (soon to safety)
                Doing so you can decide also continuously if you still continue or you prefer to stop and go back to where you came from … you can see at which moment potentially you reach the theoritical point of no return (especially for example if there are some consideration with water)
                Your proposal is by far better than mine.
                Here illustrated :
                At the begining, having the navigation to shifted toward BEGIN and END will let you know how to reach back the planned road
                At a certain time you will see that you may reach a point of no return …
                DMytroD 1 Reply Last reply Reply Quote 0
                  Mister PYC Silver Members @Dimitrios Kanellopoulos
                  @dimitrios-kanellopoulos
                  Yes this is exactly what I said with my poor english … talking about the “petit poucet” which is the french translation of tje find back.
                  Apologize my english is limited and sometimes I do not know the english term, my watch being in french mode
                  You saif exactly in 9 words what took me a chapter 🙂
                  Stil, the idea of @дима-мельниченко is a very good one.
                  Although you have this famous find back option, in case the watch observe you are out of route, switching to a “Angel mode” it will let you now how far you are from the beginning (theoritical or real … to be discussed, may be theoritical as you always will have the find back option to reach the real one) and the ending of yoru journey
                  Łukasz SzmigielŁ 1 Reply Last reply Reply Quote 0
                  • DMytroD Offline
                    DMytro @Mister PYC
                    @mister-pyc I only think this shouldn’t be an automatic switch but rather an automatic suggestion. Otherwise it can be annoying to see bearing navigation instead of planned route in case one wandered off just a few hundred metres on purpose.
                    isaziI 1 Reply Last reply Reply Quote 2
                    • isaziI Offline
                      @дима-мельниченко not just annoying, even dangerous. You are walking on a trail, you miss one turn, your watch instead of telling you (as it correctly does now) “off route” starts navigating you somewhere that may be unreachable or dangerous, even giving you ETE!
                      Blog: isazi's home
                      DMytroD Mister PYCM 3 Replies Last reply Reply Quote 2
                        Mister PYC Silver Members @isazi
                        @isazi
                        Humm humm …
                        Thinking to recover through the phone is banned approach.
                        phone should be preserve for urgency, moreover nothing says that you can use it to create a new road … when you are around 4000 m … your phone has no more any 5G, 4G … 3G …
                        May be a suggestion here.
                        In the navigation option, it could be nice to propose a new option to navigate to the START or END of an course. I understand as per yoru comments that they are not stored per say as POI but still they are stored in the watch, so could be interresting to offer a navigation to them;
                        In such case, no need to double your itinery by these 2 POI, which is what I did and allowed me to see that the navigation to the summit was giving me back distance, ETE, ETA information and also compass navigation
                        • DMytroD Offline
                          DMytro @isazi
                          @isazi this may be omitted by imposing a constraint. Let’s say a suggestion similar to battery mode switching pops up iff more than 1 km of route or longer than 30min off route. These are more or less random numbers and exact ones need to be determined upon testing.
                          isaziI 1 Reply Last reply Reply Quote 0
                            @isazi
                            Humm humm
                            I was thinking to this … but I trend to disagree.
                            It is not different that having you create a wrong route which will push you to these embush.
                            Moreover if clearly on the watch there is an angel which appears
                            Then SUUNTO cannot be taken for any responsibility here.
                            It was clearly an indication to help you, not a compulsary direction to follow.
                            It is the same when you drive your car, you can go to 250km/h but it is 1) forbidden 2) dangerous, still I do not know a single beautiful luxuray car where you cannot either accelerate like a hell"s angel or drive far above the limits …
                            • isaziI Offline
                              @дима-мельниченко the battery is pretty easy (one parameter) and not related to safety much (unless you are betting your life on your watch, navigating dangerous terrain with no visibility and relying only on your watch to survive).
                              Blog: isazi's home
                              • isaziI Offline
                                isazi Moderator @Mister PYC
                                @mister-pyc said in Is it a navigation BUG .. Distance/ETE/ETA remained empty despite I was not far from the itinery:
                                You are either the greatest lawyer or comedian ever.
                                Blog: isazi's home
                                  @isazi
                                  Is there a way ro rename this post into :
                                  ANGEL MODE Proposal when your wath detect you are out of the route
                                  it is definitively not a bug , now I catch the way the watch behave
                                  It’s more a possible missing feature.
                                  Sunday I was thinking it was a bug in my watch because I was surprise that the watch did not compute th einformation toward the ending of the route despite I was no more on it … for me it was just abecoming a computation between 2 gps point
                                  Still this disccussion is super interresting and should be renamed in somethign positive
                                  • isaziI Offline
                                    @isazi
                                    I cannot rename posts, you as the original author may, not sure. Although it may not be possible at all.
                                    Blog: isazi's home
                                    Mister PYCM 1 Reply Last reply Reply Quote 0
                                      @isazi
                                      I was looking for this but did not find the option … of course you start to know me and that I’m often blind 🙂
                                      I was thinking that you as moderator might have this super power 🙂
                                      Let me stil try to search for it
                                      Thanks in any case
                                      These discussions are super interresting as challenging us and get fun to think that there could be some features …
                                      • isaziI Offline
                                        @mister-pyc often forum/discussion systems do not have this function to avoid the situation in which you get lots of upvotes for a topic, then change the name to achieve a different goal. So it may be the case for this forum too.
                                        Blog: isazi's home
                                          @isazi
                                          very logical indeed
                                          Unfortunate as my title is not reflecting what I think now 🙂 and would like to suggest
                                          • Łukasz SzmigielŁ Offline
                                            Łukasz Szmigiel
                                            As I said before - automation is good but only if it’s really well designed and here it’s very, very risky as @isazi pointed out.
                                            I think that if you’re preparing for mountaineering having option A/B and C is crucial for survival and relying only on electronics, and especially on automated electronics sounds dangerous to me (but hey, I’m no.1 Deliberative in StrenghtsFinder, so I find dangers everywhere).
                                            I also think that design goes beyond what we see on screen. It needs to adapt to market needs and as we sadly know - people don’t read manuals and even as simple as S line is right now - there are lots of confusing things that either manual doesn’t cover well or most people won’t care anyway. Also - we’re talking about multisports watch, not a specialized tool just for one or two activities (as your ideas @Mister-PYC might be very well relevant for mountaineering).
                                            So - we have different battery modes (with a slightly malfunctioning ETA mode forcing 1s that I hope will be dealt with) and different navigation options - with POIs, routes and breadcrumbs all of which can be switched easily during the activity when needed - which I think is crucial as only the user knows when it’s best to use what.
                                            BTW. You can have like 255 POIs in watch I think? And their icons will be displayed in navigation screen (although without names) when in breadcrumb navigation mode - regardless if routes are enabled or not. This is awesome and if in future it’s possible for the names to be displayed (even short - like first 8 letters) it would be an amazing tool for navigation even without maps.
                                            S9PP 2.50.28
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
