    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Suunto 9 Peak (review and specs)
    Scheduled Pinned Locked Moved Suunto 9 Peak
    257 Posts 51 Posters 89.4k Views 50 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
      Dimitrios Kanellopoulos Community Manager @dulko79
      @dulko79 some time interval not every second. I dont know the specifics but it should be around 5-10mins. It does have somewhat a cleverness there. Also it will change this a bit in the future.
      But I dont think that OHR is the main drainage in battery on the s9P.
      Creator of quantified-self.io — a next gen training dashboard with MCP access, cross-service activity and route sync
      D 1 Reply Last reply Reply Quote 1
      • D Offline
        dulko79 @Dimitrios Kanellopoulos
        @dimitrios-kanellopoulos cleverness, like if you are sitting still at the desk working, then you get up and start walking. Peak then changes sampling rate for hr based on movement?
        App: beta
        Phone: Iphone
        iOS
        Dimitrios KanellopoulosD 1 Reply Last reply Reply Quote 0
          @dulko79 Unfortunately I dont know the specifics. What I do know is that atm there are a few features missing. For example “sensing” that the watch is not worn / tight (sensor skin contact). That should come asap.
          1 Reply Last reply Reply Quote 3
          • freeheelerF Offline
            freeheeler @Dimitrios Kanellopoulos
            brilliant 🙂 👌
            living sideways
            • Mff73M Offline
              Mff73
              Question about OTA that comes to me :
              If SA becomes the only way to upgrade S9P, and something went “wrong”, is there similar workaround like with Suuntolink drag’drop FW file? 🤔
              SSU (retired), SV1, SV2
              Wife : S9PP
              SA: Always the latest beta :)
              Android + Galaxy S205G
              isaziI Dimitrios KanellopoulosD 2 Replies Last reply Reply Quote 0
              • pilleusP Offline
                pilleus @Dimitrios Kanellopoulos
                @dimitrios-kanellopoulos said in Suunto 9 Peak (review and specs):
                I am now at 29% battery left
                YOU should be at 100 %! Life is short and every moment matters … 😊 🤙
                https://www.instagram.com/moves.are.life/
                Suunto Vertical Black Lime
                Suunto 9 Peak Pro Black
                Suunto Spartan Ultra Stealth Titanium
                • isaziI Offline
                  isazi Moderator @Mff73
                  @mff73 if something goes wrong while updating, the latest stable firmware that was on the watch is installed.
                  Blog: isazi's home
                    Dimitrios Kanellopoulos Community Manager @Mff73
                    @mff73 you always have the last FW in the watch to be able to revert.
                    You can actually reset the watch without SL
                    • ? Offline
                      A Former User @Dimitrios Kanellopoulos
                      @dimitrios-kanellopoulos Since you are appearing to be using the S9P as your daily driver, I have a few questions if I may:
                      • How does adaptive backlight works under DND? Currently S9B dims the screen during DND, is this preserved or the screen will be made dim regardless of DND if it’s dark and adaptive mode is used?
                      • What about sounds (beeping) during notifications? Anything done there? With S9B there’s no way to disable sound for notifications only. So, either you hear a beep every time a notification comes, or use DND that defies the purpose (and makes the screen dim in the process), or disable all sounds, which also carries over to activities
                      • I’m still seeing zombie notifications on 2.14.16 and the only way to cure it appears to be restarting the watch that resets Body Resources to 50%, which reminds me…
                      • Any improvements to Body Resources sometimes funky behavior? On 2.14.16 firmware, I had it drop from 91% to below 50% in two hours the watch was on the charger. Not cool. The other day Resources were about 20%, I went for 50 minutes weight lifting, and the value jumped to 45% 😰 Who knew some flies, curls, and cleans can supercharge you?
                      • Last but not least, are we getting S9B sleep tracking (awake/light/deep) or S7 more advanced phase analysis (awake/light/deep/REM)?
                      As always, thanks a lot for any insights.
                      Dimitrios KanellopoulosD 1 Reply Last reply Reply Quote 2
                        Dimitrios Kanellopoulos Community Manager @Guest
                        @nickk I have been using the s9p as my main watch for quite a few months. Since then I didn’t have any real issues with the device tbh.
                        • The DND shuts the standby adoptive backlight off. The adaptive standby backlight means that if the sun is shinning there is no backlight. When you wake the watch up, your current backlight setting is applied. Remember in Suuntos word there is backlight (like the normal lighting) and standby light (the very small light to just make it show the time during the night).
                        • There is no progress in SW there. Same stuff. That said I do know that the s9p “supports” more customizable vibras. Not in SW yet.
                        • Each time the watch goes on charger it resets the resources and pauses the recovery time. I am not sure why this is like so. Lets open the discussion. There are some issues with resources also tracked here and those are delegated to FB.
                        • IDk that. Suunto has a custom sleep tracking (in house) so I have literally no clue.
                        What helps is like with the S7 , Suunto listens to the demands of the consumers at launch and should pay attention to the “sentiment” demand. Good or bad? IDk. Logical sure imo.
                        S9P is a branch off the S9/S5/S3 line. New HW and new SW to cover the new HW. The rest move in Sync.
                        ? JorgeFDJ 3 Replies Last reply Reply Quote 2
                        • ? Offline
                          Gotcha.
                          Resources behavior with respect to charging/rebooting effectively means one should charge when Resources hit around 50%. Otherwise any OCD types like me gawking over data will be losing data points 😲 I think Garmin resets to 45% on reboot and guesstimates a discharge when it’s off your wrist based on I don’t know what… But it’s not as steep as what I’m seeing on S9B.
                          Would be nice if notification alerts could be made vibration-only, or sounds could be turned off for everything but activities.
                          Should I create a topic for that and let people vote? I think we already have “future firmware” discussion.
                          Dimitrios KanellopoulosD Brad_OlwinB 2 Replies Last reply Reply Quote 3
                          • ? Offline
                            So, you don’t sleep with S9P? And if you do, does it give you REM or just deep sleep? That’s basically a difference between S9 and S7. I thought sleep analysis was at least partially FB algos, no?
                              @nickk I sleep all the time with the s9P. That’s why I have DND. 😅
                              It shows exactly the same data s9b shows.
                              So no rem unfortunately. Only time awake and deep sleep.
                                @nickk let’s see how we can facilitate that.
                                • ? Offline
                                  That’s quite alright. Now we know Peak takes off after its bigger brother. So, it is indeed Suunto 9 first, and Peak second.
                                  I’m fine without REM given all existing watches’ sleep phase analysis is deeply flawed, no pun intended. Was just wondering…
                                  • W Offline
                                    wakarimasen Gold Members
                                    I’d be interested to hear how people ‘approach’ going to sleep, with sleep tracking in mind (I know it sounds like a really odd question). At the moment, my s9B seems to think I start sleeping between an hour and 90 minutes after I turn out the light, which I know to be incorrect. I’d worked out a way to get some reasonable results from my SSSWHR Baro, but using the same method doesn’t seem to be working here.
                                    By the way: I know the results are not exact, and I’m comfortable with that. If I can get into a routine that would make them a little more accurate, I’d just be a little happier 🙂
                                    Suunto Race Titanium
                                    Suunto Ambit3 Peak
                                    Polar H10
                                    Polar OH1
                                    • JorgeFDJ Offline
                                      JorgeFD @Dimitrios Kanellopoulos
                                      @dimitrios-kanellopoulos only one alarm still present in peak or newest firmware?
                                      ? 1 Reply Last reply Reply Quote 1
                                      • ? Offline
                                        A Former User @wakarimasen
                                        @wakarimasen Sadly, start of sleep being cutoff or extended into normal hours because you were reading, watching something, etc. is a sad fact of life. Other platforms, like Polar for example (you should know that based on previous ownership history 😊 ), have exact same problem.
                                        My only three life hacks…
                                        Make your sleep period as close to the real one as possible, i.e. if you actually fall asleep around 23:00, set your sleep start at 22:45, not 22:30 or 22:00…
                                        Try to move around a bit before calling it a day, you know brush your teeth last kind of thing… so any previous quiet period isn’t interpreted as the beginning of sleep and there’s a distinct change in activity levels.
                                        Maybe change on which hand you wear the watch for the night?
                                        W 1 Reply Last reply Reply Quote 0
                                        • ? Offline
                                          A Former User @JorgeFD
                                          @jorgefd78 From the videos I’ve seen, the interface looks exactly like S9/5/3, so I’d guess yes, one alarm and one timer.
                                          • W Offline
                                            wakarimasen Gold Members @Guest
                                            @nickk My experience with Polar watches has been really good - the Vantage V was pretty much spot-on all the time.
                                            It’s not the most important thing for me though, and indeed is only really some form of an estimation in the end.
                                            I’ll try your suggestions, and see if I can find a way. Thanks!
                                            Suunto Ambit3 Peak
                                            Polar H10
                                            Polar OH1
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
