    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Suunto 9 Peak (review and specs)
    Scheduled Pinned Locked Moved Suunto 9 Peak
    257 Posts 51 Posters 90.0k Views 50 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • surfboomerangS Offline
      surfboomerang @Bulkan
      @bulkan Maybe the scale is somewhat different, but I do see a similar pattern in both tops. I don’t think the data is diffent.
      Watching a little bit further at 9:35, I noticed the bug I reported here is solved in the S9 peak! The sun icon is now visible against a white background. Hope it comes to the S9B too.
      Suunto Vertical Titanium Solar
      OnePlus Nord 4
      Dimitrios KanellopoulosD BulkanB 2 Replies Last reply Reply Quote 1
        surfboomerang
        Can someone tell me what the green horizontal bar between the datafields is you see in the video? I have never seen it.
        Edit: Nevermind… I just found out about the “Target” setting. I never used it 😄
        OnePlus Nord 4
        inkognitoI 1 Reply Last reply Reply Quote 0
        • jthomiJ Offline
          jthomi Moderator Gold Members Silver Members
          Since there seems to be a bit confusion about the thickness, at least for me, can someone post a pic of a Suunto Spartan Sport without OHR in comparison to the new Suunto 9 Peak? That would be awesome… 😄
          pavel.samokhaP 1 Reply Last reply Reply Quote 0
            Dimitrios Kanellopoulos Community Manager @surfboomerang
            @surfboomerang if you talk about the sea level pressure that wont come to windsuf. We have turned off the sensor as wind etc can really mess it up
            Creator of quantified-self.io — a next gen training dashboard with MCP access, cross-service activity and route sync
            surfboomerangS 1 Reply Last reply Reply Quote 2
              surfboomerang @Dimitrios Kanellopoulos
              @dimitrios-kanellopoulos I was talking about the sun icon color of the weather widget, but good to know that pressure is not measured for the exact reason you mentioned. Does this also mean that altitude is no longer recorded for watersports? Because that metric was quite useless for those sports 😄
              OnePlus Nord 4
              Dimitrios KanellopoulosD 1 Reply Last reply Reply Quote 2
                @surfboomerang I am not sure if this applies to all water sports. But I would assume to most yes. I know there are a few misalignments here and there reported.
                  @dimitrios-kanellopoulos You’re right. Maybe it is interesting for downhill kayaking (or how is that sport called?)
                  OnePlus Nord 4
                  EgikaE 1 Reply Last reply Reply Quote 1
                  • inkognitoI Offline
                    inkognito Platinum Member @surfboomerang
                    @surfboomerang The green line between the data fields is the progress bar of your target distance/duration. I think this was implemented at least a year ago 🙂
                    Edit: damn, too late 😄
                    SV: fingers crossed :D
                    S9 (non-baro): died after 2 months, replaced, holding strong since 03/20
                    Spartan Trainer: casing broke after 23 months, repaired, lost watertightness 5 months later, died
                    Despite some pretty bad luck, I still love Suunto!
                      Dimitrios Kanellopoulos Community Manager @Bulkan
                      @bulkan this will become better
                      1 Reply Last reply Reply Quote 3
                        surfboomerang @inkognito
                        @inkognito Thanks anyway 😉
                        OnePlus Nord 4
                        • BulkanB Offline
                          Bulkan Moderator @surfboomerang
                          @surfboomerang is the same data and course. But looks like it will be improve.
                          Tu comunidad Suunto en Telegram: https://t.me/suuntocommunity (spanish)
                          isaziI 1 Reply Last reply Reply Quote 0
                          • isaziI Online
                            isazi Moderator @Bulkan
                            @bulkan yeah at the moment the alti profile on the Peak is a bit flattened, probably due to difference in screen size.
                            Blog: isazi's home
                            • EgikaE Offline
                              Egika Platinum Member @surfboomerang
                              @surfboomerang said in Suunto 9 Peak (review and specs):
                              White water kayaking. The problem there is you get a lot of water on the sensor, sometimes submerging it etc.
                              You still get a good idea of the altitude profile and that is the reason why it makes sense to keep altitude data for kayaking. This is the way it is 👍
                              Dimitrios KanellopoulosD isaziI freeheelerF 3 Replies Last reply Reply Quote 2
                                Dimitrios Kanellopoulos Community Manager @Egika
                                @egika I have to check with the S9P sensor and water. To me it looks it works better as the sensor doesn’t get water stuck in
                                • isaziI Online
                                  isazi Moderator @Egika
                                  @egika yes, what I would do is similar to what already happens with other sports such as MTB, where you have different specializations. When choosing Kayaking I would like to have two profiles: flat water, white water.
                                  Blog: isazi's home
                                  • EgikaE Offline
                                    Egika Platinum Member @Dimitrios Kanellopoulos
                                    @dimitrios-kanellopoulos the screenshot above is from S9 - i am happy with this given the challenging conditions
                                    @isazi : good idea 🙂
                                    • freeheelerF Offline
                                      freeheeler @Egika
                                      @egika
                                      for white water kayaking uphills could be filtered and maybe there’s a reasonable algorithm to detect submerging the watch: unless you take a huge waterfall drop, there’s no reason to suddenly rise the pressure.
                                      Maybe it sounds a bit ignorant as rivers follow a certain topography and I bet some kayakers would like to record this, too… but what if only start and end alti is recorded and delta is the descent?
                                      living sideways
                                      Dimitrios KanellopoulosD 1 Reply Last reply Reply Quote 0
                                        Dimitrios Kanellopoulos Community Manager @freeheeler
                                        @freeheeler said in Suunto 9 Peak (review and specs):
                                        we do do that. But water sticks and influsences
                                        freeheelerF 1 Reply Last reply Reply Quote 2
                                          Last update and charge of the watch was 6 days exactly ago, the morning of 26th May.
                                          • All on (24/7 tracking etc) except notifications. Standbylight always on, on adoptive mode. No raise to wake as it’s not needed for this config.
                                          • White watchface
                                          • 4h of GPS with Gallileo (consumes more than GPS only)
                                          • 2 FW update on the 26th and 28th of the month (transfer FW via BT + install )
                                          • Several checks on the watch and playing around for pics etc
                                          • DND from 22pm to 8am
                                          • Several pairings with SA due to development
                                          I am now at 29% battery left 🙂
                                          I suppose its good.
                                          D pilleusP ? 3 Replies Last reply Reply Quote 8
                                          • D Offline
                                            dulko79 @Dimitrios Kanellopoulos
                                            @dimitrios-kanellopoulos how often does sensor check daily heart rate, every second or within certain time interval?
                                            App: beta
                                            Phone: Iphone
                                            iOS
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
