    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Suunto 9 Peak
    Scheduled Pinned Locked Moved Suunto 9 Peak
    875 Posts 103 Posters 373.5k Views 95 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • ? Offline
      A Former User @Guest
      @kk2n-kk said in Suunto 9 Peak:
      @andré-faria hmm… Structured training from Nolio?
      Yes, it is what is says in the comment.
      If so it seems suunto is taking time to develop the structured workout but at least it will be compatible with various platforms (tp, nolio).
      ? 1 Reply Last reply Reply Quote 1
      • ? Offline
        @andré-faria Thanks a lot… i guess my french language knowledge has not rusted that bad 🙂
        • W Offline
          wotus Bronze Member @Dimitrios Kanellopoulos
          @dimitrios-kanellopoulos said in Suunto 9 Peak:
          @mff73 yes but mind the activity capacity.
          Some people abuse this function to record like 200h of data. The watch can hold up to ~50h of 1s data (belt pods etc).
          I currently have about 78 hours of training data with 1s gps data and until now no unit has been overwritten in the logbook.
          It seems that the memory is enough for more than 50h 1s of gps data.
          W 1 Reply Last reply Reply Quote 3
          • U Offline
            uranfl
            Is it normal that field for burned calories counts on even when recording activity (Trekking) is on pause?
            isaziI 1 Reply Last reply Reply Quote 0
            • isaziI Offline
              isazi Moderator @uranfl
              @uranfl the watch keeps tracking your HR also during a pause. Actually it keeps tracking GPS and altitude too.
              Blog: isazi's home
              surfboomerangS U 2 Replies Last reply Reply Quote 0
              • surfboomerangS Offline
                surfboomerang @isazi
                @isazi 😮 I always thought it stopped GPS tracking and thus saving battery. But it isn’t?
                If I recall correctly, this was the case on the Ambit series.
                Suunto Vertical Titanium Solar
                OnePlus Nord 4
                Dimitrios KanellopoulosD 1 Reply Last reply Reply Quote 0
                  Dimitrios Kanellopoulos Community Manager @surfboomerang
                  @surfboomerang if it drops gps then it will take again time to find it
                  Creator of quantified-self.io — a next gen training dashboard with MCP access, cross-service activity and route sync
                  • U Offline
                    uranfl @isazi
                    @isazi that is understandable, but when you pause activity the watch should stop counting burned calories
                    • isaziI Offline
                      @uranfl well, you are alive and breathing, why should it stop? 🙂
                      Blog: isazi's home
                      U 1 Reply Last reply Reply Quote 3
                      • U Offline
                        uranfl @isazi
                        @isazi that’s different logic than in A3P which I am used to. It sounds more reasonable to count burned calories while exercising (moveing) than during 2 hour rest on the summit…
                        sartoricS 1 Reply Last reply Reply Quote 0
                        • sartoricS Offline
                          sartoric Moderator @uranfl
                          @uranfl
                          Activities calories count includes also basal calories, because are calories actually burned during the exercise.
                          If you need to recovery it, you need to know you’ve burned it 🙂
                          SVTS - 2.50.28
                          SSSWHR BARO Amber - 2.8.32
                          Samsung A5 2016 - Android 7.0
                          Suunto App Android 6.11.12 beta
                          U 1 Reply Last reply Reply Quote 0
                          • U Offline
                            uranfl @sartoric
                            @sartoric Thank you all for the explanation! You almost convinced me 🙂
                              Dimitrios Kanellopoulos Community Manager @uranfl
                              @uranfl during pause all calcs are stopped but the hr is still there. That’s all.
                              • ? Offline
                                A Former User @Dimitrios Kanellopoulos
                                @dimitrios-kanellopoulos Think recovery time counts up during pause. Is that expected regular behavior?
                                  Dimitrios Kanellopoulos Community Manager @Guest
                                  @mountainchris no it doesnt
                                  • ? Offline
                                    @dimitrios-kanellopoulos than it is new in sw. I noticed it 2 months ago. I ran two hours. At the end with higher hr so that hr was in the beginning of the pause a little a. I also have a data field for recovery time, which I can’t see in pause. The pause at the end was 10 min and after the pause the data field was definitely higher. So it counted up. Usually there is no noticeable count if hr in pause is low, so no recovery is needed. If you do longer workouts with higher hr the pause hr can be high and then count in data field is seen after pause… behavior ob S9B. I think correctly there shouldn’t be a count in pause.
                                    • ? Offline
                                      @Dimitrios-Kanellopoulos tried it today again. S9B is counting up recovery time during pause. Can be easily reproduced with harder workouts and recovery data field. Just take a pause after workout for 10-15 min and check data field before / after pause.
                                      • ? Offline
                                        A Former User
                                        Btw when can I buy S9P? Always sold out 😭
                                        • isaziI Offline
                                          isazi Moderator @Guest
                                          @mountainchris if you leave your email on the website you’ll get an email with a link, usually pretty fast.
                                          Blog: isazi's home
                                          • paataP Offline
                                            paata Bronze Member
                                            Hi, I have a question… Is resolved stuck while saving activity in suunto 9 peak? I have SSU and this issue is very annoying (feeling option on doesn’t help). Because of this, i’m thinking about upgrade to S9P.
                                            ? EfejotaE 2 Replies Last reply Reply Quote 0
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
