    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Suunto 9 Peak
    Scheduled Pinned Locked Moved Suunto 9 Peak
    875 Posts 103 Posters 366.6k Views 95 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • ? Offline
      A Former User @isazi
      @isazi said in Suunto 9 Peak:
      @andré-faria swipe to go back to the watch face.
      @дима-мельниченко said in Suunto 9 Peak:
      @andré-faria you could hold down the middle button to quickly return to main screen.
      Thank you guys, I didn’t know of this tricks.
      Although they solved the “issue”, I think it would be more natural to just continue moving the menu (and maybe less complicated to implement).
      Dimitrios KanellopoulosD 1 Reply Last reply Reply Quote 3
        Dimitrios Kanellopoulos Community Manager @Guest
        @andré-faria long hold the menu to go back from some places as well
        Creator of quantified-self.io - sync Garmin and COROS activities to Suunto, import Suunto routes, deliver Suunto routes to Garmin courses, and analyze training data in one private dashboard.
        lexterm77L 1 Reply Last reply Reply Quote 0
        • lexterm77L Offline
          lexterm77 Bronze Member @Dimitrios Kanellopoulos
          I set intervals 12x(30s int + 15s rec) it is same problem as baro, when you finish interval and reset and press start again it stays at start interval screen until first interval expires. Not that is a big bug but sort of annoying.
          isaziI 1 Reply Last reply Reply Quote 0
          • isaziI Offline
            isazi Moderator @lexterm77
            @lexterm77 using Suunto+ also?
            Blog: isazi's home
              lexterm77 Bronze Member @isazi
              S Plus Weather Insight, Itensity zone set for power, no itensity target set, Target: distance.
              I rememered same type of interval on May 21st on Baro, press start, shows interval 1 on screen, then instead of going to interval screen goes back to start screen where shows start pointed at start button but it actually starts counting. If you just keep going it eventually returns to interval screen.
              isaziI Dimitrios KanellopoulosD 2 Replies Last reply Reply Quote 0
              • isaziI Offline
                @lexterm77 I think this bug is already known, not sure if the issue is S+ now. I’ll check and get back to you.
                Blog: isazi's home
                  Dimitrios Kanellopoulos Community Manager @lexterm77
                  @lexterm77 could you try without s+?
                    @dimitrios-kanellopoulos
                    I can try without s+, on first interval is fine, it is when you reset interval and do a second one, and a third one. I can try again tonight on my easy trail run.
                    isaziI 1 Reply Last reply Reply Quote 1
                    • isaziI Offline
                      @lexterm77 so the issue should be the S+ now, and it is known to Suunto (so we hope in a fix).
                      Blog: isazi's home
                        @isazi
                        I tried same without S+ There were no problems this time.
                        • B Offline
                          bnorthrop
                          Question for anyone who has the titanium 9 Peak. The body of the watch is brushed titanium but the thin top rim around the watch face looks like polished titanium. I’ve now had my S9P for about 1.5 weeks and in just the past couple days I’ve noticed that one side of that top thin rim is scratched. It’s easy to tell the difference because the rest of the rim is very nicely polished.
                          What I’m not sure about is whether the watch actually came like this (like a manufacturing defect) and I simply didn’t notice until now, or whether the polished rim actually scratches pretty easy.
                          Have any of you with the titanium version noticed this polished rim getting scratched/scuffed already? Or is it likely that mine came this way any it was scuffed from the start? Thanks!
                          • Brad_OlwinB Online
                            Brad_Olwin Moderator @bnorthrop
                            @bnorthrop It does scratch easily, my test version was scratched quite a bit and so is the one I purchased. It doesn’t bother me much, they are not that easy to see.
                            Vector/T6c/Vertical 2 Ti
                            • B Offline
                              bnorthrop @Brad_Olwin
                              @brad_olwin Thanks for sharing your experience. I’m not that bothered as long as the screen doesn’t also scratch, which I suspect (or at least hope) won’t happen nearly as easily.
                              Plus, I assume at some point the thin polished rim will be scratched enough it’ll just match the brushed look of the sides of the case 😁
                              ? 1 Reply Last reply Reply Quote 1
                              • ? Offline
                                A Former User @bnorthrop
                                Full review of ray
                                https://www.dcrainmaker.com/2021/07/suunto-9-peak-gps-watch-in-depth-review.html
                                ? 1 Reply Last reply Reply Quote 4
                                • ? Offline
                                  A Former User @Guest
                                  @andré-faria I think this is the nicest Suunto review I’ve seen from Ray in the past 5 years I’ve been closely reading him.
                                  Aleksander HA 1 Reply Last reply Reply Quote 8
                                  • Aleksander HA Offline
                                    Aleksander H Bronze Member @Guest
                                    @nickk said in Suunto 9 Peak:
                                    I think the Suunto Spartan Sport was the last one to get a review as positiv as this from him.
                                    • ? Offline
                                      A Former User @Aleksander H
                                      https://www.youtube.com/watch?v=BR6LH2JOwbM
                                      Chase the summit also release his review.
                                        @andré-faria he uses qs
                                        • ? Offline
                                          A Former User @Dimitrios Kanellopoulos
                                          Another review, but in french, with an interesting comment!
                                          Nolio for those who don’t know. Interesting!
                                          • ? Offline
                                            @andré-faria hmm… Structured training from Nolio?
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
