    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    GPS problems with my S9B
    90 Posts 12 Posters 16.6k Views 11 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • sartoricS Offline
      sartoric Moderator @basetta79
      @basetta79
      It could be … Or not 😁
      Which icon are you referring to?
      I have the same phone (not the same watch) and I never faced such an issue
      SVTS - 2.50.28
      SSSWHR BARO Amber - 2.8.32
      Samsung A5 2016 - Android 7.0
      Suunto App Android 6.10.7 beta
      B 1 Reply Last reply Reply Quote 1
      • B Offline
        basetta79 @sartoric
        This icon is usually white during syncronization; this afternoon was blue and no icon on the watch.
        Before the 9B I had a SSU, same phone, zero problems.
        isaziI 1 Reply Last reply Reply Quote 0
        • isaziI Offline
          isazi Moderator @basetta79
          @basetta79 is that icon with a nuclear symbol on a battery some power saver? May be killing the Suunto app in the background?
          Blog: isazi's home
          B 1 Reply Last reply Reply Quote 0
          • B Offline
            basetta79 @isazi
            @isazi uh, never realized. I will switch it off
            • isaziI Offline
              @basetta79 I don’t have any power saving app, but I configure Android to not optimize SA battery and leave it run in the background as much as it wants. It helps with keeping the watch always synced without the need to open the app.
              Blog: isazi's home
              • B Offline
                basetta79 @isazi
                @isazi said in GPS problems with my S9B:
                I see. It is very strange to me checking all these features; with the Spartan Ultra life was easier 😞
                • tuxellaT Offline
                  tuxella Bronze Member @basetta79
                  @dimitrios-kanellopoulos said in GPS problems with my S9B:
                  Specifically you started with only 6 visible sats (8-12 is good ).
                  I couldn’t find any way to find this info in the GPX or FIT files exported from the Suunto App.
                  @Dimitrios-Kanellopoulos could you tell us how to check the number of satellites seen by the watch?
                  Thank you.
                  Dimitrios KanellopoulosD 1 Reply Last reply Reply Quote 0
                    Dimitrios Kanellopoulos Community Manager @tuxella
                    @tuxella I request the raw data of the watch. Those data are only available to me if you share the activity.
                    Unfortunately those data are not available to end users for many reasons but I can help here when needed.
                    (There are some hacks though if you use Android to check that data as they are stored in the filesystem of Android)
                    Creator of quantified-self.io a portal that allows you to analyze your data from various providers, upload fit activity files to Suunto app, gpx routes and more…
                    tuxellaT 1 Reply Last reply Reply Quote 1
                    • tuxellaT Offline
                      tuxella Bronze Member @Dimitrios Kanellopoulos
                      @dimitrios-kanellopoulos Thank you for the quick answer.
                      I use an iPhone, so no luck for me I guess.
                      (If I remember correctly, the number of satellites (or a “reception quality” score) was also available in the files stored by an older version of SuuntoLink for the Ambit.)
                        @tuxella correct but not sure if that happens anymore
                        A 1 Reply Last reply Reply Quote 1
                        • A Offline
                          asorli @Dimitrios Kanellopoulos
                          I had same issue with GPS track with S9B. I did watch reset as Suunto support suggests. Unfortunately with no luck. Issue persists.
                          https://www.suunto.com/en-gb/move/andrejorli/60313cce67a20b5c3bcf3e3a
                          https://www.suunto.com/en-gb/move/andrejorli/5ffad6816a37bb349f1ed779
                          https://www.suunto.com/en-gb/move/andrejorli/6070820b9761a9481e7c19d1
                          Any suggestions?
                          surfboomerangS 1 Reply Last reply Reply Quote 0
                          • surfboomerangS Offline
                            surfboomerang @asorli
                            @asorli Do you use GPS+QZSS only or in combination?
                            Looks like a steep area so probably a big challenge for GPS devices to aquire enough satellites.
                            Suunto Vertical Titanium Solar
                            OnePlus Nord 4
                            • A Offline
                              asorli
                              @surfboomerang After reset I did test runs with all GPS setup combinations.
                              I found best results with GPS+QZSS only.
                              I know it’s quite callenging terrain for gps reception but with SSWHR I never had such bad tracks on this route.
                              surfboomerangS Dimitrios KanellopoulosD 2 Replies Last reply Reply Quote 0
                                @asorli My guess would be: More is better…
                                Probably more change on a good fix if you combine with GALILEO or GLONASS
                                OnePlus Nord 4
                                  Dimitrios Kanellopoulos Community Manager @asorli
                                  @asorli does the watch notify you of GPS lost?
                                  A 2 Replies Last reply Reply Quote 0
                                  • A Offline
                                    There was no notification of GPS lost.
                                    I pay attention during activity on pace displayed. When GPS “lost” occoured displayed pace variate ±2 min/km.
                                    Support case 04031406 is opened.
                                    • A Offline
                                      @dimitrios-kanellopoulos Is it possible issue is related to activity type? Today’s cycling ride track on the same route is amazing.
                                      https://www.suunto.com/en-gb/move/andrejorli/6081a7a0916af10f0fcfa35e
                                      Brad_OlwinB Dimitrios KanellopoulosD 2 Replies Last reply Reply Quote 0
                                      • Brad_OlwinB Offline
                                        Brad_Olwin Moderator @asorli
                                        @asorli I have run in places with steep canyon walls and deep forest where I have lost GPS signal, it only happens for a short time and looks nothing like this. I use GPS only and no other satellites. Something seems to be going on here, especially since your cycling track looks good.
                                        Vector/T6c/Vertical 2 Ti
                                          @asorli there is something very fishy. Idk what. Because there is a huge blocking gps lost notification that should pop up.
                                          I want you Todo this.
                                          Next time it looses gps , after you sync, please press send logs.
                                          Give me the time the logs where s ent and the username / email in pm
                                          A 1 Reply Last reply Reply Quote 0
                                          • A Offline
                                            @dimitrios-kanellopoulos Thank you. I’ll do that.
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
