    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    GPS problems with my S9B
    90 Posts 12 Posters 15.7k Views 11 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • B Offline
      basetta79
      Hello everyone,
      My beloved S9Baro the last week started to follow badly the gps signal. It hooks and unhooks from the satellites while I am running. No messages pop up on the display about the disengage. I used to run with GPS+beidou satellites and I tried to change to just GPS but nothing changed.IThe 9B is with the latest firmware release. What can I do? Did someone experience this issue? In attachment a screen in which I highlighted the problems.
      isaziI Dimitrios KanellopoulosD 2 Replies Last reply Reply Quote 0
      • isaziI Offline
        isazi Moderator @basetta79
        @basetta79 is AGPS updated?
        Blog: isazi's home
        B 1 Reply Last reply Reply Quote 2
        • surfboomerangS Offline
          surfboomerang
          If this is only one time, it could be just a bad GPS day. Try a soft reset and sync with SA to update AGPS data as @isazi suggested.
          If this problem persists over more activities in the future a better analysis is needed.
          Suunto Vertical Titanium Solar
          OnePlus Nord 4
          1 Reply Last reply Reply Quote 3
          • B Offline
            basetta79 @isazi
            @isazi said in GPS problems with my S9B:
            Think so but I will check. Do you think the app update can affect the precision of the watch? Thank you for your help
            sartoricS isaziI 2 Replies Last reply Reply Quote 0
            • sartoricS Offline
              sartoric Moderator @basetta79
              @basetta79 said in GPS problems with my S9B:
              AGPS data are used by the watch not by the App itself
              SVTS - 2.50.28
              SSSWHR BARO Amber - 2.8.32
              Samsung A5 2016 - Android 7.0
              Suunto App Android 6.8.9 beta
              B 1 Reply Last reply Reply Quote 1
              • B Offline
                basetta79 @sartoric
                @sartoric said in GPS problems with my S9B:
                Thank you
                • isaziI Offline
                  @basetta79 tell us the date of your AGPS update if you can.
                  Blog: isazi's home
                  • B Offline
                    basetta79 @isazi
                    @isazi ok, I’ve just checked and I found out it wasn’t updated.
                    Now I downloaded the latest version from Play Store: it’s the 4.38.1
                    So strange it didn’t download automatically (as for all the apps).
                    isaziI 1 Reply Last reply Reply Quote 0
                    • isaziI Offline
                      @basetta79 okay that is the app version. On your watch go to “Settings” -> “General” -> “About” and look for “Assisted GPS”.
                      Edit: if you watch is in Italian it should still be something similar to that.
                      Blog: isazi's home
                      • B Offline
                        basetta79 @isazi
                        On my watch I synced this morning before the run I post in screenshot.
                        On my watch the sw is 2.14.12
                        Assisted gps 2021-04-18T00:00:00Z
                        • isaziI Offline
                          @basetta79 the AGPS is updated (at least it is now), if it happens again can you check right after the activity if the APGS is updated or not?
                          Blog: isazi's home
                          B 1 Reply Last reply Reply Quote 0
                          • B Offline
                            basetta79 @isazi
                            @isazi sure!
                            • isaziI Offline
                              @basetta79 when you start the activity, does it take long for the GPS icon to become green?
                              Blog: isazi's home
                              • B Offline
                                basetta79 @isazi
                                @isazi today 1-2 minute. Yesterday when I realized I was off with gps, I stopped and finished the activity. Then I immediately started another one but the search for gps has been long. When back at home, I couldn’t sync with the app. I had to un pair the watch then pair it newly and it worked.
                                Edit: I was using navigation with an imported route
                                isaziI 1 Reply Last reply Reply Quote 1
                                • isaziI Offline
                                  @basetta79 long time for a GPS fix is consistent with missing AGPS.
                                  Blog: isazi's home
                                  B sartoricS 2 Replies Last reply Reply Quote 1
                                  • B Offline
                                    basetta79 @isazi
                                    @isazi and what can I do in that case? Is this something I can fix without sending the watch to official assistance?
                                    freeheelerF 1 Reply Last reply Reply Quote 2
                                    • sartoricS Offline
                                      sartoric Moderator @isazi
                                      I had some issues with slow fix too a couple of days ago.
                                      So maybe there was some problem in the file data
                                      SVTS - 2.50.28
                                      • freeheelerF Offline
                                        freeheeler @basetta79
                                        @basetta79
                                        just make sure your watch completely synces to SA before an activity. the agps file gets synced with the watch-phone connection 👍
                                        I’ve had bad agps and also in general bad recording days, too. they are very rare IMHO
                                        living sideways
                                        • B Offline
                                          basetta79 @freeheeler
                                          @freeheeler ok. This morning the agps were synced to the app before the run but the result was awful (BUT the SA wasn’t updated). Tomorrow I will retry…
                                          • isaziI Offline
                                            @basetta79 if you sync AGPS do it more than 15 minutes before you start the activity. Unpacking and making the files available takes time, so if you sync a new AGPS and then start immediately it is not available.
                                            Blog: isazi's home
                                            B freeheelerF ? 3 Replies Last reply Reply Quote 1
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
