    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Suunto 9 Failed to update, reset, send logs
    14 Posts 5 Posters 1.2k Views 5 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • Crispy ChrisC Offline
      Crispy Chris
      Hey!
      I can’t update my Suunto 9, it shows (“Failed to check for updates. Please check your internet connection and try again.”) neither can I reset the watch or send logs.
      I’m on 2.12.30, and SuuntoLink is 3.5.2.
      Net works ok, Bitdefender show no Suunto apps blocked.
      I’ve searched through forum and found there’s a way of manually update firmware, but no entry for bare Suunto 9 - only BARO.
      12sec button reset did nothing else but reset, problem continues.
      Any help appreciated.
      Thanks in advance.
      suzzloS 1 Reply Last reply Reply Quote 0
      • suzzloS Offline
        suzzlo Moderator @Crispy Chris
        @crispy-chris try to update manually. Search in the forum to fing info
        BR
        Suunto: Race, S9Peak, Spartan Sport Wrist
        Garmin: FR745, Edge 530
        SA topics:
        • Guides - https://forum.suunto.com/tags/guides
        Crispy ChrisC 1 Reply Last reply Reply Quote 0
          Crispy Chris @suzzlo
          @suzzlo Easier said than done, most of them are for Suunto 9 BARO, mine is Suunto 9 without barometer.
          • suzzloS Offline
            Hi S9 owners ( @Brad_Olwin , @Bulkan @isazi …)
            Do you know which is the latest firmware file for a S9 NOT BARO. Is this the correct one http://firmware.geo.movescount.com/production/Ibiza-fw_2.14.12.3833-F.zip ?
            /cc @crispy-chris
            SA topics:
            • Brad_OlwinB Offline
              Brad_Olwin Moderator @suzzlo
              @suzzlo said in Suunto 9 Failed to update, reset, send logs:
              /cc @crispy-chris
              No, Ibiza is the baro model. The firmware for non baro is Lima!
              Vector/T6c/Vertical 2 Ti
                Crispy Chris
                Ok, so what should I search for.
                http://firmware.geo.movescount.com/production/Lima-fw_2.14.12.3833-F.zip ?
                Any guess what’s the number after update version? 3833-F looks like S9 BARO reserved.
                Dimitrios KanellopoulosD 1 Reply Last reply Reply Quote 0
                  Dimitrios Kanellopoulos Community Manager @Crispy Chris
                  @crispy-chris “https://firmware.geo.movescount.com/production/Lima-fw_2.14.12.3836-F.zip”,
                  Creator of quantified-self.io — a next gen training dashboard with MCP access, cross-service activity and route sync
                    Crispy Chris @Dimitrios Kanellopoulos
                    @dimitrios-kanellopoulos It works! Over 5min update, but now it’s up to date. Thank You very much for help! 😊 👍
                    Dimitrios KanellopoulosD 1 Reply Last reply Reply Quote 3
                      @crispy-chris could you please press send logs and pass me back the id ?
                      Crispy ChrisC 2 Replies Last reply Reply Quote 1
                        @dimitrios-kanellopoulos “Failed to send logs, please try again later” 🙄
                        isaziI 1 Reply Last reply Reply Quote 0
                          @dimitrios-kanellopoulos I could send You logs right from SuuntoLink dir.
                          suuntoapp.1.log include all update installation info.
                          • isaziI Offline
                            isazi Moderator @Crispy Chris
                            @crispy-chris seems your SuuntoLink cannot access internet🤔
                            Blog: isazi's home
                            • suzzloS Offline
                              suzzlo Moderator @isazi
                              @Crispy-Chris @isazi are you using a connection behind a proxy?
                              SA topics:
                                @suzzlo No, I’m not. It’s just a net from a mobile provider T-Mobile, so it’s like using net through sim on phone.
                                Every other connections works ok, Bitdefender in-out for SuuntoLink and Update.exe also enabled.
                                And it did worked earlier pretty good.
                                Register Login
                                • First post
                                  Last post
                                Suunto Terms | Privacy Policy
