    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Running in a tunnel caused issues in the total distance computation
    59 Posts 11 Posters 12.9k Views 12 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • tuxellaT Offline
      tuxella Bronze Member
      Hello,
      I ran a couple of times in a tunnel with my watch (S9 Baro) and it caused the total distance to be very off (so wrong that strava flagged it).
      Here are the activities, on strava and QS :
      30/03/2021:
      • https://www.strava.com/activities/5036520007
      • https://quantified-self.io/user/JbyRpWWlliUl8tBDkpWbbh73h5B2/event/975238d06e48341364aafa086da3180a5ace4ffacc918480990f8492635200b7
      09/03/2021:
      • https://www.strava.com/activities/4917350585
      • https://quantified-self.io/user/JbyRpWWlliUl8tBDkpWbbh73h5B2/event/d2cdf19fe7f26908a7604e0d1739699ad5a76daafde081534e03d47b537dd5a5
      When looking at the GPX file and re-computing actual distance between points, the distance is ok (7.74 km, when the friend I ran with measured 7.72 with his watch).
      My current working theory is that the step length remembered by the watch is too long.
      How can I re-calibrate this length? (The track of the 30/03 was done after the firmware update, so after a soft reset AFAIK)
      Dimitrios KanellopoulosD sky-runnerS 2 Replies Last reply Reply Quote 0
        Dimitrios Kanellopoulos Community Manager @tuxella
        @tuxella the recalibration happens a the time with gps based workouts.
        If you run in a tunnel that is straight then the GNSS distance from gpx recalculation (or check it on qs) will be ok and right. If the watch reports more it indeed does not use so we’ll the fused speed or you look many times at your watch.
        Creator of quantified-self.io — a next gen training dashboard with MCP access, cross-service activity and route sync
        • tuxellaT Offline
          The tunnel more or less follows the yellow line bellow, which I think is pretty straight.
          8032bf03-bb3a-48ed-a694-9f0f4033ecd4-Untitled.png /var/folders/8t/5y2nkcwj2bs623k4l75359xm0000gn/T/com.sindresorhus.Shareful.Copy/87060D8D-1FCC-4BA8-85E8-408B62B00074/Untitled.png
          See also the openstreetmap routing: f6e5664b-dad6-4de2-b732-c87d7f383794-image.png
          https://www.openstreetmap.org/directions?engine=graphhopper_foot&route=48.85891%2C2.33983%3B48.86052%2C2.33101#map=17/48.86011/2.33463
          I don’t think I looked at my watch more than once or twice under the tunnel (which is ~700m long). The cadence and speed reported on points while I was under the tunnel look ok to me in QS.
          Can I do anything to help the watch (using fusedtrack or not) for my next run?
          • sky-runnerS Offline
            sky-runner Platinum Member @tuxella
            @tuxella I suspect the watch may be double counting the tunnel distance in this case - the first time from accelerometer and the second time from GPS when it reacquures the GPS signal. The easiest way is to download the FIT file and inspect the distance over time in it, and see if there are any sharp jumps in the distance. In my experience Ambit3 had exactly the same issue, which I observed several times.
            Suunto: Ambit, Ambit 3 Peak, 9 Baro, Race S, Race Ti, Vertical 2 Ti
            Garmin: Forerunner 210, Forerunner 610, Fenix 6X, Fenix 7X Ti
            Dimitrios KanellopoulosD 1 Reply Last reply Reply Quote 0
              Dimitrios Kanellopoulos Community Manager @sky-runner
              @sky-runner we have fixed this issue quite some fw before.
              tuxellaT 1 Reply Last reply Reply Quote 0
              • tuxellaT Offline
                tuxella Bronze Member @Dimitrios Kanellopoulos
                This “double counting” theory could explain the results I get.
                I analysed the data in the Suunto fit file from the 30/03/2021 :
                The first time in the tunnel (difference between the first and the last point without coordinates):
                • Distance: 0.87 km
                • Time: 4:15
                • Speed: 12.28 km/h
                On the way back (in the same tunnel):
                • Distance: 0.88 km
                • Time: 4:19
                • Speed 12.23 km/h
                If I add these distances to the distance calculated from GPS coordinates of each point:
                7.74 + 0.87 + 0.88 = 9.49km
                Where the total distance in the fit file (and reported in Suunto App, QS, Runalyze, Strava…) is 9.58 km
                  @tuxella can you make the links of qs public ? You can easily see if it’s that bug which was fixed
                  Currently I cannot open those links
                  • tuxellaT Offline
                    @dimitrios-kanellopoulos They should be public now
                      @tuxella are you using a pod ?
                      • tuxellaT Offline
                        @dimitrios-kanellopoulos No, this activity was done with just a Suunto S9 and the HR belt
                          @tuxella I’ll take a better look when I am on my pc.
                          I do see the issue.
                          tuxellaT 2 Replies Last reply Reply Quote 2
                          • tuxellaT Offline
                            @dimitrios-kanellopoulos Cool 🙂
                            Have a nice week-end
                            D 1 Reply Last reply Reply Quote 1
                            • D Offline
                              ddausw @tuxella
                              @tuxella
                              I have the same problem with the s9b after the last FW update. The tunnel length is counted twice. I tested with Glonass as well as Galileo.
                              Dieter
                              • MiniForkliftM Offline
                                MiniForklift Platinum Member
                                Nice pace! Just gave you kudos
                                SV Titanium Solar Forest
                                tuxellaT 1 Reply Last reply Reply Quote 2
                                • tuxellaT Offline
                                  tuxella Bronze Member @MiniForklift
                                  @miniforklift Thanks 🙂
                                  • tuxellaT Offline
                                    @dimitrios-kanellopoulos Hello
                                    did you have the opportunity to check on this?
                                    Dimitrios KanellopoulosD 2 Replies Last reply Reply Quote 0
                                      @tuxella I reported a bug or the watch guys.I think this new FW re introduced the issue
                                      tuxellaT 2 Replies Last reply Reply Quote 1
                                        @tuxella I would like some suunto app links
                                        • tuxellaT Offline
                                          For the 30/03/2021: https://www.suunto.com/fr-fr/move/thomas430851/606310cf949ba71fa290dc8a
                                          For the 09/03/2021: https://www.suunto.com/fr-fr/move/thomas430851/60476ac697a7b66e0c4c5d8a
                                          • tuxellaT Offline
                                            @dimitrios-kanellopoulos I had this issue twice: on the 30/03 and on the 09/03.
                                            On the 09/03 I wasn’t using the “new firmware” (which was released on the 30/03 AFAIK)
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
