    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Turn-by-turn navigation in S9 series with Plotaroute
    30 Posts 12 Posters 3.7k Views 10 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • ? Offline
      A Former User @markytarky
      @markytarky just a newbie question what’s the difference between this and classic GPX you follow ?
      I’m interesting if it’s help to be more precise when you have many small path to follow.
      markytarkyM 1 Reply Last reply Reply Quote 0
      • markytarkyM Offline
        markytarky Silver Members @Guest
        @g287-sf well, here the plotaroute creates a waypoint on each turn a norifies you twice to make a turn. Once after you pass a WP (it tells you how far the next turn is plus the direction e.g. sharp right or keep left, etc.) and second when you reach the WP. That’s it. No other differences.
        Instagram
        Watch: S9B customized, S9P all black
        Suunto App: iOS beta
        • M Offline
          Mike H. @omunoz
          Hello.
          Is Kamoot and Plotaroute the only choices to plan and upload to S9 turn by turn navigation? Do you know other possibilities?
          By the way. Visual indicator would be very useful.
          Suunto 9 Baro
          Suunto app beta at Android 11
          Derrick SpaffordD Mff73M 2 Replies Last reply Reply Quote 0
          • Derrick SpaffordD Offline
            Derrick Spafford @Mike H.
            So a quick question that I asked in another thread… turn by turn does NOT work on trail routes created but only on roads?
            isaziI 1 Reply Last reply Reply Quote 0
            • Mff73M Offline
              Mff73 @Mike H.
              @mike-h said in Turn-by-turn navigation in S9 series with Plotaroute:
              Hello.
              All apps or Web services that enable to create routes gpx files including turn indications with WPs naming may work.
              I use Locus Map and it works (just gpx import need to be done through external service (not direct import in SA) like QS or Runalyze).
              SSU (retired), SV1, SV2
              Wife : S9PP
              SA: Always the latest beta :)
              Android + Galaxy S205G
              • isaziI Offline
                isazi Moderator @Derrick Spafford
                @derrick-spafford it works on everything is routable.
                Blog: isazi's home
                Derrick SpaffordD 1 Reply Last reply Reply Quote 0
                  Derrick Spafford @isazi
                  @isazi said in Turn-by-turn navigation in S9 series with Plotaroute:
                  Thanks. Will keep trying to figure it out as it hasn’t worked for me yet and trying to find why.
                  • isaziI Offline
                    @derrick-spafford how do you import the gpx route in SA?
                    Blog: isazi's home
                      I pulled the GPX route from Strava. Uploaded it to Komoot and then sent it to SA to use in watch. Route shows but no turn to turn.
                      I tried this with creating a planned route but also a recently run route.
                      I have an old custom Movescount Sport mode that I use (with Optical HR disabled) that I was wondering if that was the problem, but used other default sport modes and still no luck. Did a master reset and will try reinstalling software to see if that helps.
                      • M Offline
                        Mike H. @Mff73
                        @mff73 Thank you for the hint 👍. I also plan my routes using Locus maps. I have to try.
                        Suunto 9 Baro
                        • First post
                          Last post
                        Suunto Terms | Privacy Policy
