    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Firmware Rollback - Firmware with best GPS
    37 Posts 12 Posters 4.3k Views 11 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • MRonyM Offline
      MRony @surfboomerang
      @surfboomerang Hello, I also have the topic of GPS measurement (Baro 9) in the vertical segment! Sunny weather, on different days and different time (same tour and new tours), deviations never less than 9m! on my last 15 tours there were about 2 peaks where I was at 3m deviation! I am not satisfied with these values! BG
      DMytroD surfboomerangS Mff73M 3 Replies Last reply Reply Quote 0
      • DMytroD Offline
        DMytro @MRony
        @mrony it’s not gps but barometer that gives you this values. Difference of 3m is totally tollerable for s9b if I know correctly.
        MRonyM 1 Reply Last reply Reply Quote 0
        • MRonyM Offline
          MRony @DMytro
          @дима-мельниченко +|-3m ok, but Not +9m and More at every Tour!
          DMytroD 1 Reply Last reply Reply Quote 0
          • DMytroD Offline
            DMytro @MRony
            @mrony I would say it’s ok as well. But I have a non baro version, so others could validate your conserns better. For me same peak may be +/- 20m ( and it’s still ok in my opinion).
            • zhang965Z Offline
              zhang965
              For me the last firmware is not getting better.
              Winners Wear Winners
              • surfboomerangS Online
                surfboomerang @MRony
                @mrony do you have the Baro version of a watch?
                Also I noticed sunny weather is not a guarantee for good GPS reception.
                Suunto Vertical Titanium Solar
                OnePlus Nord 4
                • MRonyM Offline
                  MRony
                  @surfboomerang s9 baro
                  • Mff73M Offline
                    Mff73 @MRony
                    @mrony said in Firmware Rollback - Firmware with best GPS:
                    does the watch records always the same altitude for the same peaks ? and are you sure of those peaks real altitude ?
                    also consider that altitude is a matter of reference
                    Not to say you are wrong, but to more understand. And with no data to look at, it is difficult to debate.
                    SSU (retired), SV1, SV2
                    Wife : S9PP
                    SA: Always the latest beta :)
                    Android + Galaxy S205G
                    surfboomerangS 1 Reply Last reply Reply Quote 1
                      surfboomerang @Mff73
                      @MRony Like @Mff73 said.
                      Some examples would be helpful then.
                      OnePlus Nord 4
                      • MRonyM Offline
                        @surfboomerang IMG_E5535 (Large).JPG IMG_E5534 (Large).JPG IMG_E5533 (Large).JPG IMG_E5532 (Large).JPG IMG_E5531 (Large).JPG IMG_E5530 (Large).JPG IMG_E5529 (Large).JPG IMG_E5537 (Large).JPG
                        Mff73M surfboomerangS 2 Replies Last reply Reply Quote 0
                        • Mff73M Offline
                          Mff73 @MRony
                          @mrony
                          do you have already tried to clean your baro sensor ?
                          have you tried the fridge test ? https://forum.suunto.com/topic/3519/alti-baro-fridge-test
                          Wife : S9PP
                            @mrony
                            Try the suggestions of @Mff73.
                            To be honest, I think the numbers you see are well within the margin.
                            I mean elevation lines on maps aren’t 100% accurate as well as I learned the hard way: https://forum.suunto.com/topic/5234/route-altitude-bug?_=1613401264400
                            Even the same map provider isn’t consistent
                            Furthermore a 2-3m difference can almost be achieved by putting the watch on the ground or waving your arm in the air. So unless you have your watch on the exact same spot from the official measurement it’s really hard to compare.
                            OnePlus Nord 4
                            MRonyM 1 Reply Last reply Reply Quote 5
                            • MRonyM Offline
                              @surfboomerang hello, peaks usually have the correct elevation on the maps. the app “peakhunter” confirms this. a deviation of about 3m would be ok, but I can’t understand that this is not possible on a single tour!
                              • Brad_OlwinB Offline
                                Brad_Olwin Moderator @MRony
                                This is possible because the watch is assessing elevation using a barometer that is pressure sensitive and attempting to correct this with a GPS measurement. Our estimates of peak heights are simply not exact. For example, Colorado, USA just revised its estimates of peak elevations with a new reference standard and we are going to have one less 4267m (14,000 foot) peak. So the accuracy you are seeking is not in the reference data you are referring to as @surfboomerang eloquently stated.
                                Second, changes in barometric pressure will affect the elevation even with GPS correction, this can easily occur. Third, depending on where the watch is placed and how you are moving, this will affect elevation measurements and there are algorithms built in to deal with this. The watch is not a precision elevation measurement instrument.
                                IMHO there is nothing wrong with your watch or the elevation values you are getting.
                                Vector/T6c/Vertical 2 Ti
                                ? 1 Reply Last reply Reply Quote 4
                                • ? Offline
                                  A Former User @Brad_Olwin
                                  @brad_olwin the only who can show error is this one
                                    Brad_Olwin Moderator @Guest
                                    @g287-sf That one is further off, I agree but the GPS point may or may not be at the true summit, the map could be off or I have had occasional elevation readings that are off. Typically, this is due to rapid changes in weather. More often, my watch is very close (within 3-6m), which I think is fantastic.
                                    ? 1 Reply Last reply Reply Quote 2
                                    • ? Offline
                                      @brad_olwin honestly for me 10meters in X and Y is normal.
                                      1 Reply Last reply Reply Quote 3
                                      Register Login
                                      • First post
                                        Last post
                                      Suunto Terms | Privacy Policy
