    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Firmware Rollback - Firmware with best GPS
    37 Posts 12 Posters 4.2k Views 11 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • ? Offline
      A Former User
      Hi,
      Since i’m on this forum i read many times “since the new update GPS works bad”
      So anyone here have try to rollback to a better version ?
      For you guys which one was the best in terms of GPS quality ?
      Geek do you think you can help to do a rollback if it’s not natively possible ?
      surfboomerangS EgikaE M 3 Replies Last reply Reply Quote 0
      • surfboomerangS Offline
        surfboomerang @Guest
        @g287-sf AFAIK most complains were the result of AGPS issues on Sony"s side. Not much Suunto firmware could do.
        Also I’m not sure if every watch firmware version also included GPS chip firmware
        Are you facing accuracy issues right now because of your question?
        Suunto Vertical Titanium Solar
        OnePlus Nord 4
        ? 1 Reply Last reply Reply Quote 1
        • EgikaE Offline
          Egika Platinum Member @Guest
          @g287-sf said in Firmware Rollback - Firmware with best GPS:
          You can easily change the FW by using the file and drag and drop it to Suuntolink
          1 Reply Last reply Reply Quote 3
          • ? Offline
            A Former User @surfboomerang
            @surfboomerang the only issue i have was with altitude on a trail i did 2 times in one week. If you want compare
            For firmware it’s just a question to see what people think because i read many times
            " this new firmware is a downgrade "
            “since the new firmware gps have issue”
            And we can see this last firmware say " GPS improvement".
            So we can affirm this improvement don’t work because people were happier before this modification and a majority of them find their gps is less reliable since they update their watch.
            What do you think ? Sorry for my english, try my best
            isaziI Brad_OlwinB EgikaE 3 Replies Last reply Reply Quote 0
            • isaziI Offline
              isazi Moderator @Guest
              @g287-sf I’m actually happier now 🙂 I am now using GPS only (instead of Baidou) and get very good tracks. In my opinion, since I bought my S9 in August 2019 the GPS has improved a lot.
              Blog: isazi's home
              ? 1 Reply Last reply Reply Quote 3
              • ? Offline
                A Former User @isazi
                @isazi i’m in France and set GPS/GZSS + Galileo. it don’t looks bad. But i should try GPS/GZSS only.
                Beidou shouldn’t be interesting for me, it’s for asia if i’m right and i’m in europe.
                isaziI freeheelerF 2 Replies Last reply Reply Quote 1
                • Brad_OlwinB Offline
                  Brad_Olwin Moderator @Guest
                  @g287-sf You cannot compare GPS tracks from one day to the next, too many variables. In fact, you should not compare them with one watch on each arm. Each firmware release that Suunto provides is extensively tested prior to release by far more exhaustive testing than you might imagine. The perception that a particular firmware is less or more precise is just that, a perception. Unless you have data to support the claim.
                  Vector/T6c/Vertical 2 Ti
                  ? 1 Reply Last reply Reply Quote 5
                  • isaziI Offline
                    @g287-sf to be fair, on any given day there are probably more Beidou satellites visible over France than Galileo ones.
                    Blog: isazi's home
                    ? 2 Replies Last reply Reply Quote 2
                    • ? Offline
                      @isazi Do you know a reliable android app or website to check satellite position ?
                      stromdiddilyS 1 Reply Last reply Reply Quote 1
                      • stromdiddilyS Offline
                        stromdiddily Gold Members @Guest
                        Lots 🙂
                        https://play.google.com/store/search?q=gnss&c=apps&hl=en_US&gl=US
                        https://satpredictor2.deere.com/lookup
                        https://app.qzss.go.jp/GNSSView/gnssview.html?t=1612823822006
                        Always carry a flaggon of whiskey for snakebite; and furthermore, always carry a small snake.
                        User of pretty much every watch since the Ambit 3 Peak. Now back in the family w SV2 :)
                        • ? Offline
                          A Former User @Brad_Olwin
                          @brad_olwin My 2 GPS tracks looks similar. It was just altitude who was bad.
                          For me 10 meters difference for GPS is acceptable when we know gps precision is around 3.3 meters. More is limit for outdoor device because it can cause orientation error.
                          For Altitude with a baro and fusedalti capable device 5 meters should be good. I compare with all my casio protek who always give me a good altitude ±5 m as indicated on map or directly on place.
                          surfboomerangS 1 Reply Last reply Reply Quote 1
                          • ? Offline
                            • EgikaE Offline
                              Just one statement:
                              If you read something many times in the internet it does not mean a majority has this opinion.
                              • M Offline
                                Mi_chael Bronze Member @Guest
                                @g287-sf
                                Pour moi, Suunto (A3 Peak, S5, S7, S9 Baro) fournit la meilleure précision GPS du marché. (Set to GPS only)
                                Ma Vertix n’est pas loin derrière.
                                Ma F6 pro ferme la marche…
                                Polar n’a pas réussi à égalé la précision de la V800, sur la Vantage V du moins.
                                  Keep in mind that the GPS precision most people talk about is the horizontal precision. Vertical is usually much less precise. That is where the barometer comes to the rescue.
                                  To be honest, if calibrated correctly, the Suunto 9 baro is pretty accurate in altitude to me.
                                  OnePlus Nord 4
                                  MRonyM 1 Reply Last reply Reply Quote 4
                                  • freeheelerF Offline
                                    freeheeler @Guest
                                    @g287-sf
                                    I have set my watch to GPS+QZSS after playing a bit with the other systems, too. I left it as mentioned and never touched it or thought about it. Some days it’s better, some days it’s worse. But always in regards to the track itself. I think altitude shouldn’t be an issue as you’ve got the baro, right?
                                    @Brad_Olwin
                                    you’re right, the true comparison is only possible with your cyborg tests like you do with many watches on one arm 😉 👍
                                    but I think users get a general feeling if their devices are more precise, react quicker etc… it is more of an impression thing I guess.
                                    living sideways
                                    Brad_OlwinB 1 Reply Last reply Reply Quote 1
                                      Brad_Olwin Moderator @freeheeler
                                      @freeheeler said in Firmware Rollback - Firmware with best GPS:
                                      @g287-sf
                                      @Brad_Olwin
                                      It is even worse than that! I have a wheel and a measured route to test how precise the GPS is. I always run/walk on the path the wheel was used and I have multiple wheel measurements to get a reliable distance. I have no idea what the neighbors think when they see me walking with a a wheel to measure distance:)
                                      ? stromdiddilyS freeheelerF 3 Replies Last reply Reply Quote 5
                                      • ? Offline
                                        @brad_olwin if you speak French you should follow “Montre Cardio GPS” on YouTube or even is blog. I run with many watch at the same time do plenty test. You should like it.
                                          stromdiddily Gold Members @Brad_Olwin
                                          @brad_olwin can’t be any worse than what they think watching you run with 7 different watches on 😄 😄
                                            freeheeler @Brad_Olwin
                                            @brad_olwin
                                            too old for a stroller, too young for a rollator 😜
                                            living sideways
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
