    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Suunto 9non baro elevation gain problem
    4 Posts 3 Posters 413 Views 2 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • RunnerR Offline
      Runner
      Hi, I want to ask you, if you know. I have new Suunto 9 watch. I got them for in the end of December. I have some doubts, that the elevation gain doesn’t count properly. I mean that the watch shows right altitude data, even when it differs, it goes right. But it doesn’t count in the elevation gain. Do you have some recommendations, what to do?
      inkognitoI P 2 Replies Last reply Reply Quote 0
      • inkognitoI Offline
        inkognito Platinum Member @Runner
        @Runner Doesn’t count at all? (0 m ascent, 0 m descent) -> you use battery mode with lower GPS accuracy. Ascent/descent is only calculated when you use Performance mode or Custom with Best GPS accuracy.
        Does it count less? -> This is due to treshold - you need to ascent/descent 7 m continously (within some time) to have this counted. If you for example ascent 5 m and descent 5 m immediatelly after that, nothing is counted. This filter was implemented to deal with lower precision of elevation data based only on GPS. BARO version of S9 is generally more accurate.
        SV: fingers crossed :D
        S9 (non-baro): died after 2 months, replaced, holding strong since 03/20
        Spartan Trainer: casing broke after 23 months, repaired, lost watertightness 5 months later, died
        Despite some pretty bad luck, I still love Suunto!
        RunnerR 1 Reply Last reply Reply Quote 1
        • P Offline
          pacos @Runner
          @Runner and if you have the baro version the threshold is of 3 meters
          • RunnerR Offline
            Runner @inkognito
            @inkognito Thanks for explaining! That would be the problem.
            Register Login
            • First post
              Last post
            Suunto Terms | Privacy Policy
