    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    S9 Baro crash in altimeter menù
    27 Posts 5 Posters 2.7k Views 5 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • matteo_000M Offline
      matteo_000
      Hi everyone,
      I’m a happy new user of S9 Baro for over 10 days. I have updated firmware 2.13.18 immediately but in this period I have had five times of system crash (and reboot) when I have used ALTIMETER->ALTIMETER GRAPH->BAROMETER GRAPH in particolar (it seems…) when I slide the display from the graph to first screenshot ALTIMETER.
      After the two last crash I have sent the log through diagnostic menù of Suntolink (log 636599218900 and 6823202005300 this immediately after the reboot).
      Someone has had similar problems ???
      Thanks a lot and good 2021.
      Matteo
      SV2 All Black - Italy
      Dimitrios KanellopoulosD 1 Reply Last reply Reply Quote 0
      • surfboomerangS Offline
        surfboomerang
        I can’t reproduce it with my S9 Baro. Maybe a soft reset or reflash of the firmware will do the trick?
        Suunto Vertical Titanium Solar
        OnePlus Nord 4
          Dimitrios Kanellopoulos Community Manager @matteo_000
          @matteo_000 does this happen often or each time ?
          Creator of quantified-self.io
          youtube.com/c/dimitrioskanellopoulos
          instagram.com/dimitrioskanellopoulos
          www.strava.com/athletes/7586105
            matteo_000
            Hi Dimitrios and thanks for your interest. It happens often: from 19 december (when I received new S9B…) it happens five times.
            Thanks a lot.
            Matteo
            Dimitrios KanellopoulosD 1 Reply Last reply Reply Quote 1
              @matteo_000 if it keeps happening it might be hardware issue. I would get it replaced. If you need help I can help you get this done
              • J Offline
                Jugger
                Hello!
                I have the same problem. Already talked to Dimitrios about it. It seems to happen while entering Altitude menu too fast (enter menu straight after scroll). I usually wait those white up and down menu arrows to disapper before entering.I have avoided any crash that way.
                I saw this topic and tried to crash my watch. Took only three times and boom, reboot. In 2 hours two times more.
                Which watchface are you using? I use the one with barometer on outer ring (with baro trending and altitude). I use yellow color. Reboot issues started after installing firmware with new watchface. I tried other watchfaces also but they seem to be stable.
                Could other people try with mentioned watchface if it causes crashes?
                Suunto Vertical Titanium Forest
                Suunto Vertical 2 Titanium Sage
                surfboomerangS 1 Reply Last reply Reply Quote 0
                  surfboomerang @Jugger
                  @Jugger I can’t reproduce it.
                  I scroll all the way down to the altitude and then as fast as I can to altiude graph->barometer->altitude->altitude graph but it keeps working. Both with touch and buttons
                  OnePlus Nord 4
                  J 1 Reply Last reply Reply Quote 0
                  • J Offline
                    Jugger @surfboomerang
                    @surfboomerang And you did use that certain watchface? It happens seldom.
                      @Jugger yes, I will try some more.
                      You mentioned yellow color. That means you have a green baro outer right right?
                      OnePlus Nord 4
                      • J Offline
                        @surfboomerang That’s right.
                          @Jugger Can you post a video? I can’t make it crash. Maybe I’m reproducing it wrong.
                          OnePlus Nord 4
                            Hey guys, can you send logs via the Suuntolink and give me the ID ?
                            1 Reply Last reply Reply Quote 3
                            • J Offline
                              Jugger
                              Here’s my log 2093490669333900. Few minutes after crash.
                                matteo_000
                                @Jugger and @Dimitrios-Kanellopoulos I have tried to crash the watch like you described (about 15 times) and it has had one crash (ID 282087109534000).
                                Usually I use the watchface like you said (with barometer on outer ring with baro trending and altitude/hPa - red colour). In the last crash has that with the outer ring with sunrise/sunset/moon phase - yellow color but maybe the colors aren’t the problem (…only watchface?!?).
                                I check often baro info on the watch because I’m passionate about meteorology. If the problem is only the fast access to alti/baro menu, I will check/access more slowly…😊
                                @Dimitrios-Kanellopoulos this is the logs list sent with Suuntolink:
                                636599218900 (crash around 20:40*) 31/12/20
                                6823202005300 (crash around 14:09*) 01/01/21
                                282087109534000 (crash around 18:42*) 04/01/21
                                (*) local time; GMT+1
                                Thanks to all.
                                Matteo
                                • J Offline
                                  Jugger
                                  Finally I got video uploaded to Dropbox. This time I got lucky and my watch rebooted on my first attempt. Total crashes today: five times.
                                  And to @matteo_000 wait for white menu arrows to disappear then it should be fine 👍
                                  Video is around 50mb. Hopefully it works.
                                  https://www.dropbox.com/s/5s6ue6nhdzdwcvk/Video 4.1.2021%2C 20.06.23.mov?dl=0
                                  surfboomerangS 1 Reply Last reply Reply Quote 3
                                    @Jugger I did exactly what you did a dozen times, but I’m still unable to let it crash.
                                    Does the watch also crash if you do this with touch instead of the buttons?
                                    @Dimitrios-Kanellopoulos Could it be production year related? My s9b is 2 years old.
                                    OnePlus Nord 4
                                    • J Offline
                                      @surfboomerang I tried and after a while it happened also with touchscreen. Just going in and out to alti menu. Don’t have to scroll to watchface.
                                        I’ll forward this to the sw team, but imo as others don’t have this issue and since I have seen these type of issues getting a watch replacement new , I would recommend the same.
                                        It can be hw fault that crashes this! Ie not isolated component.
                                        In regards to that, can it be clothing, place etc ?
                                        Ie electrostatic
                                        • J Offline
                                          Jugger @Dimitrios Kanellopoulos
                                          @Dimitrios-Kanellopoulos I doubt that static electricity has anything to do with it. Crash can happen anywhere. With different clothes and temperatures. I would like to replace my watch if possible.
                                          Like I’ve said reboot happens random. Not everytime like on video.
                                            Dimitrios Kanellopoulos Community Manager @Jugger
                                            @Jugger ask support and pm me the case ID to try to speed this up and bypass the support scripts
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
