    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    S9 Baro crash in altimeter menù
    27 Posts 5 Posters 3.2k Views 5 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • matteo_000M Offline
      matteo_000
      Dear all,
      in these days I have tested much time the function ALTI-BARO and I found:
      • the crash can happen ONLY with the watchface with barometer on outer ring with “baro trend” and altitude/hPa info;
      • it NEVER happened with other watchface;
      • with others watchface the access to submenù (ALTI->GRAPH ALTI->GRAPH BARO) is much faster than with watchface with “baro trend”; with this the slide/swipe it seems more slow…someone could try it ?
      • touch or bottons use is the same; there isn’t difference;
      • my S9B is new (less than a month…arrived to me 19th last december) and if @surfboomerang has had the same problem with his watch two years old…maybe insn’t hardware problem… I think;
      It could be a bug of the new watchface or last FW update ??? 🤔
      @Dimitrios-Kanellopoulos I tell you others new ID log sent immediately with Suuntolink after the reboot:
      446884534921400
      452235984552900
      I think that I will waiting to replace the watch to understand if the problem can resolve (maybe with new FW update ?!?) because all the others functions seems ok. In case I need it I will advise. Thanks for your support! 🙂
      So this is my little experience that I hope could help.
      Matteo
      SV2 All Black - Italy
      surfboomerangS 1 Reply Last reply Reply Quote 2
      • surfboomerangS Offline
        surfboomerang @matteo_000
        @matteo_000 said in S9 Baro crash in altimeter menù:
        Small correction.
        I can not reproduce the problem with my watch. I tried many times, with the baro trend selected, to let it crash but I failed to reproduce the issue.
        Also I haven’t noticed that the menu is much slower with that particular watch face. I will pay more attention to it.
        Suunto Vertical Titanium Solar
        OnePlus Nord 4
          matteo_000
          Ok sorry for my mistake…so @Jugger how old is your watch ??? Do you have detected the same difference between the watchface “baro trend” and others??? Thanks
          Matteo
          J 1 Reply Last reply Reply Quote 0
          • J Offline
            Jugger @matteo_000
            @matteo_000 I just tried and baro watchface is bit more slower when swiping alti sub-menu all the way to left and back to main menu. I also tried to crash my watch with other watchfaces with no luck. Only baro is causing that. I’ve had all firmware updates but problem was always there. So it’s not related in software.
            I bought my watch in May 2020. Everything else is working just fine.
            Suunto Vertical Titanium Forest
            Suunto Vertical 2 Titanium Sage
            Dimitrios KanellopoulosD 1 Reply Last reply Reply Quote 1
            • Dimitrios KanellopoulosD Online
              Dimitrios Kanellopoulos Community Manager @Jugger
              @Jugger it doesnt mean SW is always related.
              The memory / CPU usage can increase and thus the “capacity” needed can cause this.
              Similar lets say (not the same problem though) with phones that their batter is going kapot and while they show 50% when you do an intense work they shutdown/reboot.
              There are also memory errors and many other stuff.
              Creator of quantified-self.io a portal that allows you to analyze your data from various providers, upload fit activity files to Suunto app, gpx routes and more…
              • J Offline
                Jugger @Dimitrios Kanellopoulos
                @Dimitrios-Kanellopoulos Thank you for clarification. I have no idea what happens inside my watch. I just use it.
                Let’s see what Suunto answers.
                • stromdiddilyS Offline
                  stromdiddily Gold Members
                  Just had mine crash for the first time on the same menu 😕
                  Was using a different watch face and am away from my comp but if it happens again I will send the logs
                  Always carry a flaggon of whiskey for snakebite; and furthermore, always carry a small snake.
                  User of pretty much every watch since the Ambit 3 Peak. Now back in the family w SV2 :)
                  Register Login
                  • First post
                    Last post
                  Suunto Terms | Privacy Policy
