    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Suunto 9 Baro display is frozen in boot mode (display shows a downward facing arrow - "arrow down" - symbol), soft/hard reset won't fix. Oh and it's race week. Ugh.
    issuebugsuunto 9 barosuuntolinksuunto app android
    32 Posts 12 Posters 13.7k Views 13 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • S Offline
      Stack
      Plugged my Suunto 9 Baro into my PC this morning because it had died overnight (not a normal occurrence, but I was exhausted and fell asleep and likely left the backlight on). Upon plugging it in I returned to working for a bit. When I looked back at my watch again later it was frozen in boot mode and SuuntoLink said “Watch reset required - your watch needs to be reset to fix the error. All data on your watch will be deleted during the reset” and offered a reset watch button. Frustrated, but I’ve had to soft reset a few times before with this watch so I say okay. Attempted the reset and the watch starts rebooting, then SuuntoLink says “watch reset interrupted” and when the watch finished it’s reboot it returned to being stuck on the boot mode screen and SuuntoLink returned to the watch error screen. Subsequent hard and soft resets result in the same thing. SuuntoLink and the Suunto 9 Baro were both on the latest update prior to this AFAIK (I use the watch 5x/week and charge it once a week, always update when one is available)
      Talked to Suunto customer service and beyond soft/hard resets (which I already had tried) they just told me to send it in (it’s under a year old so thankfully still covered). This would be fine if I didn’t have the race I bought this watch for this weekend. So I’m planning to try anything up until race start and send it in after. In the interim, if anyone has ever had this issue and has some advice or things to try I’d love to hear it.
      I have already tried numerous iterations of this with no success:
      https://www.suunto.com/en-gb/Support/faq-articles/lifecycle/how-to-reset-your-suunto-watch/
      I plan to try and let the watch die again and see if plugging it in resolves it. I also plan to try a different computer when I have the chance.
      I also have my old Ambit3 Sport as a last-ditch backup, but the current expected battery life on it is not far for my expected race duration (running my first ultra) so I’m not super confident with it.
      Suunto Ambit 2 R (lost to the abyss)
      Suunto Ambit 3 Sport (backup watch)
      Suunto 9 Baro Titanium Ambassador Edition
      K A Nick DavisN 3 Replies Last reply Reply Quote 0
      • S Offline
        Stack
        The sequence that happened to my watch seems to be nearly identical to what happened to @Charles-D in this post, but I am stuck in the boot screen and resets do nothing…
        https://forum.suunto.com/topic/5539/why-does-my-s9-keep-resetting?_=1607487424433
        • surfboomerangS Offline
          surfboomerang
          Reflash the latest firmware isn’t working also in this state?
          Suunto Vertical Titanium Solar
          OnePlus Nord 4
          S 1 Reply Last reply Reply Quote 1
            surfboomerang
            Also, to be sure, check the cable. I ran into a reset issue because of a faulty one.
            https://forum.suunto.com/post/25976
            OnePlus Nord 4
            1 Reply Last reply Reply Quote 3
            • K Offline
              Klunzinger Bronze Member
              Send it to a servicecenter, the OHR Flex is faulty. Replacing it will solve the problem.
              BR
              S 1 Reply Last reply Reply Quote 3
              • K Offline
                khuttun @Stack
                @Stack One thing you could try is to do a drag’n’drop update for the watch in SuuntoLink (see for example https://forum.suunto.com/topic/5180/spartan-whr-baro-bricked/9?_=1607499537042).
                Also, if you didn’t do so yet, try sending the diagnostic logs from SuuntoLink (in the “Diagnostics” menu) and give the log ID number to Suunto support, so they can investigate the issue better.
                • S Offline
                  Stack
                  Thanks for all the feedback guys, here’s what I’ve tried so far…
                  Soft and Hard reset methods with cable plugged in and unplugged yielded no results
                  Factory reset on the SuuntoLink program yielded no results
                  Attempted manual firmware push suggested here (https://forum.suunto.com/topic/5405/s9b-upgrade-factory-reset-problem-v2-10-26) using SuuntoLink method described by @Dimitrios-Kanellopoulos here (https://forum.suunto.com/topic/5396/suunto-spartan-ultra-update-not-available/10) and previous firmware versions described here (https://forum.suunto.com/search?term=Ibiza firmware.geo &in=posts&matchWords=all&sortBy=timestamp&sortDirection=desc&showAs=posts). This yielded no results.
                  Tried “put watch to deep sleep after reset” checkbox suggested here (https://forum.suunto.com/post/46365) (https://forum.suunto.com/assets/uploads/files/1578509185798-screenshot_20200108-194536_lite.jpg) yielded no results.
                  Commandeered my wife’s computer and added the latest SuuntoLink. Yielded no results.
                  I have a second cable at my office, but I’m working remote. Will see if I can get into my office to get to the cable.
                  • S Offline
                    Stack @surfboomerang
                    @surfboomerang Correct this didn’t work unfortunately. I will try the cable when I can get my hands on my other one, it’s in my office.
                    cosme.costaC 1 Reply Last reply Reply Quote 2
                    • S Offline
                      Stack @Klunzinger
                      @Klunzinger out of curiosity, what is the OHR Flex?
                      cosme.costaC K 2 Replies Last reply Reply Quote 0
                      • S Offline
                        Stack @khuttun
                        @khuttun Thanks for the link, I managed to stumble on that last night and tried it, it didn’t work unfortunately.
                        I had sent the logs but it was after talking to support. To be honest, support only tried soft and hard resets then told me to just send it in. They didn’t seem to be interested in advanced troubleshooting.
                        • cosme.costaC Offline
                          cosme.costa @Stack
                          @Stack said in Suunto 9 Baro display is frozen in boot mode (display shows a downward facing arrow - "arrow down" - symbol), soft/hard reset won't fix. Oh and it's race week. Ugh.:
                          I guess he means the connector of the OHR that goes into the watch main board.
                            cosme.costa @Stack
                            If I were you, before send the watch to service I would try with different cable, some people has had issues with it.
                            • S Offline
                              Stack @cosme.costa
                              @cosmecosta I guess I don’t know what the acronym OHR stands for?
                              isaziI 1 Reply Last reply Reply Quote 0
                              • isaziI Offline
                                isazi Moderator @Stack
                                @Stack Optical Heart Rate. I guess they are referring to some (possible?) internal defect on your watch.
                                Blog: isazi's home
                                • S Offline
                                  Stack
                                  Update on my end, got into my office and plugged in the watch, getting a new message I haven’t before so I’ll take that as a good sign (says “Your watch battery level is too low to start the update. Please wait for the watch to charge to 15% before updating.”), but I’ll have to wait until the watch charges up.
                                  Also noticed SuuntoLink is on 3.1.4 here, not sure if that is making the difference or not, as at home I am on 3.3.5.
                                  surfboomerangS 1 Reply Last reply Reply Quote 0
                                    surfboomerang @Stack
                                    @Stack I don’t think Suuntolink version should be an issue, but who knows…
                                    Try if you’re watch will work again and then the same at home
                                    OnePlus Nord 4
                                    • S Offline
                                      Stack
                                      Soft reset, hard reset and manual firmware update didn’t work with new cable. Did the same thing as the other cable. I guess the issue is the watch. Will be sending it in.
                                      Super disappointed as I have been training for months for the race this weekend using this watch (which I bought less than a year ago to run my first ultra) and it fails. Had good luck with past Suunto watches and for the most-part good luck with this one aside from some random soft resets and occasional GPS/baro glitches… but this definitely spoils my feelings about the brand in the short term. I hope support can resolve it and I can use this watch for years to come.
                                      Thank you to everyone who tried to help, I will keep you posted on what the Suunto support comes back with as the issue. In the interim, I guess I will see how well my old Ambit holds up.
                                      • S Offline
                                        Stack
                                        So I didn’t get a chance to hit the UPS store to ship my watch to support today, and it finally died on it’s own accord (probably helped that the boot screen kept the light on). Decided to try one last thing and plugged it into a power source (non-pc) and it booted up to the main screen! Will probably still send it in because I don’t trust it to not do this again but if it holds up I may be able to wear it for my race after all…woo!
                                        We will see if it holds up though, I’d like to plug it in to update GPS when I’m at the race but I’m afraid to plug it into the computer again… I’ll definitely be packing my Ambit just in case, but am excited that my watch might actually work. Fingers crossed…
                                        surfboomerangS 1 Reply Last reply Reply Quote 5
                                          Can’t you just connect wireless to your phone and sync GPS that way?
                                          OnePlus Nord 4
                                          • K Offline
                                            Klunzinger Bronze Member @Stack
                                            @Stack This is the connection from OHR Module to the mainboard. The servicecenter will know the problem.
                                            BR
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
