    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Why does my S9 keep resetting!?
    13 Posts 6 Posters 1.8k Views 7 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • C Offline
      Charles D
      Four times in 18 months, my S9 has required some sort of reset spontaneously when I plug it in to charge. I don’t mind losing all my data on the watch, but it is really irritating to have to go back in and re-create all my custom sports modes.
      Do other people see this behavior as well (i.e., it’s a feature) or am I the only one (i.e., it’s a bug)? REALLY frustrated in any case.
      Screen Shot 2020-12-07 at 8.47.03 AM.png Screen Shot 2020-12-07 at 8.46.33 AM.png
      isaziI Brad_OlwinB 2 Replies Last reply Reply Quote 1
      • isaziI Offline
        isazi Moderator @Charles D
        @Charles-D you’re not the first one to report something similar in the forum.
        Blog: isazi's home
        • Brad_OlwinB Offline
          Brad_Olwin Moderator @Charles D
          @Charles-D I sent you some information by email Charles. Unfortunately, this is not happening to me so harder to track down. Others have reported this as well. You can answer my questions in the email either by email or here.
          Vector/T6c/Vertical 2 Ti
          • S Offline
            Stack
            This is identical to what just happened to me, but now my watch is stuck on the boot mode screen and no manner of hard/soft reset will fix it.
            Suunto Ambit 2 R (lost to the abyss)
            Suunto Ambit 3 Sport (backup watch)
            Suunto 9 Baro Titanium Ambassador Edition
            • kiloawayK Offline
              kiloaway
              how’s your watch now? mine got exact the same issue all of sudden. tried everything the forum suggested to no change. figured I may need to wait and try reflash the watch the with future newer version firmware .
              isaziI 1 Reply Last reply Reply Quote 0
              • isaziI Offline
                isazi Moderator @kiloaway
                @kiloaway last firmware update should have fixed this. Did you contact support also? It may even be the cable, or something in your setup. The only time it happened to me (in 2019) was because I was using Suuntolink in a virtual machine and the USB was not whitelisted.
                Blog: isazi's home
                • ? Offline
                  A Former User
                  Hi all, I was trying to find information on how I can recover the sports modes I have customised for my Suunto 9 Baro.
                  Today the watch randomly required a reset while charging, and both SuuntoLink and the Suunto iPhone app now consider this as a new watch (serial number is the same, but that does not seem to help at all).
                  The Suunto app has also erased all sports modes, there were quite a few… It seems I really have to recreate all Sports modes, or am I missing something?
                  Software is and was up-to-date on all devices.
                  Thanks!
                  • isaziI Offline
                    isazi Moderator @Guest
                    @martinlx said in Why does my S9 keep resetting!?:
                    Unfortunately yes. Maybe it will change in the future, but I don’t know.
                    Do you charge your watch on your computer, or just with ac adapter and cable?
                    Blog: isazi's home
                    • ? Offline
                      A Former User @isazi
                      @isazi Hi, Thanks. I charge the watch via power cable and would usually only connect to my laptop for software updates. It was also connected to power cable this morning when the reset was suddenly required. Do you think that makes difference?
                      And besides that, not being able to recover the sports modes is very, very disappointing. Now the good thing is that I kept Suunto app print screens of all watch displays for my most important sports modes…
                      • isaziI Offline
                        That sounds normal, I would assume that the reset would happen only if connected to a computer. Maybe a faulty cable?
                        Blog: isazi's home
                        • ? Offline
                          @isazi Hi, no faulty cable. I am using this since I have the watch. Bad luck as it seems…
                          • isaziI Offline
                            @martinlx the fact that this happens may actually mean you have a faulty cable. Cables break. Or maybe the pins under your watch are a bit rusty and need cleaning. You may want to have a chat with support too.
                            Blog: isazi's home
                            • ? Offline
                              @isazi I mean, these things can happen, power cable or not. The issue is that the customised sports modes are lost, although they are on a separate device that knows me as a user with a Sunnto user account. One would expect that it should be easy to recover them…
                              • G gcolli referenced this topic on
                              Register Login
                              • First post
                                Last post
                              Suunto Terms | Privacy Policy
