    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    S9B upgrade / factory reset problem (v2.10.26)
    40 Posts 7 Posters 6.7k Views 6 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • Mff73M Offline
      Mff73 @azorg
      @azorg
      Eventually downgrade to less than 2.10, and reupgrade.
      Are you sure you have proper FW file for your watch model (just to be sure šŸ˜‰)?
      SSU (retired), SV1, SV2
      Wife : S9PP
      SA: Always the latest beta :)
      Android + Galaxy S205G
      A 1 Reply Last reply Reply Quote 0
      • sartoricS Offline
        sartoric Moderator
        And don’t forget ā€œask supportā€ solution šŸ˜‰
        SVTS - 2.50.28
        SSSWHR BARO Amber - 2.8.32
        Samsung A5 2016 - Android 7.0
        Suunto App Android 6.11.12 beta
        • A Offline
          azorg @Mff73
          @Mff73 I manually try to flash IbizaC-fw_2.11.38.3143-F.zip and Ibiza-fw_2.12.30.3539-F.zip. When can I find firmware for S9?
          • surfboomerangS Offline
            surfboomerang
            version seems OK. I also got ā€œIbiza-fw_2.12.30.3539-F.zipā€ in my Suuntolink folder.
            Long shot… any software on you pc that could cause trouble? Try another PC? Reinstall Suuntolink?
            Do you see any errors in the logfiles in the directory: C:\Users\<your user>\AppData\Roaming\Suuntolink?
            Suunto Vertical Titanium Solar
            OnePlus Nord 4
            • A Offline
              azorg
              Manual update to 2.10.26 (drop file to gear) crash too.
              Only reset+flash 2.10.26 works…
              surfboomerangS 1 Reply Last reply Reply Quote 0
                surfboomerang @azorg
                @azorg Any errors in the Suuntolink log files?
                OnePlus Nord 4
                A 1 Reply Last reply Reply Quote 1
                • A Offline
                  azorg @surfboomerang
                  @surfboomerang, some ERRORs in ā€œsuuntoapp.logā€
                  [2020-Nov-10 17:43:01 +0300] [ERROR] [SDS RESPONSE] type: GET status: NOT_FOUND header: {ā€œStatusā€: 404, ā€œTaskIdā€: 12, ā€œReasonā€: ā€œNOT_FOUNDā€, ā€œContent-Lengthā€: 0, ā€œUriā€: ā€œsuunto://SDS/Komposti/Devicesā€}
                  [2020-Nov-10 17:44:57 +0300] [ERROR] Recovery failed
                  [2020-Nov-10 17:44:57 +0300] [ERROR] Unknown mode, requested UpdateApplication
                  [2020-Nov-10 17:45:17 +0300] [INFO] [SDS REQUEST] type: PUT uri: sds://SDS/Firmware/Status contract: {ā€œErrorDetailsā€: ā€œUnknown mode, requested UpdateApplicationā€, ā€œErrorā€: ā€œFIRMWARE_UPDATE_FAILED_WITH_ERRORā€, ā€œSerialā€: ā€œ201210003780ā€, ā€œCompletedā€: false}
                  [2020-Nov-10 17:45:44 +0300] [ERROR] [SDS RESPONSE] type: GET status: NOT_FOUND header: {ā€œStatusā€: 404, ā€œTaskIdā€: 97, ā€œReasonā€: ā€œNOT_FOUNDā€, ā€œContent-Lengthā€: 0, ā€œUriā€: ā€œsuunto://ECKIE18E55B8/Settings/Device/Backendā€} error: [wb] Failed to get resource
                  [2020-Nov-10 17:45:44 +0300] [ERROR] [SDS RESPONSE] type: PUT status: BAD_REQUEST header: {ā€œStatusā€: 400, ā€œTaskIdā€: 98, ā€œReasonā€: ā€œBAD_REQUESTā€, ā€œContent-Lengthā€: 0, ā€œUriā€: ā€œsuunto://SDS/Whiteboard/InternetGateway/Configurationā€} error: [wb] Operation failed
                  [2020-Nov-10 17:45:45 +0300] [ERROR] WebService::isNewFirmwareAvailable: getFirmwareVersion failed with code 417
                  [2020-Nov-10 17:50:17 +0300] [ERROR] [SDS RESPONSE] type: GET status: NOT_FOUND header: {ā€œStatusā€: 404, ā€œTaskIdā€: 123, ā€œReasonā€: ā€œNOT_FOUNDā€, ā€œContent-Lengthā€: 0, ā€œUriā€: ā€œsuunto://201210003780/Device/Power/BatteryLevelā€} error: [wb] Failed to get resource
                  isaziI 1 Reply Last reply Reply Quote 0
                  • isaziI Online
                    isazi Moderator @azorg
                    @azorg I would suggest you to contact Suunto support.
                    Blog: isazi's home
                    A surfboomerangS 2 Replies Last reply Reply Quote 2
                    • A Offline
                      azorg @isazi
                      @isazi is official e-mail, chat?
                      Have you any contacts of developers?
                      Phone support don’t respond in my country…
                      sartoricS isaziI 2 Replies Last reply Reply Quote 0
                      • sartoricS Offline
                        sartoric Moderator @azorg
                        @azorg
                        if you open the support page you should get chat, if available
                        SVTS - 2.50.28
                        • isaziI Online
                          @azorg also if you use the Suunto app, you can contact support from there.
                          Blog: isazi's home
                            surfboomerang @isazi
                            @isazi said in S9B upgrade / factory reset problem (v2.10.26):
                            This indeed.
                            Although it is strange that you can flash the old firmware but not the last two. Have you also tried an older version then the one you have now?
                            OnePlus Nord 4
                            • A Offline
                              @surfboomerang said in S9B upgrade / factory reset problem (v2.10.26):
                              This indeed.
                              No, I didn’t. I have not old version for downgrade. Can you help me find it?
                              v2.10.26 flash success only in recovery mode with reset watch (if I disconnect watch during flashing).
                              If I flash v2.10.26 manually (drag and drop to gear zip file) then watch freeze too on second dot…
                                surfboomerang
                                Is a ā€œReset watchā€ in recovery mode not the same as tell the watch to reset it’s settings to the factory default of the installed firmware? So the firmware file is never transfered to the watch.
                                While with the manual drop of a zip file is an actual data transfer?
                                In brief… the watch won’t flash any firmware (current or newer).
                                This was exactly my case more then a year ago. Once I replaced the charging cable, my issue has been resolved.
                                I still use the old cable as a spare charger, but I can never use it to flash firmware onto my watch.
                                OnePlus Nord 4
                                A 1 Reply Last reply Reply Quote 2
                                • A Offline
                                  @surfboomerang some times I can manual flash to 2.10.26 (1 of 5) and I see all long flashing process…
                                  Manual update to 2.11.x and 2.12.xx freeze on second dot flashing šŸ˜ž
                                  Mff73M 1 Reply Last reply Reply Quote 0
                                  • Mff73M Offline
                                    Mff73 @azorg
                                    @azorg
                                    You can find a couple of old firmwares with this search.
                                    https://forum.suunto.com/search?term=Ibiza firmware.geo &in=posts&matchWords=all&sortBy=timestamp&sortDirection=desc&showAs=posts
                                    Wife : S9PP
                                    • ? Offline
                                      A Former User
                                      Why not contact support?
                                      Seems to me you have a defective watch no?
                                      • isaziI Online
                                        isazi Moderator
                                        Indeed it looks like either your watch or your cable are problematic. I would contact support and have them deal with it.
                                        Only once, more than a year ago, I had an issue with the watch getting stuck updating and having to do full reset. It was because I was using a virtual machine and the usb device was not automatically passed through mid update.
                                        Blog: isazi's home
                                        • A Offline
                                          azorg
                                          Solve the problem! Return Suunto 9 baro (black) to shop with full refund!
                                          I bought Sunto 9 titanium v2.11.38 and upgrade to 2.12.30.
                                          1 Reply Last reply Reply Quote 4
                                            surfboomerang
                                            That’s one way to solve it šŸ˜„
                                            OnePlus Nord 4
                                            With your input, this post could be even better šŸ’—
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
