    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Suunto 9 Picasso Edition
    125 Posts 26 Posters 26.7k Views 25 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • freeheelerF Offline
      freeheeler @Dimitrios Kanellopoulos
      @dimitrios-kanellopoulos
      I PM-ed it to you as an error popped up over and over again when I tried posting it here…
      living sideways
      • zhang965Z Offline
        zhang965
        I noted something interesting, I run weekly 10k in the same place.
        The mode of GPS is gps only and in performance mode with last AGPS and 15mins waiting before starting.
        As the field is 400m, so normally, every km mark will be the other side of field. (400 * 2,5 = 1km)
        So for the figures 2 to 6, you can see the 10km mark(or the red end mark) is close to the green begin mark.
        but the first one, the GPS trace is very fine, strangely the 10km marks in 200m farther than where is should be.
        My question is, where is these 200m? there is no evidence that GPS takes any shortcut,
        how could it be? it means during a section where the GPS saved a speed lower than my actual speed?
        Winners Wear Winners
        • zhang965Z Offline
          zhang965
          just my observation,
          I did a 10k GPS only(L) and a 5k GPS + Galileo( R) today, I’m still suffering the gps speed lost issue,
          I run with an almost constant speed, but during the red box area, the speed dropped a lot (4m/km to 4.46m/km)! so this makes my 8th 9th 10th kms much longer.
          So I ran another 5k with GPS + galileo, in the same area, the speed less than GPS only (4 to 4,16).
          anyone meets the same problem?
          does anyone know the root cause?
          how can we avoid this problem?
          freeheelerF 1 Reply Last reply Reply Quote 1
            freeheeler @zhang965
            @zhang965
            same day? what if you try to repeat that on another day?
            maybe the satellite position did not like this direction change on that very spot?
            living sideways
            zhang965Z 1 Reply Last reply Reply Quote 0
            • zhang965Z Offline
              zhang965 @freeheeler
              @freeheeler said in Suunto 9 Picasso Edition:
              @zhang965
              I didn’t think in this way, I will try it next time
              thank you a lot
              Dimitrios KanellopoulosD 1 Reply Last reply Reply Quote 1
                Dimitrios Kanellopoulos Community Manager @zhang965
                @zhang965 are you using Stryd or some pod btw?
                Creator of quantified-self.io a portal that allows you to analyze your data from various providers, upload fit activity files to Suunto app, gpx routes and more…
                • zhang965Z Offline
                  zhang965 @Dimitrios Kanellopoulos
                  @dimitrios-kanellopoulos said in Suunto 9 Picasso Edition:
                  nope,
                  • S Offline
                    Sara Mack @Guest
                    @André-Faria
                    this is from a cycling activity wearing a merino shirt of cigarclothing.
                    On the spikey HR activity I was running with a plastic shirt from https://www.cigarclothing.co/… same today: plastic shirt and spikey HR graph…
                    The graphs show good results about the shirt.
                    • zhang965Z Offline
                      zhang965
                      it’s what i noticed recently:
                      the GPS reception is not stable.
                      When I run with a given pace (4;11 m/km), during a section, the pace is dropped suddenly a lot(5;30m/km), but I will get a speed compensation after this section (3;20m/km), if I understand, it’s my S9B recalculate the distance.
                      normally, the recalculation is OK, it will not lost so much distance on a straight section.
                      But if I run faster during the section curved where the pace dropped, I’ll lost the distance, as the recalculation of distance is based on two positions. you can see in my screenshots, it looks like a shortcut.
                      My questions about this problem;
                      How my GPS reception can be lost during a such long distance (during 300m )? It supposed to be logged every 1s?
                      How can I check the GPS logging period? How can I check where the GPS reception lost or why it’s lost?
                      There is the GPS track difference between 2019 2020 2021 in the same place, same configuration
                      Why the GPS reception is getting worse over time?
                      Thanks
                        @zhang965 good question. Different times and different available sat?
                        • zhang965Z Offline
                          Almost the same time
                          2019 at 6:23
                          2020 6;47
                          2021 7:06
                          It looks I’m getting lazy over years
                          What is Available Sat?
                          Dimitrios KanellopoulosD freeheelerF 2 Replies Last reply Reply Quote 0
                            @zhang965 available satellites over your heat.
                            • zhang965Z Offline
                              I don’t know, so far, the only thing I can tell, they follow the same steps,
                              I wear the HR blet, I walk about 30m (so the watch has 30m to connect to GPS) to the park before start the run,
                              • darxmurfD Offline
                                darxmurf Platinum Member
                                Hi all,
                                Just bringing a quick answer here. On my side, the GPS is wrong almost all the time. On the map I’m always going “through” building or in the lake, on the railways. Ok I’m often starting my run from town, with buildings around but we don’t have skyscrapers here and I’m always waiting the watch is ready before starting. My 9 Baro is configured with GPS+Glonass.
                                I would say I know where I’m running and there is no need for me to re-check the map after but there is a serious lack or precision here 😕
                                https://www.instagram.com/darxmurf/ - https://www.instagram.com/omch.swiss/
                                Richard ThygesenR 1 Reply Last reply Reply Quote 0
                                • Richard ThygesenR Offline
                                  Richard Thygesen @darxmurf
                                  @darxmurf perhaps not related but my track is always wrong on the graphic map but fairly good on the real satellite map. But it had almost more or less been wrong. The last days it has been better and the only thing I changed is that I use a Polar H9 instead of a Polar OH1.
                                  S9
                                  S9 Peak
                                  Race
                                  Mister PYCM 1 Reply Last reply Reply Quote 0
                                  • Mister PYCM Offline
                                    Mister PYC Silver Members @Richard Thygesen
                                    The SUNTO 9/Baro GPS is not so bad …
                                    For the fun of it, I created a personalized “Motorsport” mooing the lawn view for when I’m cutting my garden grass …
                                    I was impressed by the result (not the garden 🙂 … but the capture of information …
                                    It is not a 400 m stadium … still I’m almost able to see that I went everywhere … just one time I entered in the house with the mower 🙂 🙂 🙂
                                    All is possible in IT
                                    Driven by you fear you stay on the ground, driven by your dreams you fly
                                    zhang965Z 1 Reply Last reply Reply Quote 2
                                    • zhang965Z Offline
                                      zhang965 @Mister PYC
                                      @mister-pyc said in Suunto 9 Picasso Edition:
                                      I don’t get you, do you understand what we discussed?
                                        @zhang965 said in Suunto 9 Picasso Edition:
                                        it looks like you need even more sleep now 😉
                                        the track from 2019 is better than the one from 2021 even with GPS improvement updates 🤔
                                        I don’t really have something to compare like you do, because I do sports infrequently. Hence no comparison over years for the same tracks at the same time… but what I do notice is that during an activity the GPS precision sometimes is better and sometimes worse but independently from the tree coverage and without steep hills near me. I don’t see a pattern
                                        living sideways
                                        • cosme.costaC Offline
                                          cosme.costa
                                          I think that also depends on the device, even being the same model, how it is worn and activity speed.
                                          Here two examples, the nice track is from my running partner. He was using an S9B Ti and I the regular S9B. He wears the the watch on the right arm and I on the left. The hill was around 400 m long with 100 m ascent, and he is much faster than me doing downhills and a little bit faster than me in the uphills.
                                          freeheelerF 1 Reply Last reply Reply Quote 2
                                            freeheeler @cosme.costa
                                            @cosmecosta
                                            and the activities were on the same time and day?
                                            at least the alti graph looks alright… but something seems to be always going on… either track or alti 😂
                                            I went downhill running today at sealevel, a loop starting and ending on our campsite 😉
                                            living sideways
                                            cosme.costaC 1 Reply Last reply Reply Quote 0
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
