Suunto 9 Picasso Edition
@TELE-HO said in Suunto 9 Picasso Edition:
@sartoric
yes I can… but it would not upload my screenshot…
let’s try again
Oh, I see
@inkognito
and this only happens for running in SA, but not for cycling?
Here’s a zoom of the same start sequence shown in QS:
@TELE-HO For me, those “SA bug” spikes occur also for cycling. They usually appear every ± 35 seconds and their height is the HR value that will follow after approx. 30 seconds from the spike. So, if your HR is going to increase in 30 seconds, you see positive spike, if it’s going to decrease, the spike is negative. When your HR is steady, spikes are not very noticeable.
@inkognito
I only came back from cycling now… no spikes at all… neither in SA nor in QS. -
what do you do when Picasso annexes your baro sensor during an activity?
@TELE-HO Turn the graph 90 degrees counter-clockwise and play “Guess the Famous Profile”?
@TELE-HO was that a pause ?
@Dimitrios-Kanellopoulos
no, non stop recording…@Fenr1r
hehe, the roman empire has crumbled long time ago
Edit:
I forgot to mention that after I’ve stopped the activity and the activity was saved the watch did an auto reboot -
@TELE-HO ok. How is the temperature chart ?
@Fenr1r
hehe, the roman empire has crumbled long time agoPlus ça change, plus c’est la même nose.
that’salright…hmm not existing?!?
…and now that you mention it I notice that the vertical speed profile is missing, too. I thought I saw both, but when I doublechecked they were both missing -
resynced and temperature is back… but not correct as you can see.
temperature went bananas well before the baro did.
@TELE-HO I know this issue. Might sound strange but it might be an edge case that happens rarely. Not 100% sure why but it’s known and fixed afaik
Maybe something went nuts on satellite data … This morning my short run on the usual path was 100m off (less)
means it comes with the next update? -
@Fenr1r said in Suunto 9 Picasso Edition:
That nose… I guess it’s me
@TELE-HO not related, but I had an issue with altitude too today
The profile is not wrong, maybe a little hiccup here and there, but the ascent/descent are: I got a 12 up 37 down in the Suunto App. Runalyze recomputes ascent/descent based on the alti data and gave me a more reasonable 48 up 38 down.
@isazi
nice, it corrects it?
my recording stays wrong. the value on the watch during the activity was wrong all of a sudden, the graph in SA is wrong, the total ascent is missing 1/3 of the meters the highest point was wrong and the end altitude is wrong, too. And of course it is now wrong in SA, Stravagram (hence Elevate) and QS. At least in QS I would have the possibility to correct it. But I don’t, because then it is not in line with the other databases anymore
another sad story, the same day, same exercise, left is recorded with suunto app on my phone and right is recorded with suunto9baro.
the distance is 3.3km vs 2.6km…
@zhang965
looks like you have a nice phone!
Register Login
