    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    problems with my S9B
    54 Posts 15 Posters 6.8k Views 13 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • EfejotaE Offline
      Efejota Bronze Member
      I had a huge difference in altitude yesterday having a short ski walk with my S9B. Any explanation? GPS signal was clearly bad in the beginning, but I cannot understand that it took so long to get the correct altitude. How could I share the file for you experts to check (the activity is already in QS)?
      cosme.costaC 1 Reply Last reply Reply Quote 0
      • cosme.costaC Offline
        cosme.costa @Efejota
        @efejota said in problems with my S9B:
        Yesterday was some issues with GPS (mainly Sony chip), Garmin was affected too.
        https://www.dcrainmaker.com/2021/02/tech-tidbits-garmin-gps-offsets-again-and-powertap-units-discontinued.html
        • ? Offline
          A Former User
          I don’t understand why just a sleeve can effect as bad the sensor. I’ve got in past many Casio Protrek and never had this kind of problem.
          Maybe a firmware update will correct it
          freeheelerF pilleusP cosme.costaC 4 Replies Last reply Reply Quote 2
          • freeheelerF Offline
            freeheeler @Guest
            @g287-sf
            I’ve had a protreck, too… many years back. this one had a twin sensor to assure no wrong measurements
            living sideways
            • pilleusP Offline
              pilleus @Guest
              @g287-sf said in problems with my S9B:
              Casio
              I use two G-SHOCK watches too and the ascent and altitude are spot on. Even more exactly than my SSU. 😲
              https://www.instagram.com/moves.are.life/
              Suunto Vertical Black Lime
              Suunto 9 Peak Pro Black
              Suunto Spartan Ultra Stealth Titanium
                cosme.costa @Guest
                Yesterdays issues were due issues with Sony chips. I have an S9B and I have had a SSU with the same placement and holes of the baro and I haven’t had issues with altitude that I can recall. I always wear the watch over the sleeve but I also pay attention that the fabric is not covering the holes (before running while running I do not pay attention to it). My running partner has an S9B too, he wears it in the left arm and I in the right and we have always very consistent results, as an example today we did intervals, in total 16 km up an down, and my ascent was 73 m and his was 71 m…
                I also have discovered that is better that you let de watch some minutes before start running in the sport screen so Fusialti can do its magic.
                  freeheeler @Guest
                  @g287-sf
                  here’s what the sleeve can do. It’s not basically the case that the sleeve below the watch is bad, it depends on the type of garment and how wet it is.
                  The dark green is with the watch over the sleeve as I usually wear it for any activity. The graph is pretty accurate.
                  The light green is with the sleeve fully pulled over the watch together with a glove causing pressure from the other side… hence, watch tight to the skin. I assume the holes were blocked and towards the end I finally started sweating a tiny bit and that’s why the graph went nuts.
                  living sideways
                  Fenr1rF ? 2 Replies Last reply Reply Quote 1
                  • Fenr1rF Offline
                    Fenr1r @freeheeler
                    @freeheeler Was that earlier research and analysis or off the cuff?
                    freeheelerF 1 Reply Last reply Reply Quote 1
                    • ? Offline
                      A Former User @freeheeler
                      @freeheeler
                      whaouu ! maybe Suunto can do something to “detect” false info and correct it “making a dual analyze” with topo map and Gps data to synchronise them 🤷
                        freeheeler @Fenr1r
                        @fenr1r
                        second 😉
                        living sideways
                          freeheeler @Guest
                          @g287-sf
                          like strava does? …corrected in 2 seconds…
                          living sideways
                          • ? Offline
                            @freeheeler yes as you say buddy, like an other third party does in 2 seconds.
                              freeheeler @Guest
                              @g287-sf
                              I’m a bit scared that we might start hearing: please use 3rd party to see correct altitude in case it was recorded incorrect… similar as when people (including myself…!) started complaining about viewing the activity on a small phone screen instead of computer screen… the mantra was: use 3rd party
                              living sideways
                              ? 1 Reply Last reply Reply Quote 2
                              • ? Offline
                                @freeheeler it’s so easier than listen customer and improve product… I’m sad because i support Suunto since my old Core in 2010 or something like that. I always say to peoplz it’s good tool but actually i’m worried…
                                • First post
                                  Last post
                                Suunto Terms | Privacy Policy
