    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    problems with my S9B
    54 Posts 15 Posters 7.2k Views 13 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • Mff73M Offline
      Mff73 @Luis Duarte
      @Luis-Duarte said in problems with my S9B:
      Running_2020-01-24T08_08_12.fit
      I think this was the first with problems
      In this one, your altitude registered after 10km is really noisy, while quite nice for first 10km.
      Something may effectively have affected baro sensor (sleeve, wind, water, wrist movement,…).
      SSU (retired), SV1, SV2
      Wife : S9PP
      SA: Always the latest beta :)
      Android + Galaxy S205G
      Brad_OlwinB 1 Reply Last reply Reply Quote 1
      • Brad_OlwinB Offline
        Brad_Olwin Moderator @Mff73
        @Mff73 said in problems with my S9B:
        @Mff73 is correct, the noisy data are where the wrong data were recorded. This occurs as I stated early in the thread because of skin or garments blocking/pushing against the sensor. The wind has to be very strong for this to happen. There is likely nothing wrong with the watch.
        Vector/T6c/Vertical 2 Ti
        • Luis DuarteL Offline
          Luis Duarte
          I will test the watch again.
          I will do what you said
          thank you all
          I’ll tell you how it went
          • cosme.costaC Offline
            cosme.costa @Guest
            @André-Faria said in problems with my S9B:
            I believe that @Luis-Duarte has the watch since christmas maybe he has runs without jacket and that this issue may be recurrent.
            If S9B is so sensitive to jackets how runners do?
            You put the watch over the jacket, I least I do that way, of course you can’t use OHR, you need a strap if you want HR readings.
            Luis DuarteL 1 Reply Last reply Reply Quote 0
              Luis Duarte @cosme.costa
              @cosmecosta ok thanks
              if that is the problem it is very bad for a top watch to have such a problem. In winter I can’t use it then. it’s just a summer watch.
              I trained little since March and did not go to the mountain. now these problems have returned.
              isaziI cosme.costaC 2 Replies Last reply Reply Quote 0
              • isaziI Offline
                isazi Moderator @Luis Duarte
                @Luis-Duarte honestly this only happened to me once in over a year, and it was during a walk in storm kinda winds (trees falling down). I used my S9 for running, hiking, skiing, mountaineering, always under a jacket, never had issues.
                Blog: isazi's home
                Luis DuarteL 1 Reply Last reply Reply Quote 1
                  cosme.costa @Luis Duarte
                  @Luis-Duarte I wouldn’t say the it is a summer watch. I use it all the year without issues. Right now you are covering the holes of the sensor making a sealing effect that makes the bad readings, if you use it in the other hand you won’t have this issues (better if you do not use gloves of course).
                  If you use it over the jacket and you do not have HR, is it a killer? I do not think so… But if it is a must for you and you can use a chest or OHR strap you will have the HR readings and surely even more percise, not affected by other factors like WOHR. You can also use the watch under the jacket with the WOHR, there are some brands of apparel that make a nice window for the watch.
                    Luis Duarte @isazi
                    @isazi but your s9 its Baro?
                    isaziI 1 Reply Last reply Reply Quote 0
                      @cosmecosta i have some friends with this whatch and they dont have any problems.
                      So I think the problem is with my baro.
                      but i will try again as you are saying
                      Thanks
                      • Saketo NemoS Offline
                        Saketo Nemo Moderator
                        Just a simple advice: wear it on the right wrist if u use whr 😉
                          Luis Duarte @Saketo Nemo
                          @Saketo-Nemo next training I will do.
                          Thanks
                          • ? Offline
                            A Former User
                            Hello Luis,
                            Just for the sake of it, have you tried re-installing firmware and reset after?
                            Also, after reset, sync with SA, wait about 30min for the agps settle down and before starting waiting for good fix.
                            • isaziI Offline
                              Yes it is.
                              Blog: isazi's home
                                Luis Duarte @isazi
                                @isazi ok 😉
                                  Luis Duarte @Guest
                                  @André-Faria yes i have yestarday
                                  I go to train today
                                    Brad_Olwin Moderator @Luis Duarte
                                    @Luis-Duarte I wear my watch over the jacket or shirt nearly all winter for most of my activities. I rarely if ever have issues with altitude readings. Occasionally yes, but as I stated before that can be due to ferocious winds we can have here in the mountains.
                                      Luis Duarte
                                      Screenshot_2020-11-04-21-24-41-233_com.stt.android.suunto.jpg Screenshot_2020-11-04-21-24-57-573_com.stt.android.suunto.jpg Screenshot_2020-11-04-21-49-14-749_com.stt.android.suunto.jpg Screenshot_2020-11-04-21-49-34-217_com.stt.android.suunto.jpg
                                        Luis Duarte
                                        This was the problem today 😔😔
                                        Not lucky with my whatch
                                        sartoricS Brad_OlwinB 2 Replies Last reply Reply Quote 0
                                        • sartoricS Offline
                                          sartoric Moderator @Luis Duarte
                                          @Luis-Duarte
                                          Who are you? The Flash?
                                          SVTS - 2.50.28
                                          SSSWHR BARO Amber - 2.8.32
                                          Samsung A5 2016 - Android 7.0
                                          Suunto App Android 6.10.7 beta
                                            @Luis-Duarte I have had this problem before, it is rare. One morning I ran from CO, USA to Spain…I too was very fast:)
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
