    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    problems with my S9B
    54 Posts 15 Posters 7.3k Views 13 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • Luis DuarteL Offline
      Luis Duarte
      Hello
      bought my S9B last christmas
      in the first training sessions I had problems with the positive and negative accumulated.
      I sent it to the Suunto factory and they said everything was fine.
      I did some more mountain training and went back to having the same problems.
      I did everything they told me …
      Altitude ok
      Reset soft
      Reset factory
      I sent it back to the factory in February and they say again ir das every thing ok.
      Then came the Pandemic and i stop the mountains.
      Now I started training on the mountain again and I continue with same problems.
      I dont know what to do anymore.
      Can same one helo me?
      Last…
      S9B - 1400D+
      Ambit peak - 450D+
      Sorry for my English
      sartoricS pilleusP 2 Replies Last reply Reply Quote 0
      • sartoricS Offline
        sartoric Moderator @Luis Duarte
        @Luis-Duarte
        To be honest, I didn’t understand what’s the problem.
        I suppose it has something to do with altitude, but, can you link a move or make an example?
        Did you try to search the forum for a similar issue ?
        SVTS - 2.50.28
        SSSWHR BARO Amber - 2.8.32
        Samsung A5 2016 - Android 7.0
        Suunto App Android 6.11.8 beta
        • pilleusP Offline
          pilleus @Luis Duarte
          @Luis-Duarte 450 vs 1400 looks like meters vs feet? 🤔
          https://www.instagram.com/moves.are.life/
          Suunto Vertical Black Lime
          Suunto 9 Peak Pro Black
          Suunto Spartan Ultra Stealth Titanium
          1 Reply Last reply Reply Quote 4
            Luis Duarte
            the problem is the accumulated positive and negative.
            always gives more in long workouts.
            today for example I ran with my 2 watches.
            S9B and ambit 3
            and gave the difference the s9B 1400 with positive accumulation and the ambit 3 450 with positive accumulation.
            • Brad_OlwinB Offline
              Brad_Olwin Moderator @Luis Duarte
              @Luis-Duarte There are two issues that could be causing this. First, if the holes on the S9B are being covered by skin or something else that blocks the baro sensor. I can have this problem if I wear on my right hand, when I flex my wrist it covers the holes and I get wrong readings ±D. Second is wind, if it is very windy and directly hits the baro sensor the ±D can be wrong.
              Vector/T6c/Vertical 2 Ti
                Luis Duarte
                some days I caught wind, but it happened on sunny days and good weather.
                I can try to wear it on my right wrist.
                I did factory reset again.
                if covering the watch with the waterproof can be a problem?
                Thank you for help
                  Luis Duarte
                    Luis Duarte
                    isaziI Mff73M M 3 Replies Last reply Reply Quote 0
                    • isaziI Offline
                      isazi Moderator @Luis Duarte
                      @Luis-Duarte can you try to have your watch under your sleeve and see if anything happen? Or switch position of S9 and A3 next time (so that the baro opening will be blocked for the A3 and not for the S9)?
                      Blog: isazi's home
                      Luis DuarteL 1 Reply Last reply Reply Quote 0
                      • Mff73M Offline
                        Mff73 @Luis Duarte
                        @Luis-Duarte
                        Are you syncing your S9b activities to SuuntoApp with Android smartphone?
                        SSU (retired), SV1, SV2
                        Wife : S9PP
                        SA: Always the latest beta :)
                        Android + Galaxy S205G
                          Luis Duarte @Mff73
                          @Mff73 yes
                          Mff73M 1 Reply Last reply Reply Quote 0
                            Luis Duarte @isazi
                            @isazi ok thanks
                            I’m go to try it
                            • Mff73M Offline
                              Mff73 @Luis Duarte
                              @Luis-Duarte said in problems with my S9B:
                              @Mff73 yes
                              So.
                              there are raw data files you may use and import them in QS, maybe you could see something interesting (registered altitude vs GPS altitude for example)
                              See here where to find this file.
                              https://forum.suunto.com/post/33052
                              Wife : S9PP
                              • M Offline
                                Mi_chael Bronze Member @Luis Duarte
                                @Luis-Duarte
                                As I see. You use a rain jacket for you’re workout.
                                Sadly the hole of barometer sensor of S9 is not at the same place of A3 Peak.
                                I think you’re jacket came to touch the S9 hole during you’re run.
                                Try to use S9 over the jacket. Or on the left wrist but try to don’t touch it with your hand.
                                Luis DuarteL 1 Reply Last reply Reply Quote 2
                                  Dimitrios Kanellopoulos Community Manager
                                  The problem is here
                                  The sensor, comes into contact with the jacket and pushes the sensor.
                                  Creator of quantified-self.io - sync Garmin and COROS activities to Suunto, import Suunto routes, deliver Suunto routes to Garmin courses, and analyze training data in one private dashboard.
                                  ? Luis DuarteL 2 Replies Last reply Reply Quote 2
                                  • ? Offline
                                    A Former User @Dimitrios Kanellopoulos
                                    I believe that @Luis-Duarte has the watch since christmas maybe he has runs without jacket and that this issue may be recurrent.
                                    If S9B is so sensitive to jackets how runners do?
                                    cosme.costaC 1 Reply Last reply Reply Quote 0
                                      Luis Duarte @Mff73
                                      @Mff73 thanks 😉
                                        Luis Duarte @Mi_chael
                                        @Mi_chael 👍👍
                                          Luis Duarte @Dimitrios Kanellopoulos
                                          @Dimitrios-Kanellopoulos I don’t remember training without the raincoat but it is possible that it happened.
                                          I will have attention in the future…
                                          since March I have not run on the mountain again.
                                          now I came back and the problem happened again
                                          But if that is the problem it is a big mistake for a top suunto watch.
                                          I hope to solve the problem
                                          thank you all
                                            Luis Duarte
                                            Running_2020-01-24T08_08_12.fit
                                            I think this was the first with problems
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
