    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Issues altitude diagram
    Scheduled Pinned Locked Moved Spartan
    54 Posts 10 Posters 10.8k Views 10 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • Stefan KerstingS Offline
      Stefan Kersting Platinum Member
      On all of my runs I have problems with measuring the correct altitude. I know the altitude of the start an do a calibration before each run. Calibrating the watch to 5 masl an starting my run results in the following altitude diagram. Up to 26 m below sea level. That’s absolutely not acceptable and I don’t know where the problem is because I calibrate the watch before my activities.
      Instagram: https://www.instagram.com/helgelandsbukken/
      https://www.instagram.com/suunto_adventures/
      IG: Helgelandsbukken, suunto_adventures
      Vimeo: vimeo.com/helgelandsbukken
      Blogg: https://turblogg.midnattsola.com
      • isaziI Offline
        isazi Moderator
        What is your watch? This looks like a watch issue, not an iOS one so I’ll move the topic to the appropriate section.
        For the S9, but probably this is true for Spartans too, calibrating before actually prevents Fusedalti to work properly. I stopped calibrating at all and have much better readings compared to last year.
        Also, if you have never done that, a night soak in lukewarm water helps.
        Blog: isazi's home
          Have a Spartan ultra, but without HR sensor. I wear the watch all the time even when taking a shower isn’t that enough? When you watch shows -36 masl altitude you reccomend not to calibrate before starting a run?
          sartoricS Brad_OlwinB 2 Replies Last reply Reply Quote 0
          • isaziI Offline
            isazi Moderator
            Since learning that calibration interferes with Fusedalti, I calibrate my S9 only if I travel far away (by airplane) and don’t plan to have any activity for few days. Otherwise, even if I know it’s wrong, I rely on the watch figuring out things by itself.
            Blog: isazi's home
            • sartoricS Offline
              sartoric Moderator @Stefan Kersting
              @Stefan-Kersting said in Issues altitude diagram:
              In fact it isn’t, as soaking it in warm water for a while let any dust or soap residue to be removed/washed away, while showering wearing the watch can lead to the opposite result
              SVTS - 2.50.28
              SSSWHR BARO Amber - 2.8.32
              Samsung A5 2016 - Android 7.0
              Suunto App Android 6.11.12 beta
                Dimitrios Kanellopoulos Community Manager
                Also for me looks more of a baro sensor dirty thing. Soap can condense there
                2 things here also for others to know:
                Let the watch soak in water, flush under the tap making sure water goes in / out the pressure sensor holes.
                However and important:
                Do not leave the watch in the water for many hours. The watch is protected and is waterproof but leaving anything into water for a lot of time might affect components errosion etc. That is a personal tip.
                Creator of quantified-self.io - sync Garmin and COROS activities to Suunto, import Suunto routes, deliver Suunto routes to Garmin courses, and analyze training data in one private dashboard.
                1 Reply Last reply Reply Quote 3
                • Brad_OlwinB Offline
                  Brad_Olwin Moderator @Stefan Kersting
                  @Stefan-Kersting i also recommend not calibrating. FusedAlti may not activate if you manually calibrate.
                  Vector/T6c/Vertical 2 Ti
                  Stefan KerstingS 1 Reply Last reply Reply Quote 2
                  • Iván Martín MoraI Offline
                    Iván Martín Mora
                    Hello, how are you? Sorry for this question. But I don’t understand, too well, what is the calibrate option for then?
                    • EgikaE Offline
                      Egika Platinum Member @Iván Martín Mora
                      @Iván-Martín-Mora FusedAlti only weorks well if GPS reception is possible and at a certain quality. In deep valleys it could be not enough for proper altitude calibration. In these cases (or indoors without GPS) it is still possible to calibrate altitude manually.
                        Stefan Kersting Platinum Member @Brad_Olwin
                        @Brad_Olwin without calibration it looks like this. The altitude displayed on the watch before I started it was -19 meters
                        isaziI Dimitrios KanellopoulosD 2 Replies Last reply Reply Quote 0
                        • isaziI Offline
                          isazi Moderator @Stefan Kersting
                          @Stefan-Kersting did you already try to clean the baro sensor?
                          Blog: isazi's home
                            Dimitrios Kanellopoulos Community Manager @Stefan Kersting
                            @Stefan-Kersting what is the altitude you would expect ?
                            0 ?
                            Stefan KerstingS 1 Reply Last reply Reply Quote 0
                              Stefan Kersting Platinum Member @Dimitrios Kanellopoulos
                              @Dimitrios-Kanellopoulos starting at 5 masl. That is 100 percent sure altitude at home
                              Mff73M 1 Reply Last reply Reply Quote 0
                              • Mff73M Offline
                                Mff73 @Stefan Kersting
                                @Stefan-Kersting
                                Android app or iOS?
                                With Android, there are raw data files in phone that can be imported in QS : you could see GPS altitude, and some other data that may help understand if fusedalti worked properly or not, of if GPS signal was good enough.
                                https://forum.suunto.com/post/33052
                                SSU (retired), SV1, SV2
                                Wife : S9PP
                                SA: Always the latest beta :)
                                Android + Galaxy S205G
                                Stefan KerstingS 1 Reply Last reply Reply Quote 1
                                  Stefan Kersting Platinum Member @Mff73
                                  @Mff73 no have iOS. But it could be nice to have information about the signal quality. Maybe a azimuth Display or something like that. But I don’t know if the problem lies there
                                    Did everything you guys recommend. Used Auto calibrate, manual calibrating, had the watch for half an hour in warm water. But when your supposed to start at 4 masl and finish at masl this result is absolutely unacceptable 👿
                                        @Stefan-Kersting It could be the sensor is faulty too, hard to say.
                                        Stefan KerstingS 2 Replies Last reply Reply Quote 0
                                          @Brad_Olwin when Auto calibrating, do you get a confirmation? I just have this screen even when outside and trying to auto calibrate
                                          Dimitrios KanellopoulosD sartoricS 2 Replies Last reply Reply Quote 0
                                            @Stefan-Kersting I think no on Spartans. However you can set the altitude to 1000m and check if its changed
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
