    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    SSWHR Baro - Multisport "Distance" vs "Current activity distance" view
    Scheduled Pinned Locked Moved Spartan
    6 Posts 2 Posters 1.2k Views 2 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • zadowZ Offline
      zadow
      Hi all, I am doing a Multisport activities quite often. My most widely setup is that I Ride first and then Run. For a run activity I created a Custom Run mode. On one screen there I have a field with “Current activity distance” and on another screen there is a “Distance” field. Well. What is the difference between them? Every time, when I Ride and then Run, both of these fields reports the same value: ride distance + run distance. I expected that the field “Current activity distance” would display distance for Run only but that is not a case. Is this a bug or feature? If it is a feature, what is the purpose to have to differently names fields which shows the same value? Or am I missing something and using it in wrong way?
      Many thanks in advance for any help/recommendations! 🙂
      Suunto Race
      Suunto S9 Baro Titanium, Ironman l.e. (607/1406)
      Suunto Smart Sensor
      Wahoo Tickr FIT
      Hammerhead Karoo 2
      Swim Ride Run Rest Repeat
      • sartoricS Offline
        sartoric Moderator
        I’m 100% sure that when multisporting 😄 using base sport modes, duration and distance (walk,run at least) show the current activity data.
        I’ll try with 2 custom sports, by chance I never used my custom sets for multisport
        SVTS - 2.50.28
        SSSWHR BARO Amber - 2.8.32
        Samsung A5 2016 - Android 7.0
        Suunto App Android 6.11.8 beta
        • sartoricS Offline
          sartoric Moderator
          just done a very quick test using the 3 fields
          • duration
          • duration current activity
          • duration previous activity
          and it works as expected
          which app version do you use ?
          Try to create a new custom mode, maybe the one you’re using is corrupted or it was made when that field was bugged (I remember something but I’m not sure)
          PS
          Yes I didn’t use DISTANCE 🙂
          SVTS - 2.50.28
          zadowZ 2 Replies Last reply Reply Quote 1
          • zadowZ Offline
            zadow @sartoric
            @sartoric Hm, re-creating sport mode could help, you are right. In the past I had to recreate some sport mode due to malfunctioning and it helped. So, I’ll try to re-create it and will see.
            Thanks for the hint!
            Suunto Race
            Suunto Smart Sensor
            Wahoo Tickr FIT
            Hammerhead Karoo 2
            • zadowZ Offline
              zadow @sartoric
              @sartoric Hi, so I did re-create custom sport mode, and tested it yesterday and it worked. Now I am happy again and I can do my crazy multisports 🙂
              Suunto Race
              Suunto Smart Sensor
              Wahoo Tickr FIT
              Hammerhead Karoo 2
              sartoricS 1 Reply Last reply Reply Quote 1
              • sartoricS Offline
                sartoric Moderator @zadow
                @zadow
                you’re welcome
                … I forgot to write here that I tested DISTANCE outdoor yesterday and it worked as expected 😁
                SVTS - 2.50.28
                Register Login
                • First post
                  Last post
                Suunto Terms | Privacy Policy
