    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Creating POIs on Movescount web page
    Scheduled Pinned Locked Moved Ambit
    poiambit3movescount
    15 Posts 6 Posters 3.0k Views 6 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • D Offline
      dzemrau
      For some reason, I am not longer able to create POIs in Movescount. Is one else having the same problems?
      zvonejanZ PrenjP ThomasRT 3 Replies Last reply Reply Quote 2
      • zvonejanZ Offline
        zvonejan Bronze Member @dzemrau
        @dzemrau
        yes, you are correct
        • PrenjP Offline
          Prenj @dzemrau
          @dzemrau same here.
          Suunto Race
          • M Offline
            margusl
            When creating a POI, fill in the Altitude field by yourself, this will enable the Save button.
            PrenjP D 2 Replies Last reply Reply Quote 1
            • PrenjP Offline
              Prenj @margusl
              @margusl said in Creating POIs on Movescount web page:
              Thanks! It works.
              Woo-hoo another third party tool needed!
              Lets see what we need in order to use our watches like we used to before with movescount only (a3p user’s perspective):
              • Basic on the go analysis of activities - Suunto app
              • Detailed analysis on big screen - qs, Runalyze, Training peaks etc.
              • Creating a movie - Relive
              • Social networking - Strava, adidas runing etc.
              • Route drawing on big screen with altitude profile and waypoints that can be imported in movescount - Plotaroute
              • Finding out altitude of a POI to add it to Movescount - Daftlogic - google maps find altitude on map
              • And all the settings, sport modes customization, route import, adding POI-s etc. - computer with internet connection and cable to sync
              Keep up the great work Suunto!
              Suunto Race
              M 1 Reply Last reply Reply Quote 3
              • M Offline
                margusl @Prenj
                @Prenj , I must say I didn’t even think of a possibility that someone might care about correct altitude there. What’s the difference when using just 0 or any other random value for POI altitude? Can you even see POI alt. from the watch?
                And I really don’t think it use to be consistent, I went though all my past POIs and only 2 had altitude set to something else but 0m, all the rest looked like this:
                8410acc6-c74d-4fc5-a785-e66edaf9fb6a-image.png.
                Now MC just fails to fill it with a default “0” . Well, there is a slight chance that I’ve imported most of my existing POIs though some other means. I tend to clean this list from time to time, so I can’t see every single one I’ve had in MC.
                Had I ever missed that alt. value, I guess would have just added it manually from labeled contour lines from that same Mapbox terrain map, 1000m for the one above.
                PrenjP 1 Reply Last reply Reply Quote 0
                • Stefan KerstingS Offline
                  Stefan Kersting Platinum Member
                  I think you have to specify altitude because if you use POI for navigating the watch has different functions i navigation modus as ETA, ETE and also how many meters up/down it is to you destination.
                  Instagram: https://www.instagram.com/helgelandsbukken/
                  https://www.instagram.com/suunto_adventures/
                  IG: Helgelandsbukken, suunto_adventures
                  Vimeo: vimeo.com/helgelandsbukken
                  Blogg: https://turblogg.midnattsola.com
                  • zvonejanZ Offline
                    @Stefan-Kersting @margusl
                    I think it is a bug connected with missing altitude in movescount. Maybe I am wrong
                    Stefan KerstingS 1 Reply Last reply Reply Quote 0
                      Stefan Kersting Platinum Member @zvonejan
                      @zvonejan I have always punched the altitude manually and it works fine
                      • PrenjP Offline
                        Prenj @margusl
                        I just checked and the POI altitude is not visible in A3P and the watch ignores it when calculating distance to it. But, I checked all my POI-s and I only found one without altitude. Not sure why that one had 0.
                        Strange. I was under impression the altitude would be used to calculate with 3d distance, but that seems to work just in sport modes? Not sure why Movescount had this field in the first place and why was it obligatory to enter altitude if it’s not used at all then?! Maybe they planed to add the 3d distance for POI-s at some point? That would make sense for mountains… Or they just had this field so you could add POI from watch itself. That info would be meaningful to some people.
                        Anyway, it should be an easy fix, but I’m getting increasingly annoyed by how slow Suunto is dealing with the problems with their software.
                        Suunto Race
                        M 1 Reply Last reply Reply Quote 0
                        • M Offline
                          margusl @Prenj
                          @Prenj , I believe it’s there mostly for POIs that are pulled from the watch - if I went through trouble of saving my location (at least 8 button presses without using a shortcut, just checked), I’d prefer to save it with current altitude.
                          • PrenjP Offline
                            Prenj @margusl
                            Probably. The problem is that it doesn’t work (at least ATM). I added current location as POI in the watch and synced it with movescount. POI in movescount had altitude of 0. It would be logical that watch stores this info and syncs it back to movescount web, but it doesn’t, which brings us back to the first question - why is this field there in the first place and why is it obligatory?
                            Suunto Race
                            • D Offline
                              dzemrau @margusl
                              @margusl I tried that with the Google map option and it did work. Now the Mapbox option is missing.
                              • ThomasRT Offline
                                ThomasR @dzemrau
                                I have the same Problem. New POI’s can not be created on movescount. Why can one not create POI’s within the app?
                                • D Offline
                                  dzemrau
                                  Try adding an altitude to the POI on Movescount web page.
                                  Register Login
                                  • First post
                                    Last post
                                  Suunto Terms | Privacy Policy
