    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    GPS bugs on Suunto9
    86 Posts 19 Posters 20.7k Views 20 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • Łukasz SzmigielŁ Offline
      Łukasz Szmigiel @Lukasz Berdowski
      @Lukasz-Berdowski I usually stick with galileo. In dense forests and mountains glonass is also handy. Beidou seems to give the best response (quickest to get back on track) after track accuracy degenerates but also gives me strange offsets. Also I don’t find it so good in woodlands. Generally with latest firmware, in the open, plain gps is more than enough. But the error gets pretty significant as soon as I enter wooded area so I usually use galileo - the error is there but it’s more like an offset than a zigzag.
      I’ve been also setting a description of which GNSS I use in my workouts to have a better look on it and more data.
      S9PP 2.50.28
        Dimitrios Kanellopoulos Community Manager
        Fused track is 100% off on best mode.
        We had that on before the watch got into production and the results were bad because in many cases the compass is not calibrated.
        I have seen your tracks. They are not good. I also wonder why.
        Creator of quantified-self.io - sync Garmin and COROS activities to Suunto, import Suunto routes, deliver Suunto routes to Garmin courses, and analyze training data in one private dashboard.
          Łukasz Szmigiel
          There is definitely some magic going on with how watch interprets raw signals from GPS sensor which may lead to issues in rare conditions. For example, when stationary, S5/S9 doesn’t draw motion - there are no weird shapes being drawn on map (which isn’t the case with Garmins, for example, as they’re constantly drawing).
          So there must be some filtering which may be failing in certain conditions (as in this post). It’s hard to guess without knowing the actual methods Suunto is using. By analyzing my own tracks I’m guessing FusedSpeed is influencing the recording (if pace is prioritized over GPS accuracy) but it manifests itself with track offsets (that are constant until change of directions). But that’s my guess anyway.
          Also, in my experience, the longer the run, the better the path being drawn - perhaps there’s some room to optimize this behavior?
          S9PP 2.50.28
          Dimitrios KanellopoulosD 1 Reply Last reply Reply Quote 0
            Dimitrios Kanellopoulos Community Manager @Łukasz Szmigiel
            @Łukasz-Szmigiel The “not-draw” when static is Sony magic.
            Łukasz SzmigielŁ 1 Reply Last reply Reply Quote 2
              Łukasz Szmigiel @Dimitrios Kanellopoulos
              @Dimitrios-Kanellopoulos cool. I thought it’s Suunto’s algo. So the chip doesn’t even provide raw data? It’s always processed?
              S9PP 2.50.28
                @Łukasz-Szmigiel I am not sure about that, but I can say that the chip indeed does a lot on it’s own.
                • Lukasz BerdowskiL Offline
                  Lukasz Berdowski
                  Hey Guys, I just did a new run, results are much better, while still not perfect, I can live with it 🙂
                  I did a soft reset, updated gps via app, waited 15 minutes, then acquired the gps signal and waited additional 3-5min.
                  The run was tracked with GPS & Galileo.
                  sartoricS Łukasz SzmigielŁ Dimitrios KanellopoulosD 3 Replies Last reply Reply Quote 4
                  • sartoricS Offline
                    sartoric Moderator @Lukasz Berdowski
                    @Lukasz-Berdowski
                    this one looks good.
                    Consider that the “worst” parts are really into the woods
                    SVTS - 2.50.28
                    SSSWHR BARO Amber - 2.8.32
                    Samsung A5 2016 - Android 7.0
                    Suunto App Android 6.11.8 beta
                    Lukasz BerdowskiL 1 Reply Last reply Reply Quote 0
                      Lukasz Berdowski @sartoric
                      @sartoric thank you, I agree. I will keep testing, nad hopefully the above mentioned process will not dissapoint 🙂
                      Also, I felt very slight singular vibrations on the watch more or less where the biggest inconsistencies are. Maybe the GPS is loosing conncetion and recconecting or something? It happens every time on this track. But there is no message being displyed
                      sartoricS 1 Reply Last reply Reply Quote 0
                      • sartoricS Offline
                        @Lukasz-Berdowski said in GPS bugs on Suunto9:
                        Are you navigating a route ? Could be the “off route” message
                        there is also the chance that the path slightly changed compared to the satellite photo as both tomtom and s9 track it on the right (the upper left section)
                        SVTS - 2.50.28
                          @Lukasz-Berdowski this looks pretty ok. You can also try glonass, its satellites have different inclination than GPS and Galileo and there are (usually) more sats available than Galileo so it may also be helpful in dense forests.
                          I also wonder how will the recorded path look like if you reverse directions?
                          S9PP 2.50.28
                            Dimitrios Kanellopoulos Community Manager @Lukasz Berdowski
                            @Lukasz-Berdowski what hand do you wear the watch ?
                            And what’s the direction of the route I see ? Clock or counter clockwise ?
                            Łukasz SzmigielŁ 1 Reply Last reply Reply Quote 0
                              @Dimitrios-Kanellopoulos I think it’s clockwise, notice the km numbers.
                              S9PP 2.50.28
                                Lukasz Berdowski
                                Left hand and the direction is clockwise. There is no track navigation on. When I look at the menu, there is ‘breadcrumbs’ selected.
                                I will try to run the other direction next time, I am very curious about the result 🙂
                                  @Lukasz-Berdowski or just chnage hands.
                                  If you are doing clockwise and left hand then if you also are more close to the left part of the road (typically you ain’t you are right for clockwise eg pavement) it’s more blocked the signal.
                                  Lukasz BerdowskiL 1 Reply Last reply Reply Quote 2
                                    Lukasz Berdowski @Dimitrios Kanellopoulos
                                    @Dimitrios-Kanellopoulos good tip! I will let you guys know in a few days how it went
                                    • darxmurfD Offline
                                      darxmurf Platinum Member
                                      Hi all,
                                      Just to add my touch on this topic, I’m pretty happy with my Suunto 9 baro but every time we hike with my girl friend, there is between 300 and 500m of difference with my watch and her garmin forerunner, even if we start/stop our watches at the same time and follow the exact same path.
                                      https://www.instagram.com/darxmurf/ - https://www.instagram.com/omch.swiss/
                                      freeheelerF suzzloS Saketo NemoS 3 Replies Last reply Reply Quote 0
                                      • freeheelerF Offline
                                        freeheeler @darxmurf
                                        @darxmurf
                                        in altitude or distance?
                                        living sideways
                                        darxmurfD 1 Reply Last reply Reply Quote 0
                                        • suzzloS Offline
                                          suzzlo Moderator @darxmurf
                                          @darxmurf Garmin model ? (I mean, Garmin Forerunner with barometer?)
                                          BR
                                          Suunto: Race, S9Peak, Spartan Sport Wrist
                                          Garmin: FR745, Edge 530
                                          SA topics:
                                          • Guides - https://forum.suunto.com/tags/guides
                                          • Saketo NemoS Offline
                                            Saketo Nemo Moderator @darxmurf
                                            @darxmurf
                                            is which one should be correct? Can you share both activity links?
                                            darxmurfD 2 Replies Last reply Reply Quote 0
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
