    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    GPS bugs on Suunto9
    86 Posts 19 Posters 18.7k Views 20 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • Brad_OlwinB Offline
      Brad_Olwin Moderator @zhang965
      @zhang965 Sorry I had to cut you off with that one. We did not want the marketplace issue to get started. I was a funny comment. We won’t remove it from this thread:)
      Vector/T6c/Vertical 2 Ti
      1 Reply Last reply Reply Quote 3
      • B Offline
        bastpp @Saketo Nemo
        @Saketo-Nemo I just tried GPS + Beidou today and indeed it was really more precise :
        So I will keep this configuration and I hope it will work well again !
        (but the elevation was still very underestimated though…)
        Thanks for your help !
        Saketo NemoS 1 Reply Last reply Reply Quote 3
        • Saketo NemoS Offline
          Saketo Nemo Moderator @bastpp
          @bastpp
          Happy to see that! 😉
          • Cuba1hrC Offline
            Cuba1hr
            Hi guys, I came to check the new posts here, not much was happening. I was thinking (hard) about Fenix 6 Pro and Grit X for a replacement for my ex S9B. I was also looking at S7 at one point, but even shorter battery life and 2 platforms (Suunto and GoogleFit)…it is a nice watch but not replacement for S9.
            I went the same road for a walk yesterday again for the first time with the Grit X, and results were almost perfect, following the road with the same Sony GPS chipset S9B has. V800 and Grit X were within 10 meters out of each other in total distance in shorter and longer walk, with nicely laid track. That’s with Galileo, maybe even better results I’ll get with Glonass next time as I read. No Beidou available for now.
            So far, so good, but now I miss a couple of things from S9B. I knew that when I didn’t opt for F6Pro - compass and altimeter outside activity, temperature visible on the watch, sunset time, goal with calories set, backlight completely off (during buttons presses), etc.
            Most of those things can be sorted out with the updates and I will keep watching which Finnish team, if and how soon, will bring some news and updates on those watches…or just offer a new one. G2, S11 or SX in case of Suunto…I am also interested if the Polar’s Vantage series will get any more updates. Everyone’s so mysterious about the updates suddenly.
            • Lukasz BerdowskiL Offline
              Lukasz Berdowski
              Hey, since my topic was closed for creating another ‘bad gps’ topic, I will ask for help here. Please find my route attached. Red is how it is supposed to be - blue is what suunto 9 baro has measured. I run this one 3 times per week and tested every possible gps setting. It is always updated and I huse the best performance setting. I have it paired with suunto HR strap - but doubt it is the problem.
              This example shows around 400 meters being cut from my route.
              Any suggestions?
              zvonejanZ Brad_OlwinB freeheelerF 3 Replies Last reply Reply Quote 0
              • zvonejanZ Offline
                zvonejan Bronze Member @Lukasz Berdowski
                @Lukasz-Berdowski
                This is forest, how the hell you know how it should be :)? Do this, run 5 time in the sam track and if tracks are the same, then your red is wrong
                Lukasz BerdowskiL 1 Reply Last reply Reply Quote 0
                  Brad_Olwin Moderator @Lukasz Berdowski
                  @Lukasz-Berdowski What satellites are on? There are some experiencing issues with Beidou.
                  • freeheelerF Away
                    freeheeler @Lukasz Berdowski
                    @Lukasz-Berdowski
                    is your watch on the latest fw, too?
                    living sideways
                      Lukasz Berdowski @zvonejan
                      @zvonejan I run this route 3 times per week for 5 years now… I know where I run 😉 See those semi transparent lines? Those are paths. The same paths are below the red line. I attach a screenshot from my run with different watch (tomtom spark) whitch was almost perfect. I havt lots of those. The only tracker that does weird shit is Suunto 9 Baro… trasa 2.JPG
                      Fenr1rF 1 Reply Last reply Reply Quote 0
                        Lukasz Berdowski @freeheeler
                        Brad & Tele-Ho, thank you for your answers!
                        My current firmware is: 2.11.38
                        I tried beidou, galileo, glonass but all of them are performing poorly 😞
                        • Fenr1rF Offline
                          Fenr1r @Lukasz Berdowski
                          @Lukasz-Berdowski Do all/most of the tracks (from whatever tracker) have the NE deflection from that first RH bend through to around the 2km mark?
                            Lukasz Berdowski
                            yes, while being less notable than suunto’s, it exists. The Entire area between 1 and 2,5 km gives trouble.
                            One thing I want to stress - suunto is very accurate on runs/walks/bike trainings in the city. The issue exists when being around trees. I did couple of runs in another city - the tracking was great up until i hit a park. Then it went haywire 😉
                            • Fenr1rF Offline
                              @Lukasz-Berdowski Right. So. Going by your summary of repeated observations and perhaps as many as four Google Streetview shots …
                              Clearly each watch is happier with tree-partheid. From the tracks shown, both devices lose it in areas of mixed deciduous (light green in sat pic. Ash? Birch?) and evergreen (dark green: a fir of some sort?). Without the mix (NE), or with the species segregated (SE), they do better/fine. The TomTom is obviously less disconcerted by arboreal mixing. The Suunto freaks out when almost wholly surrounded by evergreens and takes some time to recover.
                              Different tree types’ interference may be a thing. If the S9B has a clever compensatory algorithm for adjusting to/anticipating GNSS signal quality, the varying mixture might cause more knock-on problems than the clear division.
                              (Or it might be track width and overhead foliage density. Or something else entirely.)
                              Łukasz SzmigielŁ 1 Reply Last reply Reply Quote 0
                              • Łukasz SzmigielŁ Offline
                                Łukasz Szmigiel @Fenr1r
                                @Fenr1r trees are always problematic in terms of GNSS accuracy but I’ve never (well once the watch got completely bananas but it was with older FW) observed such problems in my S5. If there is a problem it typically manifests itself with offset which is pretty much constant (ie. 10 - 20 meters off) untill I change direction or signal improves (opening in the tree line, etc.) and this is ok.
                                But the image attached by @Lukasz-Berdowski indicates a rather big error in first 2 km of run.
                                @Lukasz-Berdowski have you tried soft reset, fresh AGPS sync, 15 minutes to unpack AGPS and then ~60 seconds on open area after acquiring fix?
                                S9PP 2.50.28
                                Fenr1rF 1 Reply Last reply Reply Quote 3
                                • Fenr1rF Offline
                                  Fenr1r @Łukasz Szmigiel
                                  @Łukasz-Szmigiel Could the S5 be dumber? Presumably (a tiny bit) more like the TomTom? The S9 suffers from its own post-processing cleverness?
                                  Trees - yup. In the image, the wild errors really correlate with the tracks’ (in-)visibility to Google’s aerial photography (whenever in 2020 that happened): i.e., sufficient overhead coverage. That might be enough.
                                  A bit boring and perhaps not applicable to that SE stretch from 4km, so I added the tree type factor. The SE track is partially visible but that’s still sort of a canyon effect so sat geometry is trickier for a regularly acquired series of good fixes.
                                  Again: might be utterly irrelevant.
                                  Łukasz SzmigielŁ 1 Reply Last reply Reply Quote 1
                                    @Fenr1r S5 / S9 use the same GNSS chip don’t they? S5 is supposed to be better in terms of signal reception due to external antenna but it’s hard to judge without debug data (raw data from sensor).
                                    Also, could it be related to FusedTrack? Or is it deactivated in performance mode?
                                    S9PP 2.50.28
                                    Fenr1rF 1 Reply Last reply Reply Quote 1
                                    • Fenr1rF Offline
                                      @Łukasz-Szmigiel said in GPS bugs on Suunto9:
                                      Just what I was wondering re prediction/compensation. S5/S9 - same firmware using that same chip in the same way, whether or not FusedTrack active?
                                        @Fenr1r there’s no FusedTrack in S5. The question is - is it hardcoded that FusedTrack is disabled in performance mode or does it activate automatically if GNSS signal is poor?
                                        S9PP 2.50.28
                                        • Fenr1rF Offline
                                          @Łukasz-Szmigiel And it’s a good question. And if the answer is Yes (=> No to the second part): is there anything else that S9 might be doing that might be particularly affected by type of canopy? Anything that your S5/L-B’s TomTom Spark wouldn’t?
                                            Lukasz Berdowski
                                            Wow guys, thank you so much for trying to help me understand the problem 🙂 To be honest, I don’t know if the fusedtrack is active or disabled while being on the Performance mode. If yes, that would certainly be a good explanation.
                                            @Łukasz-Szmigiel I havent done the reset, just the final 2 steps. By the way, I assume you are in Poland too, what GPS mode do you find to be the most accurate?
                                            There is one more thing - sometimes I feel a very small, almost unnoticable watch vibration (lasting maybe a 0,5 sec) during runs but there is no message on the watch face. I was reading somewhere however, that that is the barometer
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
