    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Suunto 9 - Fitness level doesn't work
    17 Posts 6 Posters 1.8k Views 6 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • D Offline
      Denis_Bevi
      Hello everybody,
      3 weeks ago I bought my Suunto 9 and I started to use it during my workout at gym, walking and running.
      For recording the fitness level the watch show me the instruction that I’ve to record an activity of 15 minutes of walking or running with GPS and Cardio frequency meter, I did this 2/3 times going running for 30/40 minutes, but the watch never showed me the fitness level, it always show me the instruction to explain me how to do.
      Someone knows what have I to do?
      Thanks for your answers, have a nice day.
      Denis
      isaziI ? 2 Replies Last reply Reply Quote 0
      • isaziI Offline
        isazi Moderator @Denis_Bevi
        @Denis_Bevi already discussed many times in the forum, but I’ll give you a summary (and you can search for more). Have you setup your zones, max, and rest HR? Do it. Then run with a bit of variability, to get in different zones, and it should work. For some people it works during their first run, other people need more runs until the algorithm is triggered, must depend on how you and different people train.
        Watch: Suunto Vertical Ti
        Blog: isazi's home
        D 1 Reply Last reply Reply Quote 0
        • ? Offline
          A Former User @Denis_Bevi
          @Denis_Bevi Did you run the whole time? Outside? Did you have good GPS reception in the area? Did you have good and consistent OHR measurements? Was the ground flat or mostly flat?
          Firstbeat VO2 Max algo is optimized for roughly flat terrains, requires decent GPS and heart rate, and I think some stretches of running. If your pace varies too much because you hit a hill, or you do run-walk thing, it might be thrown off.
          I’d do a soft reset of the watch and try again.
          @isazi Not sure Firstbeat cares much about zone setup. And I definitely would recommend against varying the pace too much. Steady comfortable pace should do. Otherwise, your HR will be all over the place, which isn’t a good thing in Firstbeat book.
          isaziI 1 Reply Last reply Reply Quote 0
          • isaziI Offline
            isazi Moderator @Guest
            @NickK thought hitting higher zones was required for triggering the algorithm the first time, as discussed in the forum previously.
            Blog: isazi's home
            • ? Offline
              A Former User @isazi
              @isazi It depends on definition of higher I suppose. 70% MHR? 80%? I know I always got VO2 Max calculated on steady 70-80% efforts with no issues, either Suunto or Garmin.
              Pushing too hard might be counter-productive because it will result in higher overall average HR and lower VO2 Max as a result. Yes, things will adjust on subsequent runs, but why give Firstbeat a pleasure to beat you down? “Hello Suunto support! I’m a 25 year old Olympian, but your watch is saying I’m 67 and eligible for Social Security!” 😫
              D isaziI 2 Replies Last reply Reply Quote 0
              • D Offline
                Denis_Bevi @Guest
                @NickK thank you so much for your answer, your time and explanation, sincerely I’m a beginner with my watch 😅 I’ll try to follow your instructions! Great man 💪🏻
                • D Offline
                  Denis_Bevi @isazi
                  @isazi oh sorry, I didn’t read it was already discussed on forum! Anyway, thank you so much for your answer, your time and explanation, sincerely I’m a beginner with my watch 😅 I’ll try to follow your instructions! Great man 💪🏻
                  isaziI 1 Reply Last reply Reply Quote 1
                  • isaziI Offline
                    @NickK yes, I would consider 70-80% right higher zones already 🙂 With a run of this kind the algorithm should be triggered.
                    Blog: isazi's home
                    • isaziI Offline
                      @Denis_Bevi feel free to share your progress here, so we can help you solve all issues!
                      Blog: isazi's home
                      • Stefan KerstingS Online
                        Stefan Kersting
                        I recognized that vo2 doesn’t measures in hiking mode. Are there several walking modes vo2 doesn’t work? Is it right that you have to walk faster than 4 km/h in order to calculate vo2 max?
                        Instagram: https://www.instagram.com/helgelandsbukken/
                        https://www.instagram.com/suunto_adventures/
                        IG: Helgelandsbukken, suunto_adventures
                        Vimeo: vimeo.com/helgelandsbukken
                        Blogg: https://turblogg.midnattsola.com
                        • isaziI Offline
                          isazi Moderator @Stefan Kersting
                          @Stefan-Kersting in hiking mode it detects VO2max for me. The S9 I mean.
                          Blog: isazi's home
                          Stefan KerstingS 1 Reply Last reply Reply Quote 0
                            Stefan Kersting @isazi
                            @isazi I see there’s a difference between waking and hiking. When you use walking vo2 is calculated, not when hiking.
                            kabziorK 1 Reply Last reply Reply Quote 0
                            • kabziorK Offline
                              kabzior Bronze Member @Stefan Kersting
                              @Stefan-Kersting said in Suunto 9 - Fitness level doesn't work:
                              S9B calculates VO2Max during hiking for me every time… it says I’m ~30 years older than I really am, but hey - it’s still a calculation 🙂
                              Stefan KerstingS 1 Reply Last reply Reply Quote 1
                                Stefan Kersting @kabzior
                                @kabzior when using this sports mode it doesn’t 01183496-4C3F-4BDE-88A4-FF224D3A9827.jpeg
                                • isaziI Offline
                                  @Stefan-Kersting in the English watch menu this may be “trekking” and not “hiking”, and I haven’t tried that. I can confirm only that the “walking” and “hiking” have VO2Max.
                                  Blog: isazi's home
                                  • sartoricS Offline
                                    sartoric Moderator
                                    That’s trekking indeed
                                    This is hiking
                                    SVTS - 2.44.52
                                    SSSWHR BARO Amber - 2.8.32
                                    Samsung A5 2016 - Android 7.0
                                    Samsung A33 2022 - Android 15 - One UI 7.0
                                    Suunto App Android 6.4.6 beta
                                    Suunto App IOs 3.5.0 (20762) beta on MBP M1
                                      @isazi don’t have the English version but that’s the icon 😉 have to try the other walking sports modes then 🙂
                                      • First post
                                        Last post
                                      Suunto Terms | Privacy Policy
