    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Battery LIfe
    Scheduled Pinned Locked Moved Suunto 7
    450 Posts 54 Posters 198.6k Views 55 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • Brad_OlwinB Offline
      Brad_Olwin Moderator @luca760101
      @luca760101 In Airplane mode with the firmware you now have, I get 6-9h in Best GPS and 14-19h in Good GPS. If you load a route that will reduce battery life and a lot of time on the map page will reduce battery life. These are averages that I have had over the last 3 or 4 months.
      Vector/T6c/Vertical 2 Ti
      • JorgeFDJ Offline
        JorgeFD
        Battery for today trail running session:
        Offline mode
        10 seconds
        Following a route
        Playing a lot with maps
        20km and 3 and a half hour plus 30’ paused
        From 100% to 57%
        masi0M 1 Reply Last reply Reply Quote 2
        • macdavM Offline
          macdav Bronze Member
          Today 4:30h of golf. 10 sec interval and more than half of battery remain. Good job Suunto!
          • masi0M Offline
            masi0 @JorgeFD
            @jorgefd78 this is indeed impressive!
            • M Offline
              Mi_chael Bronze Member
              4h of cycling with gps set at best (1s) 30% of battery down.
              Nice 👍
              • masi0M Offline
                masi0
                As my Suunto is 2 day old I had no time to measure the battery entirely, however it lasted 1.5day when I connected it to the charger with 25% left. It was normal use with one test run (with 10% battery use during 30 minutes of GPS)
                Today I did similar run with 10s GPS - only 4% drop. Nice!
                The only concern I have is that when watch is fully charged, it quickly drops battery to 98%, then its fine. Any ideas?
                sartoricS 1 Reply Last reply Reply Quote 0
                • sartoricS Offline
                  sartoric Moderator @masi0
                  @masi0 said in Battery LIfe:
                  A drop to 99/98 is almost normal due to the rounding of the battery manager. As soon as you disconnect it from the charger, the numbers drop (eg. 99.9 or 98.9) depending on full charge percentage (sometimes it simply indicates 99 instead of 100, but it’s common battery charging “no issue”)
                  SVTS - 2.50.28
                  SSSWHR BARO Amber - 2.8.32
                  Samsung A5 2016 - Android 7.0
                  Suunto App Android 6.11.12 beta
                  1 Reply Last reply Reply Quote 3
                  • Zab_55Z Offline
                    Zab_55
                    Hi there ,
                    I’m new Suunto 7 owner from this day , and I need your help straight.
                    I’ve been waiting if Suunto make the update for battery life before I buy the S7, they did -> I bought.
                    But here comes the disappointment tbh. I charged it , set it, updated all the preinstalled apps and watch itself and there it comes. The battery percentage is going down crazy. I turned off Wifi, turned off AOD, NFC, just let the Bluetooth on with battery saver tilt.
                    Here is the picture how it went down with literally no use at all (watching movie with watch on my hand with occasional tilt to check the battery level)
                    I’m iPhone user and was wondering if there might be some issue with setting my Location permissions for “always allow” and it’s using GPS all the time ?
                    I tried factory reset and it did not help at all (screenshot is taken after factory reset)
                    I installed only Spotify but did not even open it.
                    Might there be issue with apps installed on the iPhone (Suunto, WearOS, Google fit - all I have) with possible data transfer and sync ongoing event though I do not use the watch ?
                    I did not turn the Bluetooth off since it is irrelevant for testing the battery life when I want to get notifications (did not receive any though)
                    I’ve read everything in this topic and used the same settings as you guys did.
                    Bit off topic, should I have GoogleFit app installed or they made finally Suunto app collect all the data ?
                    What output on your charger do you use please ?
                    Many thanks for your help and sorry if there are some mistakes in the text.
                      Brad_Olwin Moderator @Zab_55
                      @Zab_55 If it is new you may be getting a lot of updates. Wait for a week or so for the watch to be stable. I am an iPhone user and you can target the notifications you want to appear on the watch by targeting notifications on the Lock Screen on the iPhone. That may reduce the battery drainage. I only allow emails from VIPs to notify, otherwise I would have an email notification every couple of minutes…The battery improvements implemented by Suunto are more for exercise and less for all day as a smartwatch.
                      Zab_55Z 1 Reply Last reply Reply Quote 0
                      • Zab_55Z Offline
                        Zab_55 @Brad_Olwin
                        @Brad_Olwin
                        Thank you for your reply ! So is there possibility that the battery will “break in” after some charges and discharges ?
                        I allow only emails and SMS , so it means just a few notifications to none during the day.
                        Anyway , should I have WearOS and Suunto app has set for always allow (Location) ?
                          @Zab_55 The battery will not break in but there are a lot of updates occurring when you start the watch up. The watch faces with the best battery usage are the Suunto faces. It will get better. Let us know if you have other issues. I have mine set for always allow to permit localization for weather, maps, etc.
                          Zab_55Z Jamie BGJ 2 Replies Last reply Reply Quote 0
                          • Zab_55Z Offline
                            Zab_55 @Brad_Olwin
                            @Brad_Olwin thank you again. It seems to be better today , so hopefully I’ll reach good battery life from now on.
                            One more thing , from settings , I have BT on and Location (from phone and watch)as well - I’m wondering if this setting is necessary and if it’s not draining battery since it uses GPS ? . I mean if it isn’t enough to use location from phone only.
                            If I switch that off , will S7 automatically start using GPS when I start some activity ?
                            Thanks !
                            • Jamie BGJ Offline
                              Jamie BG Bronze Member @Brad_Olwin
                              @Brad_Olwin I disagree with you on the battery. I feel wear os is a bit like Android and it does take a couple of days to a week or two for it to bed down.
                              It also doesn’t tend to help that or usage in this period often isn’t normal usage as we test, check and try out features. I.e. use isn’t normal.
                              • masi0M Offline
                                masi0
                                Honestly I am very supprosed how good battery is with S7. I had 2x 30m runs since taking watch from the charger. Suunto indeed did a great work with WearOS optimization.
                                • Zab_55Z Offline
                                  Zab_55
                                  This night, I switched off WiFi, BT, NFC, Location manually instead of going in airplane mode. As well switched off gestures instead of going in theater mode (I’m unable to switch alarm off in Th.mode) and my battery went from 81% to 77% 🙂
                                  Anyway Location (from phone and watch) is necessary for everyday use ? I mean, activity itself is using GPS even if it is switched off, so during the day, it might help battery last longer when I switch it off whilst sitting indoor ?
                                  • EgikaE Offline
                                    Egika Platinum Member @Zab_55
                                    @Zab_55 said in Battery LIfe:
                                    This is interesting.
                                    Can find out which of these settings makes the difference?
                                    Jamie BGJ 1 Reply Last reply Reply Quote 0
                                    • Jamie BGJ Offline
                                      Jamie BG Bronze Member @Egika
                                      @Egika - will to bet it is wifi/bluetooth
                                      • Zab_55Z Offline
                                        Zab_55
                                        I’ll try to figure it out what exactly is draining the battery most. The night before I used only theater mode and airplane mode, Location on and it was around 8-9% , it might be gestures as well if I was moving my arm during the night 😁
                                        But I’m wondering if that setting for Location makes difference too. I let it off for today, it seems like the battery holds better. It would be good if somebody who was testing it will give us an opinion too.
                                        • Jamie BGJ Offline
                                          Jamie BG Bronze Member @Zab_55
                                          @Zab_55 -
                                          This is how I set up my watch - AOD on, Minimal ambient mode (depends on watch face), 24/7HR off, Tilt to wake off, Touch to wake on, bluetooth on, wifi on, nfc off, location on, Gestures off, screen timeout at 5s. With this set up I generally run between 2%-3% hour while watch is connected to phone. Any disconnects to phone can make battery usage ramp up as a) it tries to reconnect using bluetooth, b) as wiif is on it will switch to that and it has higher battery consumption [make sure that on your phone the wear os and suunto app are both set so that they aren’t optimized for battery - i.e. android will not close these apps automatically / Make sure that your google apps are up to date - if not it can create additional disconnects]
                                          Alternatively (keeping the same set up) but switching AOD to off I will get between 1% to 1.5% battery usage per hour.
                                          • Zab_55Z Offline
                                            Zab_55 @Jamie BG
                                            @Jamie-BG can’t understand how you could have only 2-3% with those settings. Wifi and Location are IMO worst for battery, not speaking about AOD. That’s really great.
                                            But my comment was positive, I was reacting to those comments when guys had truly bad battery loss during the night and maybe airplane mode vs switching off WiFi and BT manually makes some difference 🤔 I’m totally happy with 4% loss during the night.
                                            My concern is if that Location is a must for daily use without activity.
                                            masi0M 1 Reply Last reply Reply Quote 0
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
