    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Battery LIfe
    Scheduled Pinned Locked Moved Suunto 7
    450 Posts 54 Posters 165.3k Views 55 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • Ander LehenaA Offline
      Ander Lehena @Jamie BG
      @Jamie-BG I usually use it to sleep track on IOS.
      Suunto 7 All Black
      Iphone SE 2020
      Jamie BGJ 1 Reply Last reply Reply Quote 0
      • Jamie BGJ Offline
        Jamie BG Bronze Member @Ander Lehena
        @Ander-Lehena assume you are using Sleep as Android as no native sleep tracking yet? Note this 3rd party app doesn’t use the co-processor, so its battery consumption will be high. Most people seem to say its takes an extra 1-1.5% of battery per hour - and switching off flight mode isn’t going to save battery due to this. Any battery save due to bluetooth will be reasonably minimal.
        Hope you are switching AOD off and locking touch screen (I know people who have had major battery issues their actions while sleeping were keeping the screen alive.
        • Brad_OlwinB Offline
          Brad_Olwin Moderator @Jamie BG
          @Jamie-BG With maps no routes. Not much time spent on maps page.
          Vector/T6c/Vertical 2 Ti
          • Jamie BGJ Offline
            Jamie BG Bronze Member @Brad_Olwin
            @Brad_Olwin That makes sense based on what I am getting which is around 13-16 hours but connected to phone (btw 6-8% battery use per hour)
            • olymayO Offline
              olymay Gold Members
              I’ve just had an interesting and frustrating battery experience with my Suunto 7.
              I went for a lunchtime run which lasted 1hr17min. I had GPS set to max accuracy, map screen always on, following a route, and streaming music from the S7 to Bluetooth headphones.
              When I set off, the battery % was somewhere in the mid 70’s, more than enough for a run such as this.
              As I crossed the finish line and stopped the run, it alerted me that the battery was down to 5%.
              I have never seen battery consumption like this before! I have minimal apps installed on the watch with nothing running in the background. I used the same settings, apps, and headphones as I always use, nothing has changed as far as I can tell.
              I have added a screenshot of the watch battery (from WearOS app on the phone) to show the steep drop in battery. (the gap in the graph is overnight where I take the watch off and put it into battery saver mode).
              Battery life on the S7 is typically stellar, so I am a little confused as to why it wa so poor during this activity.
              Suunto 7 Graphite Copper
              Suunto App Beta (Android - Pixel 6 Pro)
              isaziI Jamie BGJ 2 Replies Last reply Reply Quote 1
              • isaziI Offline
                isazi Moderator @olymay
                @olymay well, check if it happens again. I can expect one-off strange behavior from something like WearOS, but if it becomes common there must be something wrong.
                Blog: isazi's home
                olymayO 1 Reply Last reply Reply Quote 1
                • Jamie BGJ Offline
                  Jamie BG Bronze Member @olymay
                  @olymay - is your play store app set to auto update or manual update? I assume you were running with watch in GPS only mode?
                  My experience is that rapid battery drain is often due to play store trying to update and it not working for lost connection or some reason. Rather than going into sleep mode and trying again later it seems to continously try and connect and rapidly drains battery.
                  If leave play store in manual update you will still get a notification when there is an update. I also prefer it this way, as then can trigger the update at a more convient time and or when I have watch on charger so uses wifi instead.
                  • olymayO Offline
                    olymay Gold Members @isazi
                    @isazi Yeah, I’ll keep an eye on it. I have shorter runs now until Wednesday when I am looking at 14km (today was 12km). I will make sure it is at 100% when I start.
                    I know that streaming music to BT headphones uses more battery, but I have done a 1hr45min run in October and it easily survived.
                    As I’m starting to do more longer runs and it’s getting darker, I may start taking my phone with me again, for safety. I can stream my music from my phone instead which will allow me to do a comparison to see how much it does actually affect it.
                    • olymayO Offline
                      olymay Gold Members @Jamie BG
                      @Jamie-BG I have the Play Store set to auto update. How do you mean GPS only mode? It was connected to my headphones via Bluetooth.
                      I may try your idea of turning Play Store to manual. Like I said, I don’t have many apps installed so it won’t be an issue.
                      • Jamie BGJ Offline
                        @olymay GPS only mode. So that it isn’t connected to your phone i.e. running off only the watches GPS - seems as though this uses less power than when connected to phone too.
                        Though suspect in you case the main culprit would be play store.
                        • olymayO Offline
                          @Jamie-BG Ah, then yes, GPS only mode. As my phone was left at home 🙂
                          • olymayO Offline
                            olymay Gold Members
                            @isazi & @Jamie-BG , I’ve just had a thought. When I checked the map screen on the watch during the run, a few times the GPS seemed to very off from my actual location. I have double checked this just now and it varies from pretty accurate, to wildly off. It’s normally pretty decent.
                            Could it have been struggling to get an accurate lock (due to trees and cloud cover) and could that affect the battery in this way?
                            Jamie BGJ 1 Reply Last reply Reply Quote 1
                            • Jamie BGJ Offline
                              @olymay could do I suppose, and if hunting it will use more battery power. Have you run that route before? If yes, then would check against those routes.
                              Before I start recording an activity I start my suunto app while getting ready, so that normally by the time i am ready to start recording my HR is steady and ready, and I may already have a GPS fix - if not I then go into the map screen, which forces a GPS fix quicker. Once it has my location I go back to tracking screen and start. It at least makes sure it starts from that point and not 100m down the road where there are less over hanging trees and easier to get a fix.
                              • olymayO Offline
                                @Jamie-BG It was my first time running this route. The first half or so is along a canal with lots of overhanging trees and my track is all over the place, often has me in the water 🤣
                                I do the same you in that I start the app whilst getting ready and doing my warm ups. I always ensure that I have HR and GPS lock before starting the run.
                                I won’t be running this route again until Wednesday (that is the day I currently do my longer runs) and this coming Wed I will be increasing from 12K to 14K, but I plan to run most of the same route (it was a beautiful route to run!). I will start with 100% battery and see how it gets on.
                                • fatih varolF Offline
                                  fatih varol @Jamie BG
                                  @Jamie-BG sorry for my bad English, but you really understand me. İ want quiet times sample 23:00-08:00 watch must be sleep…
                                  • Jamie BGJ Offline
                                    Jamie BG Bronze Member @fatih varol
                                    @fatih-varol press DND settings in top pull down menu. White round circle with line through it. If you want to automate use an automation tool from play store.
                                    • Scott GibsonS Offline
                                      Scott Gibson
                                      Hi guys. Just got my S7 for Xmas. The watch is now set up and has done a software update from what I could tell yesterday on the charger.
                                      I have just taken the watch off the charger and it says 7 hours until the battery runs out!!
                                      It is on my wrist but it only says Android system has used 1% of the battery which would be right as it has only been off the charger for 5 mins.
                                      Any idea what is causing this, is there a setting which is draining the battery?
                                      M Dimitrios KanellopoulosD 2 Replies Last reply Reply Quote 0
                                      • M Offline
                                        meyton89 @Scott Gibson
                                        @Scott-Gibson without knowing how you ve set up the watch its difficult to know.
                                        If the watch is new the discharge rate is an estimate based on usage so far. Its likely not right.
                                        But for me I turn off the WiFi when I wake up.
                                        The display being set to always on uses more battery rather than tilt to wake.
                                        Any additional apps, notifications from the phone having NFC on.
                                        It all takes up battery life
                                        Just remember the suunto 7 is a smart watch with some sport watch functionality. The battery life is at best two or three days with the smart functions on
                                        Scott GibsonS Andrea Antonio GuadalupiA 2 Replies Last reply Reply Quote 0
                                          Dimitrios Kanellopoulos Community Manager @Scott Gibson
                                          @Scott-Gibson if you are on Android turn the wear os app battery optimization to off.
                                          Creator of quantified-self.io a portal that allows you to analyze your data from various providers, upload fit activity files to Suunto app, gpx routes and more…
                                          Scott GibsonS 1 Reply Last reply Reply Quote 0
                                            Scott Gibson @Dimitrios Kanellopoulos
                                            @Dimitrios-Kanellopoulos thanks for the info, where abouts is this in the app? I have tried looking In the battery section on wear os but couldn’t see anything.
                                            Positive news though. I have ran two 5.6km runs and a 3k walk on high accuracy and always on heart rate and the battery still has 25% left and has been off the charge for over 24 hours. Even made a couple of Google pay transaction.
                                            If it continues like this there will be no complaints from me regarding battery life.
                                            Loving it so far.
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
