    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Battery LIfe
    Scheduled Pinned Locked Moved Suunto 7
    450 Posts 54 Posters 198.6k Views 55 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • EgikaE Offline
      Egika Platinum Member @Jamie BG
      @Jamie-BG yes, I noticed the same with SUP - the display constantly activating will be dealt with the next update.
      I highly doubt that airplane mode does not disable BT and WiFi - as this is a regulatory requirement.
      Still my question is, why hiking and cycling (with the same settings!) yield such different battery life…
      EgikaE 1 Reply Last reply Reply Quote 1
      • EgikaE Offline
        Egika Platinum Member @Egika
        @Egika said in Battery LIfe:
        So one thing is that the S7 GPS is using higher power when in worse satellite reception places and when at slower speed (or stationary). Both is more so the case with hiking instead of cycling.
        I hope that some development focus is put on this to enable some predictable GPS run time independent of the selected sports mode
        Jamie BGJ Fenr1rF 2 Replies Last reply Reply Quote 1
        • Jamie BGJ Offline
          Jamie BG Bronze Member @Egika
          @Egika - when you try this is your screen on or off? Try both keeping your screen off for both activities, and while it is always going to vary slightly (due to terrain features etc), I think you might that the battery usage will be very similar.
          I suspect that title to wake activity on wrist movement is causing the difference. When you cycle your wrist is fairly stationary and barely ever tilts - not the case when you are walking/running/hiking.
          Hopefully they will soon solve the tilt to wake bug when you turn it off in the app it will actually work, so no need to switch off screen to stop this issue.
          I generally operate with screen off mode, and have found battery usage similar across a varitey of different activities.
          • Fenr1rF Offline
            Fenr1r @Egika
            Interesting but how would that work?
            Can you essentially duplicate GPS settings between sports modes on the S7, making whether you are hiking in a Cycling mode or cycling in a Hiking mode irrelevant to GPS run time? And then …
            Doesn’t predictability require knowledge and/or control? And in this case one of the major variables is 3D environment.
            => Wouldn’t you need pre-knowledge of the sky-masking on a to-be-followed-exactly route (adjusted to your personal watch/wear configuration)?
            Or would it involve a constantly adjusting display of remaining run time assuming future energy-use at last-fix levels?
            As for control: assuming the GPS is pulling as little power as possible (at its settings), isn’t the only control possible pulling more power unnecessarily? (Maybe working on Covid by doing a little FoldingOnWearOS.) I.e., you can shorten to a predictable time but not lengthen … and why would you?
            Jamie BGJ 1 Reply Last reply Reply Quote 0
            • Jamie BGJ Offline
              Jamie BG Bronze Member @Fenr1r
              @Fenr1r - I think the suggestion is that potentially the checking with satellite time is different - but can’t see why you would want to do that, and would think that hiking etc would poll less frequently than cycling (as less distance moved).
              But too my point I don’t think that is the case as I use 3 very different options very regularly and with my screen off there is little variance in battery usage (any difference I would put to terrain features).
              • EgikaE Offline
                @Jamie-BG yes, both with screen fully off.
                You can try it yourself. You will see a noticable difference!
                • Federico OrmesaniF Offline
                  Federico Ormesani @Brad_Olwin
                  @Brad_Olwin I lost data. When the S7 switched on Save battery mode and recharge it to sync the result is in attached.
                  Federico OrmesaniF 1 Reply Last reply Reply Quote 0
                    Federico Ormesani @Federico Ormesani
                    Federico OrmesaniF Brad_OlwinB 2 Replies Last reply Reply Quote 0
                      @Federico-Ormesani
                      The problem of battery life in generale is objetcive. Register one activity about 6/7 hours it is difficult to fully complete. This is my opinion, and I don’t think that my S7 has a problem. It is a wroste engineering design
                      • Brad_OlwinB Offline
                        Brad_Olwin Moderator @Federico Ormesani
                        @Federico-Ormesani It appears that the activity was saved up to the point that the watch went into battery saver mode. I do not know why the altitude was not transferred. I am on iOS and all the data up to the watch going into battery saver mode is transferred.
                        Vector/T6c/Vertical 2 Ti
                        • danklodD Offline
                          danklod
                          Hi all,
                          my impressions that when I’m using the watch with screen off the battery life is more extended but this is usefull for some activities like rowing and swimming. But when I’m in the mountain for hiking, trekking and etc and when I often have to use the map to understand what path I have to follow the battery life is about 6/7 hours like @Federico-Ormesani said. Also if in next update been added the option to we can import gpx tracks and follow the path this will be increasingly annoying. Perhaps if we can use this activities with some simple mode option or cutted function or anything else this will be great.
                          luca760101L 1 Reply Last reply Reply Quote 3
                          • luca760101L Offline
                            luca760101 @danklod
                            Last test on a trail running skyrace, with mountaineering passages but always with visible gps (almost all at 2300 meters above sea level without tree cover): final activity of 7:15 h, my S7 died at 5h29m of activity in mode plane. Do I have to resign myself to not being able to use the S7 when it goes over 5h? Dear Suunto, help us …
                            EgikaE Saketo NemoS Kai LiuK 3 Replies Last reply Reply Quote 2
                            • EgikaE Offline
                              Egika Platinum Member @luca760101
                              @luca760101 depends on the settings.
                              Right now the GPS is using a lot of power when moving slowly (or almost stationary).
                              Until the next update is there, you could try cycling as sports mode. This will increase the battery run time to 10-15h (that’s what I get)
                              luca760101L 1 Reply Last reply Reply Quote 1
                              • JorgeFDJ Offline
                                JorgeFD
                                My experience hiking last week for 20km and 1200 meter ascent. I put s7 in airplane mode and select hiking mode. After 6h (plus 1h paused) the battery was at 20%
                                • Saketo NemoS Offline
                                  Saketo Nemo Moderator @luca760101
                                  @luca760101
                                  I don’t remember if we had already talked about it, but one way to help the watch is to bring it back to the home (and disable the reactivation of the screen with the rotation of the wrist) with the back button. This will force you to press the Suunto app button when you want to check the data, but it will certainly consume less battery.
                                  We hope that Suunto will soon present an update that improves autonomy, it is also my wish.
                                    luca760101 @Egika
                                    thank you, in fact I also think GPS is the real problem of excessive resource consumption. your theory is very logical. we therefore await the next update to be able to do sport for more than 5 hours :;-)
                                      Brad_Olwin Moderator @JorgeFD
                                      @jorgefd78 This is about what I am getting with trail running.
                                      luca760101L 1 Reply Last reply Reply Quote 0
                                        luca760101 @Brad_Olwin
                                        @Brad_Olwin
                                        That is, how many hours with the trail running mode with the airplane mode? As with the discussion on charging the exhausted S7, perhaps at this point you have a special version produced by Suunto for the testers.
                                        • Kai LiuK Offline
                                          Kai Liu Bronze Member @luca760101
                                          @luca760101 Charge it before battery dies when you break?
                                          S7, S9P, Vertical Solar / boxing, skiing, hiking, running
                                            luca760101 @Kai Liu
                                            @Kai-Liu
                                            It’s the same
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
