    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Problem with altimeter s9b
    15 Posts 6 Posters 685 Views 6 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • Giulio Dall'OstoG Offline
      Giulio Dall'Osto
      Hi,
      I have a problem with my S9b. In section “outdoor” when I select “auto adjuste altitude” the Watch goes in loop and don’t found the altitude. Is It normal?
      • isaziI Offline
        isazi Moderator
        What do you exactly mean? Your watch should tell you that you can close the menu and it’ll notify you when it has a new altitude.
        Watch: Suunto Vertical Ti
        Blog: isazi's home
        Giulio Dall'OstoG 1 Reply Last reply Reply Quote 0
          Giulio Dall'Osto @isazi
          @isazi It seems that the process never found the altitude!
          isaziI 1 Reply Last reply Reply Quote 0
          • isaziI Offline
            isazi Moderator @Giulio Dall'Osto
            @Giulio-Dall-Osto are you outside? It needs GPS, good GPS, for something like 5-10 minutes to work.
            Blog: isazi's home
              @isazi and if I don’t start the process of auto adjust, the process doesn’t work in background. Right?
              Václav KrálV isaziI 2 Replies Last reply Reply Quote 0
              • Václav KrálV Offline
                Václav Král @Giulio Dall'Osto
                @Giulio-Dall-Osto This is backgroud process.
                Polar A360, Polar M600, Polar M430
                Suunto Spartan Trainer, Suunto Spartan WHR Baro
                Suunto 9 Baro
                Coros Apex Pro
                Google Pixel 2
                • isaziI Offline
                  @Giulio-Dall-Osto you have to start the process, then it’ll work in the background.
                  Blog: isazi's home
                  • Saketo NemoS Offline
                    Saketo Nemo Moderator
                    it is almost useless to do this, unless you have a very incorrect altitude as given on the watchface, and in this case I advise you to manually set the altitude, where known.
                    Doing it before an activity is not needed, it will take care of fusedAlti to recover the right altitude once the activity has started
                    Giulio Dall'OstoG 1 Reply Last reply Reply Quote 1
                      Giulio Dall'Osto @Saketo Nemo
                      @Saketo-Nemo @isazi ok thanks. I don’t notice wrong altitude. But, when I started this process(auto adjuste altitude), It seems It never found the altitude.
                        at the cost of being repetitive: were you outdoors with good visibility of the sky?
                          @Saketo-Nemo yes! In any case the process seems don’t found the altitude
                          sartoricS 1 Reply Last reply Reply Quote 0
                          • sartoricS Offline
                            sartoric Moderator @Giulio Dall'Osto
                            @Giulio-Dall-Osto
                            As it is a background process, you’ll never receive any confirmation message.
                            In fact what it does is to kick in fusedalti (afair) so it keeps “correcting” altitude for a while.
                            Of course you need a good GPS signal
                            SVTS - 2.44.46
                            SSSWHR BARO Amber - 2.8.32
                            Samsung A5 2016 - Android 7.0
                            Samsung A33 2022 - Android 15 - One UI 7.0
                            Suunto App Android 6.2.2 beta
                            Suunto App IOs 3.2.0 (20384) beta on MBP M1
                            • isaziI Offline
                              isazi Moderator @sartoric
                              @sartoric on S9 you get a notification when it’s done.
                              Blog: isazi's home
                              • sartoricS Offline
                                sartoric Moderator @isazi
                                @isazi
                                oohhh … what a magic !
                                SVTS - 2.44.46
                                • Cuba1hrC Offline
                                  Cuba1hr
                                  🙂 I have done it after the reset (when s9b stopped responding) and on altitude of 250m it missed about +20 meters what was earlier showing (before restart). It was off more than 50 meters before auto adjust. I don’t know exact altitude in single meter so I let it auto adjust altitude.
                                  It normalized few days later, after 2 walk activities.
                                  • First post
                                    Last post
                                  Suunto Terms | Privacy Policy
