    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Suunto 7 - Google fit integration must be improved
    Scheduled Pinned Locked Moved Suunto 7
    130 Posts 23 Posters 36.2k Views 24 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • Brian HuffmanB Offline
      Brian Huffman
      @Jamie-BG Thank you for the response. I get what you’re saying. As an explanation, I LOVE the Suunto 7 for running. I had a Fossil Sport prior to the Suunto 7 and it was HORRIBLE. It truly makes a difference to use a watch made by a vendor that caters to sports enthusiasts.
      That being said, for every day use and especially for “dressier” events, I actually prefer another watch. The Suunto 7 is utilitarian in looks (which is perfectly fine for outdoor use) and because it is big and bulky it catches on things like long shirt sleeves, jacket sleeves and sweatshirt sleeves. So ideally (for me) I will swap out watches depending on what I’m doing. It sounds like I’m in the minority. But just figured I’d explain the rationale.
      Jamie BGJ 1 Reply Last reply Reply Quote 3
      • M Offline
        moodydaddy @pilleus
        @pilleus said in Suunto 7 - Google fit integration must be improved:
        @Brian-Huffman deactivate Suunto’s syncing to Google Fit and deactivate the salmon.overlay as described in one of my posts. Then everything is fine and steps and heartrate from S7 will be added to Google Fit without overwriting data from other devices (smartphone, WearOS watches). 👍
        Hi @pilleus first post on here and 7 owner from Christmas, would you be able to give me a more in-depth step by step walkthrough on how to do the salmon overlay deactivation please.
        I have the Suunto 7 and also a Garmin fenix 3HR, I use the Garmin most work days and Health Sync transfers all the data into Google fit fine. When I get home I then use my suunto 7 for the rest of the day and none work days to track any activities I do ( mountain biking, fitness workouts etc) when the 7 sync to Google fit it over writes the data collected from the Garmin, this is exactly what was discussed earlier and as I read it deactivating the salmon overlay will stop this?
        Thanks in advance
        Simon
        Apologies for the long first post.
        pilleusP 1 Reply Last reply Reply Quote 1
        • pilleusP Offline
          pilleus @moodydaddy
          @moodydaddy do you use an Android smartphone?
          https://www.instagram.com/moves.are.life/
          Suunto Vertical Black Lime
          Suunto 9 Peak Pro Black
          Suunto Spartan Ultra Stealth Titanium
          M 1 Reply Last reply Reply Quote 0
          • M Offline
            moodydaddy @pilleus
            @pilleus yes I do a Samsung S10 currently.
            Simon
            pilleusP 1 Reply Last reply Reply Quote 0
            • pilleusP Offline
              pilleus @moodydaddy
              @moodydaddy okay. here we go …
              Smartphone:
              • Install https://play.google.com/store/apps/details?id=com.cgutman.androidremotedebugger&hl=de&gl=US
              S7:
              • Open settings - system - info and tab continously onto build number until the message appears that you are developer now
              • Go back to settings and scroll down to developer options
              • Open it and scroll down to ADB debugging and enable it
              • Enable debugging over WLAN and wait until the wifi is connected and the IP adress appears in the text
              Smartphone:
              • Open remote ADB shell and enter the IP adress of the S7
              • Connect to S7 and allow on the display of the S7 the connection to your smartphone (once or trust it forever)
              • Type in the textfield of the remote ADB shell: pm disable-user --user 0 com.google.android.wearable.app.overlay.salmon
              • Press ENTER to send the message
              • Type in the textfield of the remote ADB shell: cmd overlay disable --user 0 com.google.android.wearable.app.overlay.salmon
              • Long press somewhere in the upper half of the remote ADB shell and choose Exit terminal to disconnect the S7.
              • Close the remote ADB shell
              S7:
              • Go to settings - developer options and deactivate debugging over WLAN to disconnect wifi. DON’T forget it!!!
              • Reboot the S7
              If you want a customizable heart rate reading (5 or 10 or 15 or … minutes) or a complication for your watch face, install on the S7 https://play.google.com/store/apps/details?id=com.magic09.hearttrace&hl=de&gl=US
              If not, enable in Google Fit the 24/7 heart rate measuring and disconnect the Suunto wear app on the S7 from Google Fit.
              Now you will have all activities, steps and heart rate values in Google Fit on the Smartphone and in Google Fit on the S7. Even the heart rate measured with other watches.
              Enjoy! 👍
              M 1 Reply Last reply Reply Quote 1
              • M Offline
                moodydaddy @pilleus
                @pilleus thanks very much for that I’ll do that in the morning.👍🏼
                  Brian Huffman
                  @pilleus If I deactivate the salmon overlay, do I still need to deactivate Suunto’s syncing to Google Fit to get this to work? What does each each of these do independently? Thank you so much for your guidance on this!
                  • pilleusP Offline
                    pilleus @Brian Huffman
                    @Brian-Huffman Google Fit is recording heart rate, steps and calories natively if enabled in Google Fit app on the S7. Suunto wear app does sync additional activities to Google Fit. I have deactivated this option, because I use the way Suunto wear app to Strava to Google Fit, to be sure that nothing is overwritten by Suunto in Google Fit. 😎
                    • Jamie BGJ Offline
                      Jamie BG Bronze Member @Brian Huffman
                      @Brian-Huffman part of the reason why I went black and black, as really understated, and putting a dress watch face on it, makes it look the part.
                      Re catching on clothing - not an issue for me, but maybe because I have always previously had large bulky watches (first one in a long time that isn’t rated for 20bars); so have become very used to working around that issue i.e. how I remove my clothes and I tend to put the cuff in behind the watch, wearing it slightly more loosely (that way also don’t have to shoot my cuffs to see the time).
                      Due to low bezel also find that it seldom if ever catches.
                      • pilleusP Offline
                        pilleus
                        Nice feature, should be added to Suunto wear app too… 👍
                        https://www.xda-developers.com/google-fit-wear-os-automatically-detect-workout-finished/
                        Register Login
                        • First post
                          Last post
                        Suunto Terms | Privacy Policy
