    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Suunto 7 - Google fit integration must be improved
    Scheduled Pinned Locked Moved Suunto 7
    130 Posts 23 Posters 36.1k Views 24 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • Mff73M Online
      Mff73 @pilleus
      @pilleus
      SSU (retired), SV1, SV2
      Wife : S9PP
      SA: Always the latest beta :)
      Android + Galaxy S205G
      • EgikaE Offline
        Egika Platinum Member @pilleus
        @pilleus on IOS there is no button for reload.
        You swipe down to update…
        But neither on the website nor on the phone nor on the watch is anything in Google Fit…
        pilleusP 1 Reply Last reply Reply Quote 1
        • pilleusP Offline
          pilleus @Egika
          @Egika okay. Only one thing left. I have two Google accounts and with my Skagen Falster 3 I connected the second Google account to Google Fit. I forgot to change it in SyncMyTracks. All syncs were okay, but nothing showing up on my Falster 3.
          You don’t have two accounts? Just to be sure?
          https://www.instagram.com/moves.are.life/
          Suunto Vertical Black Lime
          Suunto 9 Peak Pro Black
          Suunto Spartan Ultra Stealth Titanium
          • EgikaE Offline
            @pilleus I only have one Google account at all. And connected all my phones and PC and watch with this single one…
            pilleusP 2 Replies Last reply Reply Quote 0
            • pilleusP Offline
              pilleus @Egika
              @Egika and the S7 does not show the heart rate or steps in the Google Fit app on the watch?
              • pilleusP Offline
                pilleus @Egika
                @Egika said in Suunto 7 - Google fit integration must be improved:
                I think I have the solution. You are using a mail address with googlemail.com.
                Change it on your pc in Google to gmail.com and you should have no problems with Google Fit. 👍
                EgikaE 2 Replies Last reply Reply Quote 1
                • EgikaE Offline
                  @pilleus really? Wow, will try that
                  • EgikaE Offline
                    @pilleus took me a little but now everything is on Gmail.
                    Tried to sync with Syncmytracks again.
                    The app shows all as normal (and as before).
                    Still nothing shows up in my Google Fit app nor on the watch…
                    pilleusP Brad_OlwinB 2 Replies Last reply Reply Quote 0
                    • pilleusP Offline
                      pilleus @Egika
                      @Egika the mail issue was the only one I remembered. Sorry for no other idea. 😕
                      • Brad_OlwinB Offline
                        Brad_Olwin Moderator @Egika
                        This is weird, I assume you have the permissions for Fit on the watch set ok? I have the opposite issue, since I usually run with two or three watches, Google Fit is importing everything and I am a superman…I am on iOS and all is porting to Fit as it should.
                        Vector/T6c/Vertical 2 Ti
                        • EgikaE Offline
                          Egika Platinum Member @Brad_Olwin
                          @Brad_Olwin ios here too by default.
                          How do you get any of your Suunto Watch app activities into Google Fit? By default it only syncs heart rate and steps…
                          Thanks!
                            Thanks!
                            I connected GoogleFit in the Suunto Wear OS app under general options.
                            In GoogleFit on your iPhone under Activity Tracking I allow Google Fit to read from Apple Health
                            I allow Apple Health to read from SA on the iPhone
                            That gets my stuff into Google Fit.
                            Not sure that is right or really works but give it a try.
                            EgikaE 1 Reply Last reply Reply Quote 1
                            • EgikaE Offline
                              @Brad_Olwin thank you. I have now connected Health to SA and to Google Fit as well.
                              Initially I was after getting the proper tracks and full activity data into Fit using Syncmytracks as hinted above. It would also import some data history.
                              Somehow this does not seem to work for me.
                              Anyway, I will check, what I get with the new health connections with new activities.
                              Thank you all for support.
                              And I back the initial topic of this thread: Fit integration of the Suunto wear OS app can be improved. 🙂
                              • EgikaE Offline
                                @pilleus said in Suunto 7 - Google fit integration must be improved:
                                @vlado said in Suunto 7 - Google fit integration must be improved:
                                How do you use SyncMyTracks?
                                Add Strava first, sync direction away from Strava.
                                Add Google Fit second, sync direction to Google Fit.
                                Sync mode every x hours or manually.
                                That’s it. 👍
                                Have now bought the full version of Syncmytracks.
                                Are you using the account sync function or import/export?
                                Thx
                                pilleusP 1 Reply Last reply Reply Quote 0
                                • pilleusP Offline
                                  pilleus @Egika
                                  @Egika account sync 👍
                                  • EgikaE Offline
                                    @pilleus ok - thanks.
                                    It took some says to get the account from Strava to Fit synced with 1100 activities…
                                    Now I still don’t get tracks in Fit… The sync log shows the most recent activity as synchronized.
                                    But in the fit app there seems just to be one point…
                                    • MO92119M Offline
                                      MO92119 @pilleus
                                      Even in Google Fit on the S7 the activity will be updated after the sync via Strava. Map and graphs of altitude and speed are missing. The complete data will be displayed in Fit on the smartphone.
                                      Hi Pilleus,
                                      Greetz from Regensburg 😎
                                      I have set it up like you suggested, and Strava syncs everything to Google Fit - everything, except the map.
                                      I think I have set up everything the right way, checked and re-checked everything, but the map won’t sync.
                                      Am I missing something? Any suggestions?
                                      Many thanks in advance!
                                      Markus
                                      • pilleusP Offline
                                        pilleus @MO92119
                                        @MO92119 said in Suunto 7 - Google fit integration must be improved:
                                        Therefore I use SyncMyTracks to have all data in Fit (altitude, heart rate, map, speed, distance, calories). 👍
                                        MO92119M EgikaE 2 Replies Last reply Reply Quote 0
                                        • MO92119M Offline
                                          MO92119 @pilleus
                                          @pilleus Yes, I read about SyncMyTracks. However, to use it I have to enter my passwords (especially Google) in the app, and I’m not gonna do that…
                                          So there’s no way to import the maps to Google Fit by only using Strava, correct? It only works via SyncMyTracks?
                                          • pilleusP Offline
                                            pilleus @MO92119
                                            No. It’s an allowed connection as it is with the Suunto wear or any other app or watch face. The apps are listed in Google Fit and can be removed.
                                            MO92119M 1 Reply Last reply Reply Quote 0
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
