    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Suunto 7 - Google fit integration must be improved
    Scheduled Pinned Locked Moved Suunto 7
    130 Posts 23 Posters 36.1k Views 24 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • EgikaE Offline
      Egika Platinum Member @pilleus
      @pilleus can you check my screenshot above? No map is synced for me while Syncmytracks in the logs tells me it synced fun from Strava to Fit…
      pilleusP 1 Reply Last reply Reply Quote 0
      • MO92119M Offline
        MO92119 @pilleus
        @pilleus said in Suunto 7 - Google fit integration must be improved:
        @MO92119 said in Suunto 7 - Google fit integration must be improved:
        passwords (especially Google)
        No. It’s an allowed connection as it is with the Suunto wear or any other app or watch face. The apps are listed in Google Fit and can be removed.
        You are right! You must enter username and password for Strava, so I assumed it’s the same for Google.
        I will test it then, thank you very much!!
        • pilleusP Offline
          pilleus @Egika
          @Egika strange. I have no problems, no delay to show the map in Fit.
          Did you check the sync log for errors?
          You can try the export & import function of SyncMyTracks to force the resync of the last activity listed in Strava.
          https://www.instagram.com/moves.are.life/
          Suunto Vertical Black Lime
          Suunto 9 Peak Pro Black
          Suunto Spartan Ultra Stealth Titanium
          • EgikaE Offline
            @pilleus log looks totally fine for me.
            It syncs nicely. Just the Fit app shows no map. The activity gets updated with some position data though, as you can see in the screenshot above…
            • pilleusP Offline
              pilleus @Egika
              @Egika said in Suunto 7 - Google fit integration must be improved:
              Fit app
              One more idea. Check out if automatic activity tracking is enabled or not in Google Fit. Change the setting to see what happens with the map.
              Do the same with location services in Google Fit. I disabled location services completely.
              • EgikaE Offline
                Fit app
                Thanks for the idea. Are you talking about the watch or app? I mainly have it on iPhone - can’t see this setting there…
                • pilleusP Offline
                  pilleus @Egika
                  @Egika okay, I have Android. The settings are in the Fit app on the phone in your profile - settings. May be IOS is different. 🤔
                  • JANTIKAINENJ Offline
                    JANTIKAINEN Bronze Member
                    Refreshed Google Fit,
                    Samsung Galaxy S24
                    Suunto Race Titanium
                    • pilleusP Offline
                      pilleus @JANTIKAINEN
                      @JANTIKAINEN said in Suunto 7 - Google fit integration must be improved:
                      Refreshed
                      Was announced some days ago, but not updated yet. I am waiting. 😊
                      JANTIKAINENJ 1 Reply Last reply Reply Quote 0
                        JANTIKAINEN Bronze Member @pilleus
                        @pilleus I updated manually.
                        Samsung Galaxy S24
                        pilleusP aeroildA 2 Replies Last reply Reply Quote 0
                        • pilleusP Offline
                          Okay, so I did now too. 😎😊
                          Here the new tiles available with the new update.
                          • aeroildA Offline
                            aeroild Bronze Member @JANTIKAINEN
                            @JANTIKAINEN How do you update manually?
                              JANTIKAINEN Bronze Member @aeroild
                              @aeroild Here is a quick guide to it,
                              https://www.techadvisor.co.uk/how-to/google-android/sideload-apps-android-wear-3673967/
                              Samsung Galaxy S24
                              C 1 Reply Last reply Reply Quote 1
                              • C Offline
                                comicinjo @JANTIKAINEN
                                Hello guys. I am a new suunto 7 user. Could someone explain to me, is it possible to link external sensor (hr chest strap from suunto or polar) to google fit on suunto 7? And if yes does it work properly?
                                • Brad_OlwinB Offline
                                  Brad_Olwin Moderator @comicinjo
                                  @comicinjo This is not possible unless you use a 3rd party app.
                                  Vector/T6c/Vertical 2 Ti
                                  • EgikaE Offline
                                    Egika Platinum Member @Brad_Olwin
                                    @Brad_Olwin no native speaker here but I understand he is asking if BT sensors can be used with the Google Fit app.
                                    Answer is yes.
                                    ou can connect sensors to the Fit app on the watch and record your training with it.
                                    1 Reply Last reply Reply Quote 3
                                    • Jamie BGJ Offline
                                      Jamie BG Bronze Member
                                      @Urban-Olofsson
                                      Note that this issue has been fixed with the July Update and Google fit now picks up the Suunto App activity tracking data and this includes maps and will show them in Google fit.
                                      Note if using Google Fit to track, then it has always showed map data when I have used it, by why are you using google fit to track - uses more battery and not nearly as well featured as the Suunto app for tracking.
                                      ? 1 Reply Last reply Reply Quote 1
                                      • ? Offline
                                        A Former User @Jamie BG
                                        @Jamie-BG yes I have noticed this is solved as I see it.
                                        • Zab_55Z Offline
                                          Zab_55
                                          Hey folks,
                                          I’d like to ask (mainly iPhone users) what settings do you use on your S7 and iP. I allowed Suunto app to integrate stats with Google fit and as well Health app on iPhone to send stats to both Suunto App and GFit. I disabled Location services on GFit on S7 though since I was afraid or battery drainage - Suunto app will automatically use GPS during activity right ?
                                          Maybe stupid question but should I even use GoogleFit to check all my stats ? Isn’t Suunto app sufficient ?
                                          Thank you
                                          isaziI Brad_OlwinB Jamie BGJ 3 Replies Last reply Reply Quote 0
                                          • isaziI Online
                                            isazi Moderator @Zab_55
                                            @Zab_55 for activities Suunto is enough, Fit is only for heart rate. Hopefully even that will end up in SA at some point.
                                            Blog: isazi's home
                                            Zab_55Z 1 Reply Last reply Reply Quote 1
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
