    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    What cadence senzor?
    14 Posts 5 Posters 1.4k Views 5 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • DurriD Offline
      Durri
      Hi, I want to buy a bike cadence sensor. Should I go to buy the original Suunto, or prefer the Garmin Bike Cadence Sensor 2? Do you have experience with them? Speed ​​measurement I want via GPS.
      Thanks all😉
      Suunto Race Titanium, Suunto 9 Baro Titanium, Polar V800, Vostok Anchar Europe Titanium, Hoka One One, Focus Atlas 6.8, Rose Pro SL, Giant Roam 2
      zvonejanZ Q N 3 Replies Last reply Reply Quote 1
      • zvonejanZ Offline
        zvonejan Bronze Member @Durri
        @Durri why do you want speed via GPS?
        DurriD 1 Reply Last reply Reply Quote 0
        • DurriD Offline
          Durri @zvonejan
          @zvonejan Because so far I have been using the Polar V800 + HR belt (on my bike) and I was happy. I see no reason to buy a speed sensor.
          • Q Offline
            QwertyBoy @Durri
            @Durri said in What cadence senzor?:
            Thanks all😉
            I’m using chinese Magene sensor. Works good.
            • N Offline
              nseslija Bronze Member @Durri
              @Durri I am using Bontrager Duotrap BT cadence/speed sensor (Trek road bike) and no problem with it at all, also used Garmin ANT+ version, it was also good.
              As far as I know you can’t use only cadence and not speed sensor if it is a combo…
              I tried only cadence sensor, but it’s not working on S9B…
              Ambit 2S
              Ambit 3 Peak
              Suunto 9 baro
              Suunto Vertical Ti Solar
                Dimitrios Kanellopoulos Community Manager
                You can use seperate cadence sensors only.
                However, you can only pair ONE BIKE pod.
                That means that the bike pod can be:
                • Cadence
                • Speed
                • Both
                So if you buy 2 seperate bike pods, eg one for cadence and one for speed then that is a problem
                Creator of quantified-self.io - sync Garmin and COROS activities to Suunto, import Suunto routes, deliver Suunto routes to Garmin courses, and analyze training data in one private dashboard.
                DurriD 1 Reply Last reply Reply Quote 1
                • DurriD Offline
                  Durri @Dimitrios Kanellopoulos
                  @Dimitrios-Kanellopoulos I plan to buy only a separate cadence sensor, there should not be a problem.
                  Dimitrios KanellopoulosD 1 Reply Last reply Reply Quote 1
                    Dimitrios Kanellopoulos Community Manager @Durri
                    @Durri that is what I do. I use the wahoo cadence sensor with no problems. The great thing if you are a multibike user is that that sensor can be clipped on the shoe.
                    N 1 Reply Last reply Reply Quote 2
                    • N Offline
                      nseslija Bronze Member @Dimitrios Kanellopoulos
                      @Dimitrios-Kanellopoulos tip how? Watch asks to calibrate speed sensor…even if the sensor is only for cadence…
                      Ambit 2S
                      Ambit 3 Peak
                      Suunto 9 baro
                      Dimitrios KanellopoulosD 1 Reply Last reply Reply Quote 0
                        Dimitrios Kanellopoulos Community Manager @nseslija
                        @nseslija I just press next or back there
                        N 2 Replies Last reply Reply Quote 0
                        • N Offline
                          @Dimitrios-Kanellopoulos i think that I tried that… I’ll try again…
                          Ambit 2S
                          Ambit 3 Peak
                          Suunto 9 baro
                          • N Offline
                            @Dimitrios-Kanellopoulos Nope, mine (no name) just doesn’t work…
                            Ambit 2S
                            Ambit 3 Peak
                            Suunto 9 baro
                              @nseslija hmmm so if you spin the sensor it doesnt get the cadence ?
                              N 1 Reply Last reply Reply Quote 1
                              • N Offline
                                @Dimitrios-Kanellopoulos Right… cadence 0…
                                Ambit 2S
                                Ambit 3 Peak
                                Suunto 9 baro
                                Register Login
                                • First post
                                  Last post
                                Suunto Terms | Privacy Policy
