    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Suunto 9 and POD foot mini?
    closed
    14 Posts 5 Posters 1.5k Views 5 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • NicolaN Offline
      Nicola
      Hello. I have a Suunto 9 cheater and I purchased a foot mini POD to record indoor activities. I tried several times to do the pairing … I also changed the battery (imagining that it was discharged even if the sensor is brand new). I don’t know what to try anymore. Isn’t that the POD is flawed?
      Suunto 9 baro titanium
      NicolaN B 2 Replies Last reply Reply Quote 0
      • NicolaN Offline
        Nicola @Nicola
        @Nicola-Gravina Suunto 9 baro…pardon!😅
        • B Offline
          BKtoo Bronze Member @Nicola
          @Nicola-Gravina the pod is ANT+, and the S9 is only BT
          NicolaN 2 Replies Last reply Reply Quote 1
          • NicolaN Offline
            Nicola @BKtoo
            @BKtoo I did not think about it. I was convinced that if ANT + … was also compatible with Bt … I will return it then …
            • NicolaN Offline
              Nicola @BKtoo
              @BKtoo But what if I want to use the S9 for indoor activities? Which motion sensor could I use? Of other brands I guess because I don’t see anything else about Suunto …
              isaziI M 2 Replies Last reply Reply Quote 0
              • isaziI Offline
                isazi Moderator @Nicola
                @Nicola-Gravina I’m using Stryd, is quite expensive though. But I’m sure there are other and cheaper Bluetooth footpods.
                Watch: Suunto Vertical Ti
                Blog: isazi's home
                • EgikaE Offline
                  Egika Platinum Member
                  Cheap options include the now discontinued Adidas miCoach and the Milestone Pod (now bought by Zwift - so Zwift run pod)
                  t6, S6, Elementum Terra, Ambit 3 Sapphire, Spartan Ultra Copper, Traverse Alpha, S7 Graphite LE, S9B Ambassador, S9P Granite Blue Titanium, S9PP Titanium Sand, Vertical All Black, Race Titanium Charcoal, Race S All Black / Titanium Courtney, Run Lime
                  • M Offline
                    Mi_chael Bronze Member @Nicola
                    @Nicola-Gravina
                    My S9 is paired with a Stryd but on treadmill i don’t use it.
                    S9 works fine alone. Just think to make outdoor run with gps set to Best for sensor calibration.
                    NicolaN 1 Reply Last reply Reply Quote 1
                    • NicolaN Offline
                      Nicola @Mi_chael
                      @Mi_chael But does the S9 reveal speed and cadence indoors without GPS on the tapir ruland, like the Polar Vantage V does?
                      • EgikaE Offline
                        Egika Platinum Member @Nicola
                        @Nicola-Gravina said in Suunto 9 and POD foot mini?:
                        It does - but as said before, it needs to calibrate your running style with GPS before.
                        Still results are mixed, because the watch needs to derive your speed from your arm movement…
                        • NicolaN Offline
                          Nicola @Egika
                          @Egika Then it uses the same system. Tonight I train on the tapirulant after a few runs already done outdoors. Let’s see how it will monitor.
                          M 1 Reply Last reply Reply Quote 1
                          • M Offline
                            @Nicola
                            Yes S9 show the speed and cadence with internal sensor.
                            For me speed on S9 is the same of my treadmill display.
                            NicolaN 2 Replies Last reply Reply Quote 2
                            • NicolaN Offline
                              Nicola @Mi_chael
                              @Mi_chael very good! 😊
                              • NicolaN Offline
                                Nicola @Mi_chael
                                @Mi_chael Verified! Perfect and thanks for the help 😊
                                1 Reply Last reply Reply Quote 3
                                • First post
                                  Last post
                                Suunto Terms | Privacy Policy
