    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Suunto 9 Baro quick discharge problem
    85 Posts 28 Posters 22.4k Views 28 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • MiniForkliftM Offline
      MiniForklift Platinum Member @isazi
      @isazi Yep, I agree
      SV Titanium Solar Forest
      • Brad_OlwinB Offline
        Brad_Olwin Moderator @MiniForklift
        @MiniForklift After 36h, one run (1.75h) and Pilates (~1h) sleep two nights, HR24/7 I am down about 25%. I keep my backlight very low 30% and don’t use it often. The backlight is probably one of the biggest battery life hogs.
        Vector/T6c/Vertical 2 Ti
        • Jenya ObolonskiyJ Offline
          Jenya Obolonskiy @isazi
          @isazi Hi, calibration doesn’t help, I made soft and hard reset and using the watch with factory settings I have ~ 3% of battery consumption per hour
          isaziI 1 Reply Last reply Reply Quote 0
          • isaziI Offline
            isazi Moderator @Jenya Obolonskiy
            @Jenya-Obolonskiy I think you should contact Suunto’s support.
            Blog: isazi's home
            Jenya ObolonskiyJ 1 Reply Last reply Reply Quote 0
              @isazi how I can contact support?
              • isaziI Offline
                @Jenya-Obolonskiy it’s on the website, or even through the Suunto App, in the “other” section of the “settings” tab.
                Blog: isazi's home
                • Joshua KingJ Offline
                  Joshua King
                  I had the same issue. Soft and hard resets didn’t work. I took it overseas for two months in the hopes that a software update was the issue, and that it would work itself out. When I got home, I sent it in and received a brand new watch. No issues. I know I am a little late to the party here, but I would send it in for “repairs” if you have yet. Hopefully it is resolved by now…
                    I would definitely get in touch with support so you can a resolution.
                    I had the same issue with a previous S9 of mine, battery was draining really fast. I took it into the store I purchased it from, they sent it away to Suunto NZ to test and they came back saying that they had found a non-repairable issue. I was offered a refund or a straight swap, problem was all sorted within a week
                    • Vincenzo UccieroV Offline
                      Vincenzo Ucciero
                      hey guys, does anyone solved the battery drainage without sending the watch back for support? I have my S9B the eats 4% at hour with no HR no SleepTrackin … no nothing! just time -.-‘’
                      Can I try something out aside from the soft/hard reset?
                      lexterm77L 1 Reply Last reply Reply Quote 0
                      • lexterm77L Offline
                        lexterm77 Bronze Member @Vincenzo Ucciero
                        @Vincenzo-Ucciero said in Suunto 9 Baro quick discharge problem:
                        1. Buy those cheap usb mAh recorders
                        2. Reset Usb recorder to zero mAh
                        3. Empty you watch battery until is black
                        4. Charge using usb (see note 1)
                        5. Record mAh once charge reaches 99%
                        6. If your mAh is around 250, you have a good battery but a drain due to water or a bad board,send it to service
                        7. If your mAh is way less than 250, you have a bad battery, send it to service
                        • sartoricS Offline
                          sartoric Moderator
                          … so maybe … contact support and ask them. Maybe it’s defective and you need to return it.
                          SVTS - 2.50.28
                          SSSWHR BARO Amber - 2.8.32
                          Samsung A5 2016 - Android 7.0
                          Suunto App Android 6.11.8 beta
                          • surfboomerangS Offline
                            surfboomerang
                            Too early to draw any conclusion, but I noticed similar behaviour with my S9. Mine is 1.5 years old now and the last couple of weeks I noticed that watch drain battery faster than it did before.
                            When I bought the watch I could almost do 12-14 days on a single charge with notifications on and a couple of hours of activity recording.
                            Now I can barely reach 7-8 days on a single charge with the same settings.
                            Due to a lot of factors and the fact that I didn’t record the draining process, I can’t conclude that it is a bad battery or the use of the watch changed over the last year.
                            I let it run out of battery now until it switches off and will then do a full recharge. I will monitor the battery use more closely to hope that I can make any conslusions.
                            I will keep you informed…
                            Suunto Vertical Titanium Solar
                            OnePlus Nord 4
                            A Vincenzo UccieroV surfboomerangS 3 Replies Last reply Reply Quote 2
                            • A Offline
                              Atlen @surfboomerang
                              @surfboomerang one more reason is FW has changed since you bought the watches.
                              Suunto S9 Baro
                              Suunto Ambit3 Sport
                              Suunto smart sensor
                              IPhone 12, iOS 14
                              surfboomerangS 1 Reply Last reply Reply Quote 0
                                Vincenzo Ucciero @surfboomerang
                                @surfboomerang I see, you moved from an extra long duration to a ‘normal’ duration… mine is 1 week old and it lasts 1,5 day(s)… makes me loose my senses 🤕
                                • isaziI Offline
                                  isazi Moderator @Vincenzo Ucciero
                                  @Vincenzo-Ucciero if your S9 lasts only a day, and you are not doing 15 hours of GPS tracking a day, please contact support because your watch must be faulty.
                                  Blog: isazi's home
                                  • Bogdan1921B Offline
                                    Bogdan1921 Silver Members Bronze Member
                                    4 Days with 6h of activities (Performance mode).
                                    My watch was brought in November 2018.
                                    At the beggining with sleep tracking, Daily HR 24/7, Notification and backlight (30-40%) it used to leasts almost 7 days.
                                    After one year, I’ve observed that the battery is drainer faster, with the same settings. Maximum 5 days.
                                    Suunto Race
                                    Polar H10
                                    Iphone 14 Pro
                                    Suunto 9 Baro [sold]
                                      surfboomerang @Atlen
                                      @Atlen True. Also Suunto app has changed over time. I don’t know if it communicates more with the watch or syncs different.
                                      OnePlus Nord 4
                                        But official from Suunto there is an answer regarding the battery drain after the last updates?
                                        I don’t know, would be better to know that yes, the battery drain faster or no (then is a watch problem)? They know and are working to improve this? Does it know somebody?
                                        Thanks
                                        Suunto Race
                                        Polar H10
                                        Iphone 14 Pro
                                        isaziI lexterm77L 2 Replies Last reply Reply Quote 0
                                        • isaziI Offline
                                          isazi Moderator @Bogdan1921
                                          @Chindris-Bogdan we all found out that the new Firstbeat metrics computed on the watch (e.g. stress and hrv) consume more battery than before.
                                          Blog: isazi's home
                                            lexterm77 Bronze Member @Bogdan1921
                                            @Chindris-Bogdan said in Suunto 9 Baro quick discharge problem:
                                            Thanks
                                            Did you measure how much energy does it take to charge battery from 0% to 100%?
                                            I charged my watch to 95% this morning at 7am, I had a 150minute activity at performance gps, heart belt and power pod on, no power saving, hr monitoring on, autolap on, it is now 7pm and my charge is 74% and I consider this normal.
                                            I Have watch since August 2018 and I need approximately 20% per day no activity. Activity requires additional 4-5% per hour of activity at performance gps, hr belt and power pod. I have dnd enabled from 22h to 6am and sleep tracking from 2pm all the way to 9am. My battery has lost about 5% of capacity since it was new. My backlight is set at 30%. I run SA only to sync activity and gps dats, no background syncing. No alarms, no standby backlight, button sound off all vibration on.
                                            I remember having to charge once a week without activity but after FB features last fall, those memories have quickly faded.
                                            If you think there is a problem you should try to narrow it down to the battery or device side.
                                            Bogdan1921B 1 Reply Last reply Reply Quote 1
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
