    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    AGPS not updating on Suunto 9 Baro
    9 Posts 8 Posters 736 Views 8 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • ? Offline
      A Former User
      Re: S9 Baro takes very long to find GPS signal before a move
      I am continuing to have issues with AGPS not updating on my S9 Baro and GPS lock taking increasingly long times.
      Currently AGPS timestamp on my watch shows 2019-11-18. I sync almost daily.
      Every two weeks or so I have to reset my watch after which it does download new AGPS file, but after a few days the issue repeats.
      I remember this issue has reportedly been fixed a few months ago, and it was a server side issue, but that doesn’t appear to be the case for me. I wonder if anyone else continues having these issues.
      I sync mostly with MC app if that matters, but supposedly that shouldn’t matter.
      freeheelerF 1 Reply Last reply Reply Quote 0
      • isaziI Offline
        isazi Moderator
        I synch only with SA, never used MC, and don’t have this issue.
        Blog: isazi's home
        • freeheelerF Offline
          freeheeler @Guest
          @silentvoyager
          I only sync to SA, too and don’t see this issue either
          living sideways
          • S Offline
            Shrek3k
            Syncing with SA (Bluetooth) and MC (cable) … no issues either (S9 - non-Baro)
            using a Suunto Vertical & Suunto Wings; mostly running (AKA stomping around) and cycling through the northern german "wilderness", and wherever else I have the chance to do so
            OS - Android 16/Pixel Pro 7
            • N Offline
              nseslija Bronze Member
              No issues… Syncing with SA… S9B…
              Ambit 2S
              Ambit 3 Peak
              Suunto 9 baro
              Suunto Vertical Ti Solar
              • Brad_OlwinB Online
                Brad_Olwin Moderator
                My S9b is not having this issue but my S5 is. Requires many sync attempts to get the AGPS file to finally copy. I will ask about this and file a bug if needed. I do not understand why this is happening iOS 13.3; latest SA beta.
                Vector/T6c/Ambit 3 Peak/S5 Copper/S3/S7 Ti/S9 baro Ti/S9P Ti/S9PP Ti/Vertical Ti/Race Ti/RaceS/Ocean/Wing/Race2Ti
                • zvonejanZ Offline
                  zvonejan Bronze Member
                  the problem is in latest version of Movescount or suunto link, I dont know which one. I had the same problems. I still use Movescount as my primary app, but I also sync with SA, just for updating AGPS. I just can not use android Movescount enymore. You can use custom graphs in movescount also if you are patien and imaginative and you can have best from both worlds
                  • ? Offline
                    A Former User
                    I really wanted to avoid syncing with SA until I have to switch, but it looks like I have to give it another try. I really dislike that it wants tons of permissions and wants to run all the time in background. That has no upside in my use case and only shortens the watch battery life. And on top of that, it will now force the wrong starting day of week on my watch.
                    Dimitrios KanellopoulosD 1 Reply Last reply Reply Quote 0
                      Dimitrios Kanellopoulos Community Manager @Guest
                      @silentvoyager You can also not give the permissions.
                      Movescount as far as I know has more permissions that are granted on Install time not on runtime.
                      The only permission SA really needs is BT / Location and the location permission is due to BT that is a location leaking module.
                      The apps does not run in the background, a sync service to listen to BLE runs that is part of the app.
                      Creator of Quantified-Self.io
                      youtube.com/c/dimitrioskanellopoulos
                      https://instagram.com/dimitrioskanellopoulos
                      https://www.strava.com/athletes/7586105
                      • First post
                        Last post
                      Suunto Terms | Privacy Policy
