    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Pros/Cons of Suunto 9 BARO * ONLY * be fair and polite!
    330 Posts 46 Posters 69.4k Views 48 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • freeheelerF Offline
      freeheeler @Guest
      @silentvoyager
      šŸ•µ
      ok, it’s not fair to compare apples with pears
      living sideways
      • Saketo NemoS Offline
        Saketo Nemo Moderator
        Just for what’s my experience: as mentioned, it is transreflective. The more light it receives, the better it is seen. So it’s due to inclination. If you are in the dark you do not see it, otherwise just turn the watch in one other inclination.
        freeheelerF 1 Reply Last reply Reply Quote 1
          freeheeler @Saketo Nemo
          @Saketo-Nemo
          most important in daylight it works šŸ‘Œ
          great, I appreciate this Infos to move myself closer to a potential upgrade šŸ˜‰
          living sideways
          sartoricS 1 Reply Last reply Reply Quote 2
          • sartoricS Offline
            sartoric Moderator @freeheeler
            @TELE-HO said in Pros/Cons of Suunto 9 BARO * ONLY * be fair and polite!:
            In full sun daylight it works like a charm. šŸ˜Ž šŸ˜„
            SVTS - 2.50.28
            SSSWHR BARO Amber - 2.8.32
            Samsung A5 2016 - Android 7.0
            Suunto App Android 6.7.12 beta
            S 1 Reply Last reply Reply Quote 1
              Dimitrios Kanellopoulos Community Manager @Mi_chael
              @Mi_chael i said what a user could do eg if running in a city at night since he asked how to light the screen.
              freeheelerF M 2 Replies Last reply Reply Quote 1
              • ? Offline
                A Former User @freeheeler
                @TELE-HO Yes, I’ve never had an issue with A3P. Different display technology.
                  freeheeler @Dimitrios Kanellopoulos
                  @Dimitrios-Kanellopoulos
                  yes, when I can start doing sport again it will be most likely running (even I am not a runner…) and most likely at night since it will be winter then… won’t be a problem with the BD storm šŸ˜€
                  I thought more of some situations when you look at the watch quickly just to know the time and date… in any random situation
                  living sideways
                  • M Offline
                    Mi_chael Bronze Member @Dimitrios Kanellopoulos
                    @Dimitrios-Kanellopoulos said in Pros/Cons of Suunto 9 BARO * ONLY * be fair and polite!:
                    Ok okšŸ‘
                    Dimitrios KanellopoulosD 1 Reply Last reply Reply Quote 0
                      @Mi_chael but you re right. With a headlamp and no other light the watch + backlight can actually become dangerous.
                      freeheelerF 1 Reply Last reply Reply Quote 0
                        what, why?
                        living sideways
                          Dimitrios Kanellopoulos Community Manager @freeheeler
                          @TELE-HO When on the forest/ mountain and running with a headlight or without (That I do many times on a full moon) any other light might ā€œfogā€ the vision.
                          I do find the watch light in the pitch black a bit of a distraction as the least I can say.
                          Or is this just me?
                          freeheelerF 2 Replies Last reply Reply Quote 2
                            running on even surface at full moon would work for me. but as soon as I go to the forest, night hiking or skitouring, I wear a headlamp that’s bright enough to see roots and dangers. of course the watch light must be darker so you’re not blinded by it…
                            living sideways
                              well of course, slow ski ascents normally don’t require a headlamp as snow reflects even with new moon
                              living sideways
                              Dimitrios KanellopoulosD 1 Reply Last reply Reply Quote 2
                                @TELE-HO no ski for me , yet šŸ˜„
                                Many things regarding ridge running and mountain running but no ski šŸ˜•
                                cosme.costaC 1 Reply Last reply Reply Quote 0
                                • Brad_OlwinB Offline
                                  Brad_Olwin Moderator @freeheeler
                                  hey guys and ladies that come from ambit and are happy with s9b now:
                                  how did you get rid of your ambit apps addiction? didn’t you use the apps at all? or did s9b display values that made apps not required for you anymore?
                                  or are there apps (hence values) that you miss now?
                                  For me:
                                  1. S9b battery life is a winner and FusedTrack is just amazing…so I have 50h-120h of battery life unachievable with Ambit
                                  2. ETE/ETA displays were what I used apps for
                                  3. I don’t need complex intervals and intervals on S9b are good enough
                                  4. Vertical speed fields are good enough on S9b
                                  5. What other apps do folks need
                                  Vector/T6c/Vertical 2 Ti
                                  ? 1 Reply Last reply Reply Quote 1
                                  • cosme.costaC Offline
                                    cosme.costa @Dimitrios Kanellopoulos
                                    I have quite experience to run in the forest with headlamp and my SSU (same technology as S9) as 95% of my runs start between 6 and 6.30 a.m., so I use the headlamp more than half a year.
                                    My experience so far is that if you are running in the dark (only headlamp) in the forest and at nice pace pay attention to the trail and check the watch later. And I use a Petzl Nao as headlamp so no issues with the amount of light.
                                    Returning to the topic, using a headlamp with a wide angle, is quite easy to check the watch in a glimpse. I have even followed some routes in close night only with the headlamp and the watch without problems. Besides, I do not know how many times do you need to check your watch, but with the 1 km watch split the screen turns on and you have time to see the summary and the sports field.
                                    1 Reply Last reply Reply Quote 3
                                      This post is deleted!
                                      • ? Offline
                                        A Former User @Brad_Olwin
                                        @Brad_Olwin said in Pros/Cons of Suunto 9 BARO * ONLY * be fair and polite!:
                                        I find vertical speed to be way too jumpy, at least when measured in ft/hour - that is what the default mountain running sport mode has.
                                        Recently I realized that in custom mode an alternative vertical speed field can be used which shows speed as ft/min. @Brad_Olwin, is that the field you use?
                                        Brad_OlwinB 1 Reply Last reply Reply Quote 1
                                          Brad_Olwin Moderator @Guest
                                          @silentvoyager I use ft/hr as most of the uphills that I do are very long. For SkiMo I find ft/hr useful and not jumpy but I also use speed so I can see if my downhill laps (typically during races) are equal or if I have slowed down. I would use ft/min if the hills were smaller. My hills are usually a minimum of 700m.
                                            freeheeler @Brad_Olwin
                                            @Brad_Olwin
                                            I use m/h for all my activities.
                                            I’ve set it up for ascent rate on ascents only, ascent rate for the entire recording and ascent rate ā€œnowā€.
                                            depending if it’s a lot of ups and downs or long flats between ascents or only one long climb it’s very useful. I assume this is not possible with s9b?
                                            living sideways
                                            Brad_OlwinB ? 2 Replies Last reply Reply Quote 0
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
