    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    S9 Baro: Altitude in the same place decrease every day
    10 Posts 5 Posters 708 Views 4 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • aldnetA Offline
      aldnet
      I’ve found that the altimeter data in the watchface, even in the workouts, in the same place, decrease everyday.
      For example I set up and automatic calibration in my house, usually it set up between 76 and 80m. That’s correct for me, in Google Earth the altitude is 78m.
      And after that every day the altimeter value decrease, 3-4 meters. For example today is set up to 22m.
      This also happens when I set up the altitude manually, following Google Earth reference. Always ends near 0m.
      Is something related with software? Hardware issue?
      If it’s a repeated subject, sorry, I try to search if it’s someone with the same problem and I’m capable to find.
      Suunto 9 Baro Black (2.11.38)
      Suunto App IOS 1.50.0 (8284)
      iPhone 11 Pro (iOS 14 Beta 4)
      Dimitrios KanellopoulosD 1 Reply Last reply Reply Quote 1
        Dimitrios Kanellopoulos Community Manager @aldnet
        @aldnet that looks quite fine. 3-4 meters is low.
        Probably its pressure change as on non activity mode there is no GPS altitude to guide the watch.
        Creator of quantified-self.io a portal that allows you to analyze your data from various providers, upload fit activity files to Suunto app, gpx routes and more…
        cosme.costaC 1 Reply Last reply Reply Quote 1
          Another thing that can infuence this (but then it might be something tricky) is temperature.
          If for example you leave the watch at the balcony and get it like after x hours that the temperature changes rapidly
          • cosme.costaC Offline
            cosme.costa @Dimitrios Kanellopoulos
            @Dimitrios-Kanellopoulos said in S9 Baro: Altitude in the same place decrease every day:
            @Dimitrios-Kanellopoulos I think that @aldnet means that He sets the altitude one day, and it’s correct, and doing nothing every day the altitude decreases some meters until it’s zero and remains zero until it’s set again. Did you mean that @aldnet ?
            Dimitrios KanellopoulosD aldnetA 2 Replies Last reply Reply Quote 2
            • AudaxjoeA Offline
              Audaxjoe
              Well my Garmin Fenix used to drop to -5000 meters when I was at home… And some times pop up to + 8000 meters (as did my Fenix 3HR) so I’m really happy with the amount the 9 Baro drifts 🙂
              Suunto Vertical
              Suunto 9 BARO
              Garmin Fenix 3, 5
              Suunto Vector
                Dimitrios Kanellopoulos Community Manager @cosme.costa
                @cosmecosta oh it remains 0? ? ?
                • aldnetA Offline
                  aldnet @cosme.costa
                  @cosmecosta @Dimitrios-Kanellopoulos yes, that is the case, but doesn’t stop to 0, in fact it continuous decrease, the case I remember I reset when it was to -22m
                  @Dimitrios-Kanellopoulos if I take the discipline to do some activity everyday that should be a way to avoid these behaviour?
                  Dimitrios KanellopoulosD 1 Reply Last reply Reply Quote 0
                    @aldnet I would clean the sensor. I get this behaviour ususally the more the sensor gets dirty , that it can due to shower etc.
                    Let it soak to water, flush under the tap on the pressure sensor holes, repeat a couple of times.
                    aldnetA 1 Reply Last reply Reply Quote 1
                    • aldnetA Offline
                      aldnet @Dimitrios Kanellopoulos
                      @Dimitrios-Kanellopoulos ok, I will do and see what’s happening
                      • ? Offline
                        A Former User @aldnet
                        @aldnet any news about this ? i’m in the same case.
                        My sensor is pretty clean, i don’t take shower with the watch. It’s starting to do this since one or two weeks.
                        I have to set it 3 or 4 times per week if i haven’t activities.
                        • First post
                          Last post
                        Suunto Terms | Privacy Policy
