    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Suunto Spartan Trainer HR charging time
    Scheduled Pinned Locked Moved Spartan
    12 Posts 6 Posters 1.5k Views 6 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • E Offline
      endon
      Hi.
      I just bought a Spartan Trainer and put to charge with around 60% battery on it.
      It’s been 7h since then, and right now the battery % is sitting at 89%.
      I’m using a Samsung charger from my S8+ (5V/2A).
      Tell me this isn’t normal… but if it is, what’s the expected time for a full charge (0 to 100%).
      Thanks.
      sartoricS gerhardusvbG 2 Replies Last reply Reply Quote 0
      • sartoricS Offline
        sartoric Moderator @endon
        @endon
        Well, not really normal.
        Maybe you need to calibrate the battery. Let it discharge completely and then charge it and see what will happen.
        If it never reach 100% (or 99% on trainer) the battery probably needs a replacement.
        SVTS - 2.50.28
        SSSWHR BARO Amber - 2.8.32
        Samsung A5 2016 - Android 7.0
        Suunto App Android 6.11.12 beta
        E sartoricS 2 Replies Last reply Reply Quote 0
        • E Offline
          endon @sartoric
          @sartoric thanks for the reply.
          It’s a new watch, I bought it last weekend ☹
          • sartoricS Offline
            sartoric Moderator
            Ohh …
            Did you try to connect it to a computer usb ?
            Let’s say that calibration could be necessary anyway
            SVTS - 2.50.28
            E 1 Reply Last reply Reply Quote 0
            • E Offline
              endon @sartoric
              @sartoric I connected it to a computer only for setup. Not really into charging it things that way, so that can’t be an option. Might try with a less powerful charger (5V/1A).
              Regarding the calibration, I’ll try to do it, but not really sure how that procedure might be relevant in this case, since we’re talking about time to charge, not battery reading/accuracy.
              • EgikaE Offline
                Egika Platinum Member
                Some chargers (and even more so powerbanks) switch off, once the charging current is below a certain threshold.
                For the watch, the current is 350mA at the beginning and less and less, once the battery fills.
                • gerhardusvbG Offline
                  gerhardusvb Bronze Member @endon
                  @endon
                  Hi. i also experience charging issues when using my cellphone charger, used several different ones. maybe it is due to the explanation as per @Egika 's message.
                  I also found long charge times and also sometimes that it shows the battery is full but then drops quite rapidly after charging.
                  Unfortunately i also found the best charging results when doing it via the laptop.
                  Huawei Mate20 Lite Android 8.1
                  • E Offline
                    endon @gerhardusvb
                    @gerhardusvb I got it working better with a generic 5V/1A charger I had lying around. Got really fast to 99%, mas got stuck there for the last couple of hours without moving. Unplugged the damn thing and immediately dropped to 90%. Plugged it into the PC and went up to 95% instantaniously. It’s the 1st time I’m charging it since I bought it but boy, this is some erratic behavior for an electronics device.
                    Mff73M H 2 Replies Last reply Reply Quote 0
                    • Mff73M Offline
                      Mff73 @endon
                      @endon
                      It was said somewhere that watch won’t charge to 100% with wall charger, but only with computer 🙂 *
                      Don’t remember why and where .
                      SSU (retired), SV1, SV2
                      Wife : S9PP
                      SA: Always the latest beta :)
                      Android + Galaxy S205G
                      • H Offline
                        hubertus46 Bronze Member @endon
                        @endon stay calm on the Spartan Trainer this behavior is Normal.
                        The program that shows the battery capacity is
                        not starte of the art, i guess this can be improved…
                        • sartoricS Offline
                          sartoric Moderator @sartoric
                          As I said 99% is ok on trainer
                          Trainer battery management, due to the cheaper/lower level battery and components, lacks a bit of precision, and it measures battery discharge by 10% steps (maybe 15% idrw)
                          SVTS - 2.50.28
                          • E Offline
                            endon
                            Thanks everyone for the help.
                            Register Login
                            • First post
                              Last post
                            Suunto Terms | Privacy Policy
