    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Suunto 3 Fitness Thoughts
    Scheduled Pinned Locked Moved Suunto 3
    174 Posts 24 Posters 39.7k Views 24 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • Armin S.A Offline
      Armin S. @Dimitrios Kanellopoulos
      @Dimitrios-Kanellopoulos said in Suunto 3 Fitness Thoughts:
      @Svetlin-Tonchev said in Suunto 3 Fitness Thoughts:
      … Are the sleep times ok?
      For me the start of sleep time often is one to two hours late.
      SlaShS 1 Reply Last reply Reply Quote 0
      • P Offline
        PC_et
        I had opposite situation couple of times - for example 3 hours less. But found the coincidence - it happened only if i stood up for a while (during the night) and than got back to sleep. Probably watch recorded it as wake up time.
        Other issue: I was at the swimming pool (25 meters) 3 times lately and decided to use swimming option (perfect for someone like me: "how many pools have I already done…?) . Every time first pool was counted as 50 meteres. So I ended up with 25 meters too much.
        • SlaShS Offline
          SlaSh Platinum Member @Armin S.
          @Armin-S how do you know exactly when you went to sleep? Laying on the bed is not sleep 🙂
          Armin S.A 1 Reply Last reply Reply Quote 0
          • Armin S.A Offline
            Armin S. @SlaSh
            @SlaSh That’s exactly the problem! If I read in bed for half an hour, the S3F can not cope.
            Let’s insert the function/button “start sleeping” (and then gives extra eg 15…30 minutes). The automatic does not work unfortunately.
            BTW: The automatic recognition of a workout was indeed already discussed here in another thread and considered not useful. That’s exactly how it is with the start of sleeping.
            Sorry for the duplicate entry, but I slept very little - according to my S3F 😵
            SlaShS 1 Reply Last reply Reply Quote 1
            • SlaShS Offline
              @Armin-S start sleep wouldn’t be true sleep as you wont get into sleep after pressing the button immediately, so kinda sleep button is pointless…
              Dimitrios KanellopoulosD Armin S.A 2 Replies Last reply Reply Quote 1
                Dimitrios Kanellopoulos Community Manager @SlaSh
                @SlaSh 😮
                Creator of quantified-self.io a portal that allows you to analyze your data from various providers, upload fit activity files to Suunto app, gpx routes and more…
                • Armin S.A Offline
                  Armin S. @SlaSh
                  @SlaSh But that way as the sleep tracking NOW works, it is also pointless. The real time of falling asleep is unfortunately very often not recognized by the S3F!
                  So: thoroughly revise and correct or consider my proposal (button and configurable time - just like some other smartwatches do) - optional for (possibly not working) automatic.
                  Of course, the automatic would be better - but then it has to work correctly!
                  • ? Offline
                    A Former User @Armin S.
                    @Armin-S You know, I have a thing for sleep tracking, so I tried most of the activity trackers out there and then some. I don’t have a problem sleeping, mind you 😛 I do have a big problem stopping myself from a million things that at the time seem far worthier pursuits than sleeping. Well, the morning is usually a different story 😴
                    None of the trackers can accurately detect sleep day in and day out. Polar had me always fall asleep few hours too late. Garmin was all over the map until recently, still isn’t very accurate, especially if you lie quietly reading a book inside your do-not-disturb ours. Fitbit was fairly close but then would have me sleep-walking in the middle of the night. Oura wasn’t bad, but had its issues. If it was wrong, it was really wrong. I can go all the way back to Jawbone and Basis.
                    Things should improve though. There’s a lot you can add to accelerometer data with ORH and HRV to better detect sleep state and phase. Hopefully, Suunto/Firstbeat would look into this.
                    • Armin S.A Offline
                      Armin S. @Guest
                      Exactly as you say @NickK. If Suunto does not get it right with the automatic, then please provide a manual version and start recording at the time specified by me. And then I know where possible mistakes come from and don’t miss 2…3…4 hours on sleep (recording). Luckily I’m sleeping and dreaming anyway 😇
                      • Brad_OlwinB Offline
                        Brad_Olwin Moderator
                        I have had very good luck with sleep tracking on the latest firmware by inserting my sleep times and then selecting DND manually. I typically will go to bed and then select DND but either watch a little TV news or read a few minutes before I fall asleep. The fall asleep time on my S9 has been very accurate. I don’t use this much but wanted to test it for my traveling to Europe. When I was using autoDND it seemed far less accurate.
                        Vector/T6c/Vertical 2 Ti
                        • Armin S.A Offline
                          Armin S. @Brad_Olwin
                          @Brad_Olwin said in Suunto 3 Fitness Thoughts:
                          … When I was using autoDND it seemed far less accurate.
                          Thanks for the tip, I will then use the DND accordingly. Would be nice if it works better then 😴
                          • J Offline
                            Jouko Tyni @Svetlin Tonchev
                            @Svetlin-Tonchev The fix for ‘sleep steps’ will come later, so we were aware of that issue. Unfortunately it dropped from this release. Currently this new approach seems to give statistically about 30% less steps than the previous ones.
                            Armin S.A 1 Reply Last reply Reply Quote 1
                            • Armin S.A Offline
                              Armin S. @Jouko Tyni
                              @Jouko-from-Suunto That sounds hopeful! Above all, it’s good to hear that Suunto cares about that - and not just here in the forum.
                              P.S. By the way, my attempt with DND was unsuccessful. Last night was missing again 1:30 h to start.
                              • Steven SmithS Offline
                                Steven Smith
                                Interesting take! A lightweight Suunto with Stryd support would be a game-changer for runners. I doubt they’ll add it, but if they did, I’d consider it too. The T6c was legendary—2000 miles is impressive!
                                • isaziI isazi moved this topic from The Lounge on
                                • First post
                                  Last post
                                Suunto Terms | Privacy Policy
