    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Suunto 9 GPS good mode have bug
    Scheduled Pinned Locked Moved Suunto app and other software services
    10 Posts 4 Posters 968 Views 4 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • K Offline
      Kenneth Chan
      I have used Suunto 9 with accuracy Good mode to join two 100km competitions and both results of kilometer were wrong. however, if used accuracy best mode or ok mode, the result was correct.
      kolyany4K 1 Reply Last reply Reply Quote 0
      • sartoricS Offline
        sartoric Moderator
        I guess this is already known, but let’s wait for a confirmation from S9 owners or from @Dimitrios-Kanellopoulos
        SVTS - 2.50.28
        SSSWHR BARO Amber - 2.8.32
        Samsung A5 2016 - Android 7.0
        Suunto App Android 6.7.12 beta
        • kolyany4K Offline
          kolyany4 Bronze Member @Kenneth Chan
          @Kenneth-Chan
          Perhaps, You encountered something similar to my problem:
          https://forum.suunto.com/topic/1371/s9-2-4-14-calibrate-fusedtrack-interface-problem-suunto-case-01853829/21
            Dimitrios Kanellopoulos Community Manager
            what do you mean exactly ?
            Creator of quantified-self.io a portal that allows you to analyze your data from various providers, upload fit activity files to Suunto app, gpx routes and more…
            • K Offline
              Kenneth Chan
              ![alt text](image url)https://drive.google.com/file/d/1TjrDvOp1Ges9go9S5mXnvws_gFk232Lf/view?usp=sharing
              ![alt text](image url)https://drive.google.com/file/d/1vn2BBD8O3nkrlj1T5bef1Ldl--9w7re_/view?usp=sharing
                that is not good. What mode was it ?
                • sartoricS Offline
                  sartoric Moderator
                  @Kenneth-Chan said in Suunto 9 GPS good mode have bug:
                  It looks like a UTM zone issue.
                  That area seems to be the borders of zones 49Q and 50Q
                  SVTS - 2.50.28
                  • K Offline
                    Kenneth Chan @Dimitrios Kanellopoulos
                    @Dimitrios-Kanellopoulos GPS accuracy is good mode
                    • K Offline
                      Kenneth Chan @sartoric
                      @sartoric I don’t know if it’s a zone problem, also SUUNTO can’t help me to solve it and only suggestion to use the best mode of GPS accuracy.
                      Suunto reply below:-
                      You can either choose between getting longer battery life with less accurate data or you can choose getting the best data with lower battery life. We understand that you want to get both. However, in cases like GPS connection, the BEST GPS accuracy is required to get the most accurate track. As mentioned having the BEST GPS accuracy can lessen battery life but it can provide a more accurate information given that the move was done in the most ideal environment. PERFORMANCE mode would still be the best option for this to get the data you want.
                        No this is for sure a bug I bet
                        • First post
                          Last post
                        Suunto Terms | Privacy Policy
