    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Watch not connecting to wifi for map download
    Scheduled Pinned Locked Moved Suunto Vertical
    7 Posts 4 Posters 111 Views 4 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • R Offline
      Rokelly
      Cannot download maps to the watch
      Suunto Vertical with software 2.50.28
      The watch is connected to Suunto App and tells me a wifi network has been setup.
      The watch wifi setting is set to auto
      When I try and download a map the watch attempts to connect to the wifi network and then fails!!
      The iPhone and watch are close to the router.
      I’ve done a factory reset, but this hasn’t solved the issue.
      cosme.costaC 1 Reply Last reply Reply Quote 0
      • cosme.costaC Offline
        cosme.costa @Rokelly
        @Rokelly Check your router, the watch must be using the 2.4 band.
        • R Offline
          Rokelly
          I’ve downgraded the software to 2.50.26, but that hasn’t altered the problem.
          I’ve gone to Control Panel-Settings-About. scrolled all the way down to the base of the menu then pressed the down button for a few seconds until the debug menu appears.
          The wifi menu confirmed it is not connected and there is no IP address
          • R Offline
            Rokelly
            So the App is telling me the watch is ‘all set’ and connected to a wifi network. But the watch itself won’t connect to a wifi network. All very frustrating.
            L 1 Reply Last reply Reply Quote 0
            • L Offline
              larrybbaker @Rokelly
              @Rokelly you are connecting to a 2.4 ghz network?
              Vertical Ti Solar
              Vertical 2
              Race 2
              iPhone 17 Pro
              R 1 Reply Last reply Reply Quote 0
              • R Offline
                Rokelly @larrybbaker
                @larrybbaker 2.5ghz. At least that what it states on the router.
                J 1 Reply Last reply Reply Quote 0
                • J Away
                  johann.fuehrer Silver Members @Rokelly
                  @Rokelly Make sure the SSID is not hidden and some special flags are not set on the router. This setting made me problems: “802.11r Fast Transition”. I needed to disable it on my router for several devices to work. Also authentication should be WPA2-PSK
                  And I run into my self-made problem by having only specific MAC addresses allowed and forgot to add the watch in the list.
                  That’s all I have in mind…
                  "Trail running is the answer. Who cares what the question is …"
                  Register Login
                  • First post
                    Last post
                  Suunto Terms | Privacy Policy
