    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Deco dive planner
    Scheduled Pinned Locked Moved Nautic
    3 Posts 2 Posters 109 Views 3 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • MigseyM Offline
      Migsey
      Hi there,
      I was planning a dive on my new and shiny Nautic, with the idea of going down to 30 metres on EAN32 and having a bottom time of 25 minutes. Even with a mildly aggressive GF of 45/90, I know there will be at least one minute of deco.
      When entering the data into the computer and looking at the dive phases, however, I find the way it displays the timings extremely confusing. I have taken a few screenshots of the dive plan and crudely stitched them together for illustration purposes.
      My main confusion is that the computer does not seem to show the ascent (or descent) times.
      From 30 metres to 6 metres, I worked out — not without a few calculations — that the ascent time is approximately 2’25", which roughly corresponds to an ascent rate of 10 m/min. The same applies to the ascent from 6 metres to 3 metres.
      Would anyone else agree that having a column showing the ascent/descent times would be very useful? It would make the overall dive plan much easier to understand and, more importantly, would give a much clearer picture of the actual time required for each phase of the dive.
      There is another thing I don’t particularly understand: the use of a 3-metre safety stop, especially in the sea, where swell can make maintaining 3 metres quite tricky. I believe I have specced in the settings that the last stop should be at 6m
      Why doesn’t the software indicate that the final stop should be at that depth instead? In this particular case, I would have expected the plan to show 4 minutes at 6 metres, followed by approximately 19 seconds to ascend to the surface.
      Am I misunderstanding the way the Nautic displays its dive phases, or is this simply a limitation of the current planner?
      Thanks in advance
      VoiGASV 1 Reply Last reply Reply Quote 3
      • VoiGASV Offline
        VoiGAS Gold Members @Migsey
        @Migsey I think the “last stop” option only works for deco dives. Safety stop can be done between 6m and 3m.
        Maybe the 3m is the default value for the planner, because it cannot calculate a range.
        Race S
        Vertical Titanium Solar
        Ambit3 Vertical
        Eon Core
        MigseyM 1 Reply Last reply Reply Quote 0
        • MigseyM Offline
          Migsey @VoiGAS
          @VoiGAS thanks for your reply. I think that this is a bug… I did a dive today , went into deco and the computer states a mandatory stop at 6 m and, at the end of this stop, a safety stop at the same depth. No mention of safety stop at 3 m at any time …
          Register Login
          • First post
            Last post
          Suunto Terms | Privacy Policy
