    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    2.53.42 Race S and Pathetic battery life
    Scheduled Pinned Locked Moved Suunto Race S
    16 Posts 6 Posters 1.1k Views 6 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • withManishW Offline
      withManish Bronze Member
      had auto-update turned off on my watch, but it somehow updated automatically, and since then the battery performance has been terrible.
      The battery life has dropped significantly, and I’m now getting only 4–5 days of backup. The battery drains by around 15% or more every day, which is quite abnormal for my usage pattern.
      Before the update, I would easily get around 8 days of battery life, including 5–6 workouts of about 2 hours each using GPS (without heart rate monitoring).
      I’ve already turned off notifications and keep the watch in Airplane Mode most of the time, but neither seems to make any difference.
      Is anyone else experiencing the same issue after the update? Would a factory reset be worth trying?
      www.withManish.com
      G M 2 Replies Last reply Reply Quote 1
      • G Offline
        Gunnar Bronze Member @withManish
        @withManish I totally understand your frustration. And that the watch updates although you disabled it, is a no go. But in the end there is an easy work around until this is fixed. Just put it on a charger for some minutes, the watch charges quickly. It is not as it should be but works fine. I don’t think that a reset fixes it according to other users.
        withManishW 2 Replies Last reply Reply Quote 0
          withManish Bronze Member @Gunnar
          @Gunnar Thank you, my friend. Each update comes with worse issues, especially with the battery. Let’s wait until things get resolved.
          www.withManish.com
            @Gunnar, Funny part, my watch uses 7-10% of its battery even in power-save mode overnight.
            www.withManish.com
            OutdoorManO 1 Reply Last reply Reply Quote 0
            • OutdoorManO Offline
              OutdoorMan Silver Members @withManish
              @withManish try to check if see a HR belt or something connected via Bluetooth. Also try to soft reset the watch (hold for 12 second the upper top button). That might help for some time.
              withManishW 1 Reply Last reply Reply Quote 0
                withManish Bronze Member @OutdoorMan
                @OutdoorMan, noting connected (I don’t own an HR belt) and not sure why Bluetooth is still on even after I put it in power-saving mode. Bluetooth is on during my workout, so I can see notifications from my phone; otherwise, it’s off. I keep Aeroplane mode on, so wireless and Bluetooth are off during regular daytime use.
                www.withManish.com
                • M Offline
                  matram Bronze Member @withManish
                  @withManish
                  Are you sure about these numbers. I have had my Race S for a year, I get about 4 days of use with 4 hours running total, using Polar H10 HRM. I do not believe that has changed significantly during the year.
                  I would expect some cost in battery life when Suunto add new features.
                  withManishW 1 Reply Last reply Reply Quote 1
                    withManish Bronze Member @matram
                    @matram, my watch is not that old, and before the new firmware, everything was working perfectly.
                    www.withManish.com
                    • A Offline
                      alp1n3
                      Same.
                      I’ve had mine for less than a year, and I’m now getting 2-3 days max out of it.
                      Bluetooth connected only to my phone, auto-updates are turned off (but it still updates anyways). The battery has gotten much worse since the last updates. I’ve reset the watch 3 times, one of which wasn’t on purpose but one of the auto-updates bricked the watch.
                      Switching to Garmin since Suunto has had over a year to fix the auto-update bug, but can’t manage that.
                      withManishW E 3 Replies Last reply Reply Quote 1
                        withManish Bronze Member @alp1n3
                        @alp1n3 Right, every update comes with more issues; I do get other glitches, but a core power issue? Power is what we all need in such watches, which is why I choose them over Apple and other smartwatches. They are also walking down this path. We need a basic, robust system, not freels, which, anyway, are not accurate.
                        www.withManish.com
                        • E Online
                          elbee @alp1n3
                          You are of course free to switch brands when ever you like and I think it is interesting to see the approach of others.
                          However… if you switch brands in the expectation to find a bug free watch with great battery life, you will be disappointed. I switched from a very expensive forerunner 965 to my current race s. For me, battery life is about the same (garmin charge every 3 or 4 days, suunto every 4 days) but the amount of bugs I experienced on that garmin is incredible.
                          Suunto t3c | Suunto Ambit 3 sport | Tomtom runner 2 | Garmin forerunner 935 | Garmin forerunner 965 | Suunto race s
                          Stryd | Bryton Gardia R300L | Polar H9 | Polar oh1+ | Wahoo bolt v2 | 4iiii precision 3
                            withManish Bronze Member @elbee
                            @elbee I agree with you about changing brands, and every brand comes with its own set of issues. The major issue with all watches is battery life, and they are aware of these issues. Rather than addressing that basic need, they keep adding new features that aren’t that important.
                            When they advertise 15 days of battery life and then one update puts it down to 3-4 days of battery life without acknowledging the issue or offering a quick solution, it is more frustrating.
                            Most good rechargeable batteries have 300-400 recharge cycles; if you consider a week’s battery life, your watch lasts 5-8 years easily. My old Ambit 3 still works perfectly, just with a little less battery power after 8 years.
                            When I am buying a Finland-based company watch, at least I can ask for better support and solutions for issues.
                            www.withManish.com
                            E 1 Reply Last reply Reply Quote 0
                              @alp1n3 By the way, you can still restore old firmware, as your watch stores the last 3 firmware versions on it. Here are the steps you can go back to old firmware.
                              I just rolled back to old version 2.50.26; let’s see how it performs.
                              Here are the steps.
                              1 - Open Settings: Press the middle button to enter the main menu and select Settings > General > About.
                              2 - Scroll to the Bottom: Swipe all the way down until you see the Data Privacy section.
                              3 - Trigger Debug Mode: Press and hold the bottom right button for 12 to 20 seconds while on this screen.
                              4 - Select the Package: A hidden menu will appear. Scroll down and select Select OTA pkg.
                              5 - Confirm Downgrade: Choose your preferred previous firmware version from the list, then press the middle button to start the 10-15-minute rollback process.
                              www.withManish.com
                              • E Online
                                elbee @withManish
                                @withManish
                                I have a similar attitude towards watches as you. I don’t need yet an other fullbodyrecoveryindex number. And I look at battery life in years, not in days.
                                My Ambit 3 sport was quite nice, my forerunner 935 lasted 6 years. I hope, and expect, my race s will also last many years.
                                  @elbee, changing bands is another problem; you have had data in the system for so many years, and there’s no easy way to migrate to another platform.
                                  www.withManish.com
                                  • E Online
                                    elbee @withManish
                                    @withManish
                                    On iOS there is rungap for datamigration.
                                    And I use strava and intervals.icu. It collects data from multiple sources (I had different brands in the past).
                                    But most importantly, data of 5 or 10 years ago hardly has any relevance. But I’m no hardcore data collector.
                                    Register Login
                                    • First post
                                      Last post
                                    Suunto Terms | Privacy Policy
