    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Race S: Extremely high battery use rate
    Scheduled Pinned Locked Moved Suunto Race S
    125 Posts 35 Posters 12.5k Views 32 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • Michele SellaM Offline
      Michele Sella @snow*
      @snow Nope, didn’t know i could do that! I’ll do it now since tomorrow i have an activity planned. Will let you know if it changes anything. Thanks!
      S 1 Reply Last reply Reply Quote 0
      • sky-runnerS Offline
        sky-runner Platinum Member @2b2bff
        @2b2bff said in Race S: Extremely high battery use rate:
        Seems like Suunto and Polar is not a good combination judging on several posts about problems with a Polar HRM…
        I’ve had similar issues with Coros HRM (armband sensor).
        Suunto: Ambit, Ambit 3 Peak, 9 Baro, Race S, Race Ti, Vertical 2 Ti
        Garmin: Forerunner 210, Forerunner 610, Fenix 6X, Fenix 7X Ti
        • S Offline
          snow* @Michele Sella
          @Michele-Sella Both Verity Sense & H10 work flawlessly for me after updating. A friend of mine is facing issues though with BT (signal drops).
          Race S Ti.
          Spark
          Michele SellaM 1 Reply Last reply Reply Quote 1
          • G Offline
            gagbo
            I have had the same problem for 6 months, I tried to RMA the watch and got told that everything is fine, I’ve put the watch away and went back to my Gatmin FR255. After the “November Drain” update I tried the watch again, (with a soft reset, low brightness, no always-on) and I still had crazy battery drain.
            I’m considering trying again now because it feels bad having the watch here and not doing anything, but apparently there are still issues since the post here is recent.
            As far as I understand, the current state is:
            • Maybe having an external HR paired drains battery? I will use a strap anyway to have precise measurements so I guess I can’t do anything about it
            • Maybe using some watch faces drains battery? I should use the default Race S one?
            • Maybe 24/7 HR messes the battery up ? I wear the watch all the time, but the working hypothesis is that the sensor loses contact with my skin (or struggles in general because I’m black?) and that makes the sensor go nuts on light emission?
            I’m trying to find some leads that would make the watch usable for me, as I’m too forgetful for a watch I must recharge every other day
            G 1 Reply Last reply Reply Quote 0
            • Horizontal_2H Offline
              Horizontal_2 Bronze Member @Tieutieu
              @Tieutieu Haven’t tracked it, but I noticed this too! (SV2)
              • G Offline
                grego
                Confirmed on my watch too. Before sleep was 15%, in the morning 9% - DND on, 24/7 HR, lastest software 2.50.28.
                • G Offline
                  gagbo @gagbo
                  I just tried:
                  • Race 2 Watch face, with always on display
                  • 24h after charging, 1h20 of GPS activity (biking with a chest strap)
                  • 24/7 heart rate (but no SpO₂)
                  • wore the watch the whole time
                  I lost 29% battery (from 100 to 79)
                  So long and see you next software update for another try, I’ll go back to my forerunner 255 😕
                  2 1 Reply Last reply Reply Quote 0
                    @snow so charged the watch 100% Sunday morning and got 75% after 5h activity with tracking and auto pause. Then no activity only kept the watch with me, now it is Wednesday 21:00pm and I’m at 10%. Seems still high consumption to me. I remember I could get 6/7 days of battery life without activity.
                    sky-runnerS S 2 Replies Last reply Reply Quote 0
                      sky-runner Platinum Member @Michele Sella
                      @Michele-Sella Yes, the battery use is easily twice as high as it used to be.
                      For example this morning during a 40 minute gym training without GPS it went down (according to the information stored in the FIT file) from 33% to 31%.
                      7 hours later the watch is already at 23%. That isn’t normal by any means! AOD is off.
                      • S Offline
                        @Michele-Sella I thought a factory reset would definitely fix the problem, but unfortunately, it’s gotten even worse now. I could be wrong, but as I said, it seems to depend on when I start using bluetooth. Now I restart the watch after every use of the chest strap and GPS just to see if anything changes. I hope Suunto starts looking into this regression
                        As @sky-runner says also for me AOD off and even 24/7 HR off to save battery now
                        Race S Ti.
                        Spark
                        S 1 Reply Last reply Reply Quote 1
                        • 2 Offline
                          2b2bff Gold Members @gagbo
                          @gagbo said in Race S: Extremely high battery use rate:
                          Thats 21% and expected as the watch with AOD will only get about 5 days - less if actually used…
                          Suunto Race S
                          Garmin Epix Pro
                          G sky-runnerS 2 Replies Last reply Reply Quote 1
                          • G Offline
                            gagbo @2b2bff
                            @2b2bff my bad, it was to 71%, one too many 9
                            But I guess counting for 80min of GPS and 24h of AOD that would still be within spec (30h GPS is 3%/h and 5d AOD is 20%/d so 23 vs 29) I guess I misread the specs
                              @2b2bff I currently observe about 20% loss per day with display wake on wrist (no AOD) and all other settings being default. For example, my watch lost 22% (from 31% to 9%) in the time period since 9am yesterday to 11:30am today.
                              According to the website the expected battery life in smartwatch mode with these settings is 9 days, but the real battery life is about twice as short.
                              • 2 Offline
                                2b2bff Gold Members @sky-runner
                                @sky-runner I have AOD enabled and get about 4 days, I guess. So, not extremely high, but mabye a bit more than it used to be…
                                Next update is around the corner, so let’s see what it gives us…
                                Suunto Race S
                                Garmin Epix Pro
                                • S Offline
                                  snow* @snow*
                                  A soft reset after using the chest strap seems to mitigate the issue…
                                  Edit: yesterday at 6 pm I updated the watch (version 2.53.42); the battery was at 40%. I went for a 30-minute run wearing the chest strap and didn’t perform a soft reset afterwards. This morning at 6 am the battery was at 36% (sleep, hrv enabled). So far, so good, I’d say 🤞 🤞
                                  Edit: after four days of heavy use, afaic the battery is holding up well so, barring any last-minute surprises, I’m happy with it now
                                  Edit: the last one I promise. Today I went trail running for an hour and 40 minutes with the navigation screen on the whole time. The battery dropped from 86% to 79% 👍 🤙
                                  Race S Ti.
                                  Spark
                                  • TieutieuT Offline
                                    Tieutieu Platinum Member
                                    Feedback after updating my SRs Tuesday. Extra battery consumption seems to fixed to me and back to what is was on daily use. To be confirmed
                                    Suunto’s devices at home :
                                    Vertical titanium solar
                                    Suunto Race S
                                    S9pp titanium sand
                                    Suunto Wing & Spark
                                    S9B titanium Ambassador edition, A3P, X6
                                    • TieutieuT Offline
                                      I can confirm now : extra battery drain on daily use has been fixed
                                      Suunto Race S
                                      S9pp titanium sand
                                      Suunto Wing & Spark
                                      sky-runnerS atoponceA S 3 Replies Last reply Reply Quote 1
                                        sky-runner Platinum Member @Tieutieu
                                        @Tieutieu I am not so sure! I have a new Vertical 2. At first the battery usage was excellent. But once I connected and used Coros armband HR sensor for the first time, the battery consumption has increased to over 10% per day in smartwatch mode. The battery was at 55% yesterday. One day later, including a 1:30h run, the battery now is at 43%. A different watch but the same issue. That doesn’t seem normal!
                                        S 2 2 Replies Last reply Reply Quote 0
                                        • S Offline
                                          snow* @sky-runner
                                          @sky-runner said in Race S: Extremely high battery use rate:
                                          Before this update, I had noticed a significant drop in battery life, and the only solution I had found to mitigate the issue was to perform a soft reset after using the chest strap. After the update, I also performed a factory reset, and now afaic the battery is working properly
                                          Race S Ti.
                                          Spark
                                          • 2 Offline
                                            @sky-runner this thread is in the Race S forum and has Race S in the title. I guess it is related to the Race S then?
                                            Suunto Race S
                                            Garmin Epix Pro
                                            E sky-runnerS 2 Replies Last reply Reply Quote 0
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
