    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Suunto Routeplanner
    Scheduled Pinned Locked Moved Suunto app and other software services
    61 Posts 27 Posters 9.2k Views 29 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • Josh PlattJ Offline
      Josh Platt
      I am really glad to see this browser option from Suunto! Quick question about the Route Collection functionality. Is it possible to see all routes in a collection on the basemap at once? I am planning a multi-day trip and would like to see the option to have multiple routes visible at a time. In my case, I am trying to separate my routes by day.
      • HonzaSH Offline
        HonzaS
        I wanted to try the route planner and found a bug that makes planning impossible.
        In the “Outdoor” map view, forest and dirt roads are displayed as regular roads. Only after zooming out to a certain level do they appear correctly as dashed green lines. However, at that zoom level not all paths are displayed anymore.
        The dark map mode works exactly the opposite way. Even at the highest zoom level, forest and dirt roads are displayed correctly as dashed lines, but from the same zoom-out level they start to be drawn as regular roads.
        b7009e92-e727-4c06-959a-edb5b376f284-image.png 231d2f3e-6ed0-4432-b3d3-a2288c117f3c-image.png
        ad2281ea-65e3-4c51-836c-4858e1583a3e-image.png 87680971-631a-4a81-a595-7d997139edeb-image.png
        In Suunto Android app, the same forest and dirt roads are displayed correctly as full or dashed green lines.
        Suunto Vertical 2
        Nigel Taylor 0N 1 Reply Last reply Reply Quote 1
        • Nigel Taylor 0N Offline
          Nigel Taylor 0 Bronze Member @HonzaS
          Is this still being actively developed, is there official support?? I’ve not really noticed any changes since day 1 ??
          I find that if I “Upload Route to Suunto”, and then bring that route back to work on it later, any saved Waypoints disappear (but are visible in the phone app).
          This along with the routeplanner seemingly forgetting it created the original route and thinks its just a regular GPX, so if you “come back later”, then make changes and re-upload, then TBT is lost to the watch, unless you ‘re-mark’ routing points along the route and effectively redraw it.
          Final issue with Waypoints is where I have routes which go over the same place twice, it becomes impossible to place them where I want…so if I have an out and back section, and halfway out I want a Waypoint to remind me to have a gel or something, I can’t reliably place it on the “out”, it might be on the back…
          …one simple solution on this would be if the Waypoints also displayed, and were placeable, by clicking on the Altitude vs Distance chart that goes along the bottom.
          It would be nice to be able to grab a placed Waypoint on the Altitude graph and nudge/shift it left or right to the desired position.
          sky-runnerS 1 Reply Last reply Reply Quote 0
          • sky-runnerS Offline
            sky-runner Platinum Member @Nigel Taylor 0
            @Nigel-Taylor-0 said in Suunto Routeplanner:
            This has always been a problem with Suunto, even with the app based route editor. But what is even worse, even if you manage to place waypoints correctly, for example one on the out part of the route and one on the back part, there is no guarantee that these waypoints won’t jump to another part of the route when synced to the watch, as long as the route is transferred via GPX. For example, you may end up with two waypoints on the out part and none on the back part. In GPX there is no concept of the distance on the route, so the waypoint has only the coordinates, and in my experience Suunto interprets that randomly.
            Garmin avoids this issue by using a FIT format for routes where every waypoint has a distance along the route in addition to the coordinates. I propose that the web route planner also adopts the FIT format. Along other things, the FIT format can also include turn directions or timing information for pace guidance. Then it would be possible, for example, to import enhanced routes from sites like PlotARoute and UltraPacer that currently only Garmin watches can take advantage of.
            Suunto: Ambit, Ambit 3 Peak, 9 Baro, Race S, Race Ti, Vertical 2 Ti
            Garmin: Forerunner 210, Forerunner 610, Fenix 6X, Fenix 7X Ti
            Nigel Taylor 0N 1 Reply Last reply Reply Quote 2
              Nigel Taylor 0 Bronze Member @sky-runner
              @sky-runner you don’t need FIT to do that, despite all the posts above saying it…GPX will suffice, it’s exactly what I’ve been doing before returning to Suunto this year.
              For previous few years I’ve been using plotaroute, adding my own waypoints (technically they’re routepoints) to mark turns/aid stations/whatever, exporting as GPX and successfully using those files on Apple using the Workoutdoors app, or on Garmin (with the oddity that I had to dump the files into the watch file system via a browser, sharing them via Garmin Connecf would strip my waypoints/routepoints).
              It became my much preferred method of watch nav, Garmins automated TBD is just stupid, with tons of spurious alerts, and Apple Workoutdoors app simply didn’t have it, until recently.
              Creating manual turn points / cue points, embedding them in a GPX, is the way that I want to work most of the time…I want to study the route and ensure I understand it, adding alerts when I expect to need them. The automated TBD is just a nice to have really.
              I think the limitation you’re referring to is for POIs, which technically sit on the map, rather than on the route, so have no concept of being “at X distance along the route”, they’re just “oh, you’re near this”.
              sky-runnerS 1 Reply Last reply Reply Quote 1
                @Nigel-Taylor-0 Yes, importing waypoints via GPX does work as long as it is a simple route. But now imagine a situation when a route goes through that waypoint twice. Should that waypoint get triggered when you go through it the first time or the second time, or both? In the Suunto case it would be randomly either the first time or the second time. In the Garmin case, it used to be the bug at least in Fenix 7 - the waypoint wouldn’t trigger at all if it didn’t have a distance assigned to it. I have personally reported it on the Garmin forum and if I remember correctly they have fixed it a few years later.
                And if you think that the case I described above is not typical, in every single trail running race that I’ve done in the last few years (at least a dozen), some of the aid stations were visited twice. So I had to really jump through the hoop to make this work correctly with Suunto. With Garmin, as long as I created waypoints in Garmin Connect or Strava, or in PlotARoute with FIT export, this worked correctly.
                • Mff73M Online
                  Mff73
                  As per my own search and understanding, the issue is not purely related to the file format (fit or gpx) but more related to the fact that Suunto routes seems not to manage coordinates along with distance or timestamps (any of them would suffice) (as @sky-runner is explaining) (gpx could do this as well as @nigel-taylor-0 is saying also).
                  Fit or gpx, it is more how routes and Waypoints are handled in Suunto routing current mecanisms. Currently, if I did understand well, WP are some kind POI on the route (track) but without “when will they appear on the route” data.
                  But I can be corrected, it is not recent since I have looked into this.
                  SSU (retired), SV1, SV2
                  Wife : S9PP
                  SA: Always the latest beta :)
                  Android + Galaxy S205G
                  WillyW 1 Reply Last reply Reply Quote 1
                  • atoponceA Offline
                    atoponce @kemetter
                    @kemetter There seems to be a bug in the distance scale along the x-axis when looking at the altitude profile.
                    Here is a long road run I’m planning. The jumps per grid line are erratic:
                    https://routeplanner.suunto.com/?route=antelope-island-causway-1773616961583&style=outdoor&bottomBar=open
                    • 0 km
                    • 1 km (+1 km)
                    • 2 km (+1 km)
                    • 4 km (+2 km)
                    • 12 km (+8 km)
                    • 17 km (+5 km)
                    • 21 km (+4 km)
                    • 28 km (+7 km)
                    • 29 km (+1 km)
                    • 30 km (+1 km)
                    This is also consistent with a future planned mountain trail run also:
                    https://routeplanner.suunto.com/?route=thurston-francis-peaks-1773617342537&style=outdoor&bottomBar=open
                    • 0 km
                    • 2 km (+2 km)
                    • 4 km (+2 km)
                    • 6 km (+2 km)
                    • 9 km (+3 km)
                    • 16 km (+7 km)
                    • 23 km (+7 km)
                    • 27 km (+4 km)
                    • 29 km (+2 km)
                    • 33 km (+4 km)
                    Has this bug been reported already? Or is there something to fix it?
                    Thanks.
                    Suunto Race S / 9 Baro / Ambit 3 Peak / Observer
                    Polar H10 / Verity Sense / OH1
                    Stryd Duo / Wind
                    r/suunto mod
                    atoponceA 1 Reply Last reply Reply Quote 0
                    • WillyW Offline
                      Willy @sky-runner
                      @sky-runner
                      First this.
                      I don’t use Strava, Suunto, Garmin, nor .fit files.
                      I’m just reading along and respond to the next comment:
                      https://forum.suunto.com/post/185132
                      The GPX (trk) track mode with navigation wpt (waypoints) in Plotaroute is a Locus map track navigation method.
                      Unfortunately, Plotaroute does not offer the even simpler GPX (trk) track mode with navigation (trkpt) track points.
                      The TBTs are supersimply discreetly placed in the (trkpt) sym element, yielding so excellent results.
                      Any route planner—Strava, Suunto, etc if desired can eventually apply this as well. (someday ?).
                      In attachment: Issy Alps 50k_navtrk_12kmh.gpx
                      The demo GPX file is “discreetly” enriched with TBT trkpt’s , announced via trkpt’s inclusive the “separate” GPX wpt.
                      The via point info attached in the trkpt’s ensures their announcements is also automatically correctly timed.
                      The BRouter used for the demo file does not generate street names. The GPX format itself supports this as well if generated by the router engine of course.
                      The Android Cruiser GPS app uses this simple GPX navtrk format. (Locus Map imports and navigates this gpx file as well)
                      The Cruiser navigation audio alerts, triggered xxx meters before the turns or via trackpoints distance is customizable.
                      The audio alerts are set as TTS or a (loud) tone indication. (Different for L/R/S)
                      Translated with DeepL.com (free version)
                      • HamiltonH Offline
                        Hamilton
                        Hey everyone!
                        After a lot of trial and error, I finally cracked a super simple way to turn any city walk into a personal audio-guided tour using just my Suunto watch + phone. No need for expensive apps or guided tours – works offline once set up, and it’s perfect for historic/architectural walks like in Oviedo, Spain.
                        The key combo:
                        • Suunto Route Planner (web version: https://routeplanner.suunto.com/) for creating/planning the route and waypoints on a big screen.
                        • list itemGPSmyCity tours (free self-guided walks with detailed descriptions): https://www.gpsmycity.com/tours/oviedo-historic-architecture-6280.html
                        • list item@Voice Aloud Reader (Android TTS app) to read the tour descriptions aloud as you walk.
                        Step-by-step how I do it:
                        1. Pick a tour on GPSmyCity (e.g., “Oviedo Historic Architecture” – 2.7 km, ~2 hours, covers gems like Oviedo Town Hall, San Isidoro Church, Palace of the Counts of Toreno, Balesquida Chapel, Valdecarzana-Heredia Palace, and more – full list with descriptions on the page).
                        2. Open the page on your computer/phone → copy the full text (introduction + all stop descriptions). Paste into a note or Google Doc.
                        3. @Voice Aloud Reader:
                        • Import/share the text → it will read everything aloud (choose a nice voice, adjust speed).
                        • You can split into chapters by stop number for easy pause/resume, or just play sequentially.
                        • Bonus: offline TTS – download voice packs if needed.
                        1. Create the route in Suunto Route Planner (browser):
                        • Go to https://routeplanner.suunto.com/
                        • Search for Oviedo → zoom in.
                        • Manually add points/waypoints by clicking on the map at each stop’s approximate location (use the tour descriptions for exact spots).
                        • Name each waypoint clearly (e.g., “1. Casa Consistorial de Oviedo (Town Hall)”, “2. Iglesia de San Isidoro”, etc.).
                        • The tool auto-connects with paths/roads – tweak as needed.
                        • Save the route → sync to your Suunto app → sync to watch (turn-by-turn navigation works great).
                        1. Important tip about waypoints/GPX (learned the hard way!):
                          Waypoints added/edited in the Suunto app often don’t sync back to the web Route Planner properly (or get lost).
                          Always export the route as GPX from the web planner BEFORE syncing to watch (or right after creating). Keep a copy on your phone/computer.
                          If you need to edit later – import the GPX back into the planner (waypoints usually load if they were created there originally). Waypoints from watch → app → web don’t transfer reliably.
                        Result: On the walk, your watch guides you point-to-point (arrow + distance to next waypoint). At each stop – pause navigation if needed, tell @Voice to continue reading the description/history of that exact building/sculpture/site. Feels like a real audio guide!
                        This works for ANY city/place – just find a similar tour on GPSmyCity (tons of free ones), or even Wikipedia/Wikiloc/AllTrails descriptions. Super flexible for travel!
                        Has anyone else tried something similar? What TTS app do you use? Any tricks for better waypoint handling in Suunto?
                        Happy trails! 🗺️🎧🏰
                        HamiltonH 1 Reply Last reply Reply Quote 3
                        • HamiltonH Offline
                          Hamilton @Hamilton
                          For testing, I attached my route.gpx file.
                          route.gpx
                          Even Better Prep: Virtual Tour with AI + Satellite Maps Before You Go!
                          Want to make your walk 10x more exciting and personalized? Do a virtual preview right from home!
                          Open Google Maps / Google Earth (satellite view) or Apple Maps — zoom into your destination city (e.g., Oviedo historic center).
                          Switch to 3D/street view if available, or just satellite + street names.
                          Ask an AI (like Grok, ChatGPT, Claude, Gemini — any good one):
                          “Describe the top historic architecture highlights in Oviedo’s old town for someone who loves Pre-Romanesque and Baroque styles. Suggest a personalized walking order based on my interests: [your preferences, e.g., ancient fountains, cathedrals, hidden gems, avoid crowds]. Include why each spot is special and photo tips.”
                          The AI will happily give you a tailored list with explanations — often better than generic guides! For example, it might prioritize La Foncalada (9th-century fountain), San Tirso Church (Pre-Romanesque), the Gothic Cathedral, Foncalada Fountain, San Julián de los Prados (UNESCO Pre-Romanesque with frescoes), etc., and suggest starting at the Town Hall for the best flow.
                          Then:
                          Use the AI’s suggestions to fine-tune your waypoints in Suunto Route Planner (add custom notes like “Must-see: Victory Cross on Foncalada”).
                          Take screenshots of satellite views or AI descriptions — paste into your phone notes for offline reference.
                          Bonus: Ask AI for café recommendations at the end (e.g., “Best sidrería near Foncalada Fountain in Oviedo for a reward after the walk”).
                          This way, you arrive already “knowing” the places, spot hidden details faster, and feel like a local explorer. Your walk becomes truly customized — no more surprises (only good ones)!
                          Anyone tried AI for pre-trip route personalization? Share your prompts or results! 🚀🗺️🤖
                          • WillyW Offline
                            Willy @kemetter
                            @kemetter
                            Please consider the following purely for informational purposes.
                            As I was particularly curious about the Suunto web GPX export.
                            The web presentation is actually very well done.
                            The GPX export differs from what I expected 😉
                            See attachments:
                            Suunto_route.gpx
                            Suunto_navtrk.gpx
                            The Suunto GPX export and a comparable copy as a GPX navtrk file.
                            The original GPX file was manually edited for this purpose using Notepad++.
                            The GPX navrrk copy therefore so do not contain any trackpoint timestamps.
                            A few GPX WPTs have been added with a Garmin-compatible sym.
                            One of these GPX WPTs also contains an operational web link.
                            The GPX WPT list is not unnecessarily cluttered with turn instructions.
                            See also the presentation in the Cruiser desktop version.
                            • WillyW Offline
                              Willy @Mff73
                              @Mff73 said in Suunto Routeplanner:
                              It is more how routes and Waypoints are handled in Suunto routing current mecanisms.
                              @ all
                              The Suunto Web Planner gpx export includes items 1 and 2.
                              1. A “direct” gpx (rte) route. (Rarely used)
                                Some apps treat such “direct” routes as tracks.
                                Other apps may refuse to import or even do crash.
                              2. Suunto gpx extension.
                                The gpx extension ensures the *association between gpx rtept and unique corresponding gpx wpt that contains the instructions.
                              Find some gpx variants. (Inclusive Suunto gpx extension).
                              Can a volunteer (watch owner) import, test and report pse ?
                              A_Suunto_route.gpx (Original rte export)
                              B_Suunto_track.gpx (rte converted to trk)
                              C_Suunto_route+wpt.gpx (A + extra wpt)
                              D_Suunto_track+wpt.gpx (B + extra wpt)
                              E_Suunto_navtrk.gpx
                              F_Suunto_navtrk+wpt.gpx
                              G_Basic_navtrk.gpx (Contains no gpx wpt nor gpx extensions)
                              • Association
                                The required strict association is handled differently in a Plotaroute (Locus) gpx export.
                                As this is applied in a very similar way as used in a Garmin tcx course_coursepoints file.
                                The Garmin tcx course with coursepoints file is the “forerunner” of true track tbt navigation.
                              • In a gpx tbt navigation track this “fragile” association complexity is unnecessary.
                                The instructions are directly attached in the relevant gpx (trkpt) trackpoints. (As well Cruiser and Locus map do navigate this file)
                              Mff73M 1 Reply Last reply Reply Quote 0
                              • Mff73M Online
                                Mff73 @Willy
                                @Willy
                                What do you want “us” to test? 🤔
                                Importability? Routability? Something else?
                                I read all your posts, all about gpx files, and still not sure to understand where you are trying to guide us. 🤔
                                Wife : S9PP
                                WillyW 2 Replies Last reply Reply Quote 0
                                • WillyW Offline
                                  Willy @Mff73
                                  @Mff73
                                  Importability.
                                  The reference is the A (rte) file. (Original).
                                  Do file B to G import as well ?
                                  “I am most curious about the B (trk) result”
                                  • If succesfull than next
                                    Routability.
                                    Do files B to F show the TBT as well or not ?
                                    If nok than test STOP and over and out 😉
                                    If ok than continue with a more complicated (multioverlap) track
                                  • C Offline
                                    ChrisTrail38
                                    Hello @kemetter !
                                    This is a great app for viewing and creating routes on a larger screen. Would it be possible to add a route generator that lets you enter parameters like “duration,” “distance,” and “elevation gain”?
                                    • WillyW Offline
                                      Willy @Mff73
                                      @Mff73
                                      Import of gpx (trk)tracks in the Suunto Web Planner is positive.
                                      Simple compare by “manually” adding the tbt data in trackpoints.
                                      Manual edit prone to “typos.” In previous files one right should be left. 😇
                                      • Out-and-return overlap track test file series.
                                        Observe compare and study, open in Notepad++
                                        1A_Suunto out and return rte.gpx
                                        1AA_Suunto out and return trk.gpx
                                        1B_Suunto out and return navtrk.gpx
                                        1C_Out and return navtrk.gpx
                                        1D_ A small file sized compressed gpz version is possible
                                        The upload of gpz or zip files is not possible in this forum
                                        1E_Out_and_return_course.tcx
                                        1F_Out_and_return_course.fit
                                      The Suunto gpx extension only adds the via trackpoint bindings.
                                      I seriously doubt this is sufficient for 100% TBT reliablility.
                                      In the previous simple track the Suunto TBT generation is correct.
                                      In the out-and-return track the Suunto TBT generation is incomplete.
                                      Specifically 2 TBTs in the overlap return track section are missing.
                                      True Track TBT file modes.
                                      https://github.com/osmandapp/OsmAnd/issues/14147#issuecomment-1114034225
                                      • atoponceA Offline
                                        atoponce @atoponce
                                        Planning another long run of ~35 km, give or take. As expected, the Suunto Route Planner has non-uniform spacing between distance ticks on the x-axis:
                                        • 0 km
                                        • 1 km (+1)
                                        • 3 km (+2)
                                        • 6 km (+3)
                                        • 8 km (+2)
                                        • 13 km (+5)
                                        • 16 km (+3)
                                        • 18 km (+2)
                                        • 24 km (+6)
                                        • 33 km (+9)
                                        • 35 km (+2)
                                        This gives a skewed view of the elevation profile:
                                        Compare to the uniform spacing using onthegomap.com:
                                        Stryd Duo / Wind
                                        r/suunto mod
                                        Mitch9M brechtvbB 2 Replies Last reply Reply Quote 0
                                        • Mitch9M Offline
                                          Mitch9 Silver Members @atoponce
                                          @atoponce Yes, I can confirm this strange behaviour.
                                          Watch: Suunto Vertical Titanium Solar (Sand)
                                          SA: Android (beta)
                                          HRS: Polar H10
                                          • brechtvbB Offline
                                            brechtvb Bronze Member @atoponce
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
